Question about Packard Bell Easy One Silver 2120 Notebook
Soon as you press any key it locks up.
Mouse pad work until you press anykey and its like the key lock is automatically activating.
i have not got a clue what to do to stop this from happening.
what should i do?
  • Packard Bell Master
  • 5,568 Answers
This sounds more like a corrupt driver than a hardware problem-
Go to the Control Panel, open the System folder, then Hardware, then Device Manager. Find and open the keyboard item, highlight the keyboard shown and delete it.
Reboot your system and force Windows to find it again and install the driver.
If this doesn't work, follow the same procedure except delete the mouse listing.
Reboot and Win should find it again and also reinstall the driver.
Posted on Dec 15, 2008
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
I activated a setting where by my cell phone is supposed to automatically lock its key pads every 5 sec after use. it has automatically rocked its self and i want to re use it. how can i go about the un...
To unlock the keypad of Nokia E71, press the left function key (left most key just below display) followed by the right function key (the right most key just below display). This should work.
Jun 28, 2011 | Nokia E71 Smartphone
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    Compaq notebook laptop: my mouse pointer or arrow is
    If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
    If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
    Dec 19, 2009 | Acer Aspire 5100 Notebook
    Internal mouse will not move and lights are red/orange
    this might be a problem with the mouse lock..
    check ur mouse lock button just above the mouse pad.
    if its locked, unlock it & try again.
    if its not locked, then go to device manager via right clicking My Computer, properties
    select mouse device & expand the tab
    uninstall the mouse, dont worry it can be done without mouse.
    now press the windows key from keyboard, and restart ur system via pressing Start key, +u, +r for windows Xp & for Windows Vista, press ALT+F4 then select restart.
    After ur machine boots up, it will automatically detect the mouse & reinstall the required drivers. its done
    if u like my post, pls rate me.. i really need some good ratings..
    Thanks
    Nov 27, 2009 | HP Pavilion dv9000z Notebook
    Same...
    Try an external mouse and if that works your touchpad is bad and needs to be replaced.
    Sep 01, 2009 | LG X-Note LM50 Notebook
    My panasonic kx-tsc10mxw keypad locked
    take this:
    1- Press Function
    2- Press Down button until menu “Change password” displayed -> ENTER
    3- " Current password " : Press this Number "726276642" -> Enter
    4- “New password”
    5- 0000 ENTER
    6- EXIT
    7- Press DIAL LOCK KEY
    Jul 12, 2009 | Panasonic Lands Phones
    How do I lock the keypad?
    You can manually lock the keypad to avoid pressing keys by accident. You can still answer an incoming call and the keypad will lock again when the call is finished. The keypad remains locked until you unlock it manually.
    Depending on your phone model, you can activate the automatic keylock. When the automatic keylock is activated, the keypad locks shortly after you stop pressing keys.
    Please note: with some phones you can still use external keys when the keypad is locked. If you wish to lock the external keys you must lock them separately.
    K530i To manually lock the keypad:
    1. From standby, press the * key.
    2. Select 'Lock keys'.
    To activate automatic keylock:
    1. From standby, select 'Menu' > Settings.
    2. In the General (tab), select Security.
    3. Select Automatic keylock > On.
    To unlock the keypad:
    2. Select 'Unlock'.
    Mar 31, 2009 | Sony Ericsson K530i Cellular Phone
    Lock the keypad
    K800i To manually lock the keypad:
    2. Select "Lock keys".
    1. From standby, select "Menu" > Settings.
    2. Select "Unlock".
    3. hope this helps Thanks and God bless
    Dec 15, 2008 | Sony Ericsson K800i Cellular Phone
    Computer locked
    there are combinations of function or "hot keys" for enabling or disabling these functions. The NuLk is a combo of the functin key and the NumLk key pressed simultaneously. The scroll lock is the one keeping your mouse from working properly. I'm not familiar with your particular unit to advise which keys are necessary to disable Scroll lock, but they should be marked. Also, some notebooks have a switch to disable the mousepad...Usually indicated by a light located above the pad itself. Good luck Harvester3
    Aug 18, 2007 | Averatec 3200 Notebook
    Packard Bell Easy One Silver 2120 Notebook Logo
    100 people viewed this question
    Top Packard Bell Computers & Internet Experts
    Alun Cox
    carey w mason
    carey w mason
    Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
