Question about Presto HeatDish Compact Heater
Cleaning the dish on my Presto space heater.
I have a Presto HeatDish Compact Heater and would like to cleane the dish. It is getting very dusty and smells funny when it's on. I can't see any way to remove the grid covering the dish. Is the only way to clean it going to be putting something through the bars on the grid and poking around that way?? Thanks for your help.
  • 4 more comments
  • Anonymous Feb 22, 2008
    By far, the easiest way is to moisten a cloth, wrap around a long screwdriver (making sure you can grasp the cloth by the screw driver handle) thread is through the screen at 12-3-6 and 9 o'clock positions, Extend the wrapped cloth several inches past the end of the screwdriver. Then sweep it from side to side at each position. You may have to tilt the heater to get to the edges, but it is far easier than trying to "bend metal" to get inside the cage. Don't over-moisten the cloth..just damp enough to remove the dust. Make sure it is unpluged...of course. Wait for it to dry before using. Worked for me!
  • Anonymous Oct 06, 2008
    I am concerned about the odd smell eminating from the unit. It smells like baking art clay (like FIMO, etc). What causes the smell? is it toxic? Does it indicate malfunction?
    Thx
  • Anonymous Dec 05, 2008
    Same problem -- very dusty parabolic heater
  • gtschen2005 Dec 06, 2008
    I have a presto heatdish. It got dusty and I would like to know how to clean it.
  • Ann P Topmiller
    Ann P Topmiller Mar 06, 2014
    PRESTO has a brush that is made to assist in cleaning parabolic heaters. Here's a link.https://www.gopresto.com/products/offers...
  • Ann P Topmiller
    PRESTO has an inexpensive brush that can be used to assist in cleaning a parabolic heater. Here's a link. https://www.gopresto.com/products/offers...
I pried the upper rim with needle nosed pliers --,just enough to get the grid off. After cleaning with Mister Bubbles, I popped the grid back in and bent the rim back down. I then took a hammer and
smoothed the rough edges. Looks almost like new!!
Posted on Feb 17, 2009
  • Catherine Sagoco
    Catherine Sagoco Nov 24, 2015
    Cleaning the presto heat dish is easy by using a swiffer duster. Gently insert the swiffer in between the wires and dust. It's very easy.
  • RPicore
    RPicore Dec 30, 2016
    Thanks juancull it worked for me too!
What worked for me was taking a small, barely damp washcloth and with the unit on it's back (unplugged, of course) slid it through the grate. Next. I pushed it around with a wooden spoon until all of the dust was gone. Then, I pulled the washcloth back out.
I tried the butter knife method first, but it was chipping the ceramic coating off of the grate....
Posted on Nov 23, 2008
Dip it in a tank or put it in commercial launry and then dryer. it works
Posted on Feb 22, 2008
If you like living on the edge, spray some windex into the dish and then hit with a spray of water while upside down in the sink. This gets 99% of the dirt without disassembling a thing. Then if you have compressed air blow off the water or else leave it stand overnight to dry. You may get some steam from the coils when you turn it on but hey...live a little. Worked for me.....zap.
Posted on Jan 01, 2012
  • Ted Lessler Jan 01, 2012
The cleaner (and more reflective) the dish is, the more efficient the dish works.
I used the "pry" method with a pair of pliers. Carefully lifting the edge a very small amount. I went around about half way then "popped" the grill off. Cleaning was very easy and the grill "popped" right back on.
I rebent the soft aluminum back in place at 3 or 4 places so that it would pop off easier the next time but wouldn't pop off when you didn't want it to.
Posted on Dec 09, 2007
  • moonens
    moonens Mar 05, 2013
    I just used this method and only had to pry a small section (maybe 5") barely up for the grill to pop off :) So clean now! Went back on so nicely, can't even tell!
  • RPicore
    Agreed! It worked for me too.
I use the can of compressed gas duster that you use for computer keyboard cleaning. It has the extension tube for hard to reach areas but be sure to use short blasts otherwise it will send mists instead of compressed air. Hope this helps.
Posted on Jan 29, 2009
The smell that you experience when the heater is first turned on is any combination of dust, carpet fibers, pollen etc. that has settled on the dish, element or any other part that heats up. I ALWAYS start up the heater outside for a few minutes to burn off the dust before I bring it in and then put it down gently to keep more stuff from falling onto the hot surface. I tried several methods on my old Presto heater to clean the dish including most of the ones listed above. Soap and water worked the best after prying the cover open. but eventually the heating element rusted and broke in several places after about 10 years of use. I tried to find a new coil element to replace the old broken one with but the company doesn't sell them and the universal heating coil stock (in bulk) have to be matched in the electrical circuit for resistance, length, cross-sectional diameter and other factors. Does anyone know where to get a new element for the Presto? I did end up buying a new one but would like to fix the old one too.
Posted on May 23, 2010
    New Friend:
I have one and have kept it clean with a microfiber cloth and a chopstick; thru the grill. I got a 2nd unit, at thrift. It was grungy and a bit dented. I popped the grill off and cleaned it; knocked out dents, as well. Since it was oxidized, I polished it with Maguires Alum Mag Polish, and a random orbital buffer; with microfiber polishing pad.
I could not believe how shiny it got. Knowing that a smooth surface reflects more direct heat, I fired it up. The performance improvement is substantial. In most typical usage , I've had to dial the temp control back 1/4 turn; or more. I can see a deep red/orange glow, in the reflector, when it's on. I liked the mod so much, I did the same to my original unit. Here is a pic. Clean & unpolished unit on the left - polished beater on the right. The shine is great. I don't think picture fully does it justice.
Cleaning the dish on my Presto space heater. - cleaning-dish-presto-space-heater-smouatxufp5lwmehha1z5nye-1-0.jpg
Posted on Nov 28, 2015
  • 72 Answers
Take it outside and blow it out using a leaf blower or a can of compressed air.
