1)i cant connect to the interface of Thomson 585 v7... 2)i cant connect to the internet...it says that my pc cant get an ip
    Problem Solver:
  • 3 Answers
If you cant get an ip best thing o try is to look at the bottom right of the screen on the task bar click on the two computers thing click on the support tab and repair ip if that dont work calling your internet provider would be best bet they might be having issues
Posted on Dec 04, 2008
Where is the WPS Button on my Thomson Speedtouch Router
Does the speedtouch 585v6 router have WPS and if so where is the ...
www.askmefast.com > Computers & Internet > Computer Networking > Router
  1. Cached
  2. Similar
Jump to The WPS button is located either at the back or top of your router.If ... - source: Trying to connect my wireless printer with the router at my new ... Router thomson speedtouch tasto wps ... Wps button speedtouch 585.
IS THERE A WPS BUTTON ON A SPEEDTOUCH ROUTER - Fixya
www.fixya.com/support/t20444391-wps_button_speedtouch_router
  1. Cached
Oct 1, 2013 - Question about Thomson Speedtouch St585 V6 Sl Wireless Modem ... do i find my password for my wireless speedtouch 585v6 router? my ...
Page 17 of the manual
https://www.cosmote.gr/fixed/documents/10280/652016/TG585_SetupUserGuide_en_v8.pdf/0878a24f-0922-408c-bd51-fff55a07f53a
Feb 02, 2017 | Thomson Computers & Internet
Hi, I can't open the main modem configuration page. the modem is (thomson tg585 v8. and the page adress is 192.168.1.254 it opens for a minut or so after turning it off then on, then it shows explorer...
Please try one of the following option:
Browse to http://dsldevice.lan or to the IP address of your Thomson Gateway (by default: 192.168.1.254).
If your computer runs Windows Vista or Windows XP, you can also access the Thomson Gateway Web Interface using the Internet Gateway Device icon.
If you computer runs Windows Vista:
1 On the Windows Start menu, click Network.
2 The Network window appears:
3 Right-click your Thomson Gateway (displayed as THOMSON TGXXX) and click View device web page.
4 The Thomson Gateway Web Interface appears.
If you computer runs Windows XP:
1 Go to My Network Places.
2 The My Network Places window appears:
3 Double-click your Thomson Gateway (displayed as THOMSON TGXXX).
Be sure you don't have any popup blocker or firewall interfering.
For more reference here below the manual (Version 7 that is basically the same of V8)
http://www.cytauk.com/cytauk/userfiles/TG585-v7_SetupUserGuide_en_pdf.pdf
regards
Mar 22, 2011 | Computers & Internet
Major wireless problems.. I can connect to my wireless router (Thomson 585v8) but i cant connect to the internet. When it connects it says local only. How do i fix it so i can go on the internet..??
check if the ip address that you are getting begins with 192.169.x.x ( x = any number between 1 to 254) check that your router the DHCP service is enable and that there a network range set (example lets say your gateway ip is 192.158.0.1 then your dhcp by defult in most cases will look like this ip range 192.168.0.2 - 192.168.0.254 using a netmask of 255.255.255.0 that will give you 254 ips per network.)
if your ip start with 192.169.x.x the that means that your machine is not getting a real ip assigned to it all you get is an APIPA that is just a reseved ip by the system to fill out ethernet interfaces that don't have and static ip or are in a network without a DHCP server.
you can set a static ip in the client pc if you don't want to enable DHCP in the router.
when you see Local Only message it means that your pc hasn't detected a route to the outside network ( internet ) without a proper gateway you will not be able to get to the internet, your router ip is always your gateway.
example:
Router Client pc
IP 192,168.0.1 IP 192.168.0.2
subnet mask 255.255.255.0 subnet mask 255.255.255.0
default gateway 192.168.0.1
Mar 03, 2011 | Computers & Internet
Broadband wireless adapter limited connectivity issues
If the wireless security on the router is enabled, then the pre-shared key or encryption key on the router and PC should match.
To check the wireless settings, use the laptop to access the web interface of the router. Follow the steps below:
1 Using your Internet browser, go to http://dsldevice.lan or to the IP address of your router (by default: 192.168.1.254).
2 On the Home Network menu, click Wireless.
3 In the upper-right corner, click Details.
4 The wireless Access Point page appears. Under:
- Configuration, you can find the network name (SSID).
- Security, you can find the encryption.
On the PC wireless, access the wireless network connection. Select the SSID and then type the encryption key or pre-shared key.
Once the encryption key on the PC and router matches, then you should obtain an IP address and get online.
Nov 27, 2009 | Computers & Internet
Lost connection
what u need to do is go to the interface of ur thomson speed touch through writing the ip address of that modem on the address bar of ur internet browser then go in that setup....Choose router instead of bridge.
Jul 14, 2009 | Computers & Internet
Thomson TG 585 v7 Wireless Problem
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
Sep 11, 2008 | Computers & Internet
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
