Question about Canon PIXMA MP160 All-In-One InkJet Printer
Paper goes in bent in printer so printed item is bent
    Guru:
  • Canon Expert
  • 183 Answers
Dear jabir,
Please check if any other material is present in paper path from paper tray to platen unit (paper eject assembly). It's usually caused by this.
Posted on Dec 05, 2008
My HP 6500A plus is giving an error code 0.6101 bed. Do you know what the problem is, is it practical to repair.
Do you mean the error 0x6101bed? This appears to be an error with the printer carriage or the sensors that detect paper in the trays. Unplug the USB cable if you are using that connection before trying the steps below.
Some people have solved the problem by turning off the printer and then removing the photo feed and output trays. Also remove any extras like a duplexer if you have one. Put in a sheet of plain paper. Then turn on the printer and quickly press the Menu button. Find the menu item for printer reports and select print status report (or a similar item). Push the paper gently into the printer pickup until the pickup spool catches the paper. Press Cancel and see if the printer ejects the sheet.
Some people have found that adding a few extra power on/off power cycles (5-6) helps. Then try to to move the print cartridges (gently - do not force anything) while the printer is off. While you are trying to move the print cartridges, check for any foreign objects in the printer. (A small piece of paper can cause the bed error.)
Make sure that the printer is on a firm surface wider than the printer. Pick it up and put it down again to shake things loose inside. At some point, the printer will go into a initialization step if you have solved the internal issue.
If these don't help, it may be that the internal frame and the rail that the printer cartridges ride on is bent. Then the solution is probably to replace the printer.
I hope this helps.
Oct 21, 2014 | HP Officejet 6500A Plus Wireless...
Will not print paper jam light comes on
if the printer take in one side of the paper and then stop or jam, then most probably something, small item was caught or trapped in between the roller or wheel
Feb 23, 2012 | Canon PIXMA iP1600 Printer
Printed 47 pages, paper for page 48 started to feed incorrectly & was yanked out. However, LCD keeps saying paper jam even though entire paper was retrieved. Turning machine off, on, examined for any...
More likely especially if the paper was pulled out backwards, that the paper sensor just before the platen roller is bent or broken. When you pull paper back up thru the feeder it gets caught on this sensor tab and it gets bent, holding it up just like a paper scrap would. If it's broken or you can't locate it to bend it straight, you will need a shop to repair your printer.
Dec 31, 2009 | Canon PIXMA MX310 All-In-One Printer
Lexmark6150
Either an obstruction, dirty rollers, paper guides not snug to the paper, or something is bent.
May 24, 2008 | Office Equipment & Supplies
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Paper wont load
Please check the following items:
Check item 1:
The cable may not be securely connected between a printer and a computer, or be about to be unconnected.
Check that the cable is securely inserted into the ports of the printer and the computer respectively.
If a USB hub is used, connect the printer and the computer directly.
Check item 2:
Print jobs may be queued.
Delete the print jobs queued in the computer. How to delete the accumulated and queued documents in the computer (Windows)
Check item 3:
The computer settings may not be corrected.
Check the computer settings. How to confirm the computer settings (Windows)
Jan 14, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