Posted on Feb 26, 2007
    Problem Solver:
  • 6 Answers
It all depends on the how much dust has accumulated on inside of the dish.
Try to use the Swiffer first before mechanically altering any part. Slide the duster in through the grate, and move it around. Pull it out and repeat on the other area. You'll just have to do this around 3 times.
If heavy clean is necessary, then you might have to resort to bending the lip of the dish to separate the grate off from the dish.
Posted on Dec 11, 2014
By far, the easiest way is to take a long screwdriver, wrap with a very lightly moisten thin towel. Make sure the towel part is several inches longer than the screwdriver and that you can hold on to both at the handle side. Thread through the cage at 12-3-6-9 o'clock positions. Sweep from side-to-side, tilt the heater to get close to the cage. Worked for me! PS. Never do this while plugged in..of course. Let dry before using.
I pried open the dish from the grate (with two butter knives) and cleaned the dish very easily. Thanks to the other person who suggested this! I cleaned it with water on a cloth and 409.
Posted on Nov 26, 2007
I took 2 thin screw drivers and with some prying, removed the grill. cleaning was a breeze and snap the grill back in.
I created a small bend which I use to clean it regularly. Works for me.
Posted on Nov 24, 2007
 Blowed with compressed air first then use contact cleaner, then blow it again. Stuborned lint you may use tooth brush.
Be sure that contact cleaner is dielectric.
Good luck,
Orlando
Posted on Oct 18, 2007
But seriously: what's with the freaky smell?
Is it killing my brain?
I've had the heater for a few weeks (Costco purchase) and the smell is becoming intolerable.
Other commentors were spot-on; it smells like a cross between cooking Fimo / lighting pre-dipped charcoal briquettes
Posted on Jan 25, 2010
Unplug the unit and spray with glass cleaner or rubbing alcohol, trying to minimize direct spray to the heat core. The spray will clean the residue that may cling the dust to the surface and run down to the bottom of dish. Rinse with water, then blow dry.
Posted on Nov 04, 2007
  • bughyaugh Nov 04, 2007
    Oh, obviously one must be careful and SPRAY rinse the dish following the glass cleaner spray wash. (above)
  • CC136 ES
    CC136 ES Mar 19, 2019
    how do you pop off the grill
Plug Flamed & burned carpet when heatdish was turned on
hi check the connetions on the heater plug and the cord replace if brunt then try it again ?
Feb 23, 2010 | Presto HeatDish Compact Heater
RE: Presto Heat Dish buzzer going off
I almost threw my heater out! I cleaned this morning with Window Cleaner and it works just fine now. It was just dust. I cleaned the round metal area not the coils.
Hope this helps.
Emailed Presto about replacing the buzzer and here is the answer I got:
There is no such part. Buzzer sounds when heater:
- is tipped
- rests uneven on floor
- is too close to furniture or wall
- has too much dust on parabolic dish
The most common reason is that the parabolic dish is dusty.
To clean the heater:
1. Unplug the heater and clean it when it is cool
2. Spray a cloth with an all-purpose cleaner such as 409
3. Wrap the cloth around a long handle such as a wooden spoon
4. Wipe between the grate from the outer edge to the center
If you have further questions, please let me know. Or call us at 1-800-877-0441 Monday through Friday 8:00 a.m. to 4:30 p.m. Central Time.
Jan 11, 2010 | Presto HeatDish Compact Heater
How do we clean the inside of the dish?
This is from Presto
- is tipped
Jan 08, 2010 | Presto HeatDish Compact Heater
Buzzer goes off
This was the answer from Presto as I had the same problem. Cleaned it with window cleaner and a wooden spoon and paper towels and now it works great!
- is tipped
Dec 29, 2009 | Presto HeatDish Compact Heater
How to clean dish? Safety grate covering face of dish does not appear to have a way to remove it so backed on dist can be removed and heat dish can be returned to near new condition. Thanks, Mike
This is the answer I got from Presto. I cleaned it with window cleaner, wooden spoon and paper towels. Dish works great now.
- is tipped
Dec 21, 2009 | Presto HeatDish Compact Heater
My heater makes this constipating noise and the "tilt" alarm goes off after 10 minutes. I'm never able to turn it to the high position.
- is tipped
Dec 12, 2009 | Presto HeatDish Compact Heater
Clean dish
'tdulany's remedy for cleaning the dish on the Presto Heat Dish probably works well, but how do you get past the grill covering the dish in order to clean it?
Nov 26, 2009 | Presto HeatDish Compact Heater
Please give me the number on how to purchase dust remover that came in presto heat dish box. Thank you!
- is tipped
Oct 25, 2009 | Presto HeatDish Compact Heater
Presto Heatdish noise.
I know the metal dish has to be dust free, clean. Beyond that you may want to call their customer service number 800-877-0441 for more help.
Jan 13, 2009 | Presto HeatDish Compact Heater
Presto Heat Dish
The hardest part of cleaning the dish is that you can't get your hand inside the cage surrounding the dish. What I did was to use a wire cutter to snip enough pieces of the cage off so that I could get access to the dish. If you do it carefully, it looks as if it was intended and doesn't prevent the cage from working. If you think of the cage/dish as a clock, I cut all the strips between 9 and 11, and 1 and 3. Easy to clean the dish afterwards.
That might not solve the buzzing problem, though. It didn't solve it for me.
Feb 07, 2008 | Presto HeatDish Compact Heater
Presto HeatDish Compact Heater Logo
21,660 people viewed this question
Top Presto Heating & Cooling Experts
Vish Iyer
Vish Iyer
Archie Ferrarini
Archie Ferrarini
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
