Question about Pitco Frialator 35CD Deep Fryer
No heat pilot will light and stay lit but when i turn switch back to on and turn thermostat back up cooking temp it will not begin heating.
    Novelist:
  • 75 Answers
1st I would check any safety switches it may have such as oil drain valve switch controlled by the oil drain valve. If it has an exhaust blower, it may have to get up to a certain speed before the flame will come on. This would be a vacuum type switch. If it has a pilot light that burns all the time, it probably has a thermocouple which the pilot light heeps hot. This could also be the problem and need replaced. If there is no resturant equipment service tech in your area, A air cond tech would be your best bet for troubleshooting it. Good luck.
Posted on Feb 19, 2007
My heat won't come on.
Newer furnaces do not have a pilot light. If yours does, you will have to relight it. Find the gas valve inside the furnace and follow the lighting directions. Generally, you turn the valve to the pilot position, press a button and hold it while you light the pilot. Hold it for about a minute and then release. If the pilot stays lit, then you can go ahead and set the thermostat to call for heat. If it does not stay lit, or the furnace still will not light, I think you need to call a repairmen or someone with knowledge of how to troubleshoot the problem.
Mar 21, 2014 | Heating & Cooling
What is a thermocouple and what does it look like
A thermocouple is a bi-metallic junction that when heated gives an small electric output. The tip of it sits where the pilot light is ( and it is a copper tube going to the gas valve) and the pilot light heats it up. It creates electricity after it heats up (which is why you have to hold the pilot light knob down when lighting) and opens the gas valve to keep pilot light lit after you let the pilot knob go back up. When it stays lit without having to hold it down, (make sure the thermostat is set low so it doesn't light the burner while you have your hand down there) then you turn the pilot knob to on. It should stay on and you can set the furnace to heat and raise the temperature where you want.
Dec 09, 2013 | Heating & Cooling
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
When you light the pilot, it stays lit, then you turn the the temp up on the thermostat, once it reaches its heat level and the cooking is done, turning off the thermostat also kills the pilot everytime,...
Thermopile generates 500 to 750 milli volts when heated properly, this small amount of electricity is used in energizing pilot and main valve coils of the gas valve for pilot and burner operation. Since the current is so small, it will not be able to flow on loosely fitted wire terminals or connectors, better check for this and tighten all wiring connections.
Also check if the gas pressure meets the standard pressure stamped on the unit's nameplate.
Jun 15, 2011 | Imperial IFS40 Deep Fryer
Im calling for heat from the thermastat and control panel, the boiler light and and the fan is running, but no matter how many times i keep re trying the pilot and burner will not commence, is there...
I would check to make sure control on gas valve is in on position and pilot is lit if you have a standing pilot. If you have a spark or hot surface ignitor make sure they are trying to lit pilot. If you have standing pilot model and pilot lit is not on. Turn control on gas valve to off,wait five mins. then turn to pilot. Depress botton and try to light pilot. If it lights hold down for a couple of mins. then release.. If pilot stays lit turn control to on. If thermostat is calling for heat this should bring main burner on. If pilot does not stay lit then replace thermocouple. Hope this helps. Thanks
Nov 16, 2010 | Heating & Cooling
My living room gas heater will not stayb lit
Try replacing the thermo coupler.There should be a little bulb shaped part(like a pencil eraser) that the pilot light heats up .The other end screw into the gas valve.If this is going bad or has gone bad the pilot light will not stay lit.Most of these are under$10.Well good luck and try to stay warm.
Feb 02, 2010 | Grilling
Pilot light will stay lit Lennox G8D2-82
You may need to replace the Thermocoupler. It screws into the gas regulator and the sensor end is set in the flame of the pilot light. You can get one at any appliance parts store. The Thermocoupler simply feels the heat of the pilot light and sends a very small amount of voltage to the gas switch that opens when your thermostat calls for heat. If the pilot light isnt lit, no voltage from the sensor and no gas can be released by the regulator.
Anyone can replace one. Just find the tip that sits in the the pilot flame when you try to ignite the pilot light. Follow it down to the regulator and unscrew it. There is no gas involved. It is Ultra Low Voltage. No danger.
Be sure to turn off the power to the unit before you begin removal. Take it to the parts store along with your furnace brand and model number. If you see any identifiers on the regulator, note them and take them with. When you replace it be sure to have the sensor end up in the flame of the pilot.
Sep 29, 2009 | Heating & Cooling
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
Temperature flux
may be your regolator not working properly. to check it u can use another applience or change it.
Hamid
Aug 11, 2008 | Imperial IFS40 Deep Fryer
Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
Nov 17, 2007 | Ovens
Pitco Frialator 35CD Deep Fryer Logo
485 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Paul Carew
Joe Palazola
ray gallant
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
