Question about Sony KV-32S26 32" TV
Power surge knocked out my pic and sound
My sony KV-32xbr70 has had this happen twice before. It seems when there is a power surge it knocks out the pic and sound but it still makes the noise it make when you hit the power button..and the power light doe come on......someone told me there is a fuse of some sort and it is a cheap and easy fix..can I do it myself? I am a remodeling contractor and can fixjust about anything...thanx for anyones help!!
    President:
  • 1,284 Answers
The noise you hear is the degausing coil and n Sony TV's they are an indicator that the main fuse is good. Your power supply has no other fuses to replace. they are not easy to troubleshoot.
Posted on Feb 09, 2007
Engine sputters accelerating seems like its missing
Sounds like you need to check your filter's there is one in the tank also.
Jan 12, 2018 | 1995 Nissan Pathfinder
Rheem RPKA-030JAZ MAKES A HARD KNOCKING SOUND
sounds like it's running backwards. possibly need a time delay in the condenser. make sure your drain line is clean.also inspect low voltage wires for bare/ chew spots near outdoor unit.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 12, 2017 | Heating & Cooling
My Sony kv-32hs240 turns on and after one hour
Sounds like you've got a short in your house electrical lines. Try using a surge protector (AKA power strip) between the power cord and wall outlet. If you've already got a surge protector, try replacing it.
Oct 29, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Powersurege damage
Anything can be repaired. But the cost can be a problem. The most commond thing to happen is the power supply gets knocked out (fixable problem), but I have seen the whole tv get knocked (not cost effective) out as well. The only way to find out is to let a repair shop look at it.
Oct 03, 2008 | Durabrand DWT2704 TV
SONY KV-27FS20 TV does not start
Only 3 things bad Flyback transfomer,bad picture tube ,shorted hori output transistor. more then likely you have a bad picture tube,ive already throwed over 20 sets out due to bad tubes.
May 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
NOTHING HAPPENS!!!!!
power supply probel, need to take to service
May 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No picture and a "whistle"
If your friend is being honest, and why shouldnt he, and the set was knocked over, I'll bet there is now a small crack in the main board. Cracks in boards due to dropping or "knocking over" usually occur next to the flyback transformer or tuner. Cracks in boards are very easy to fix so if you do not have experience working inside TV's then allow a qualified tech to handle it for you.
Sep 01, 2007 | Sony KV-27FS13 27" TV
Sony KV-32V35
Could be a problem in the shutdown circuit,in the HI Voltage detection circuit,or the flyback transformer. If your not a tech, you shouldnt be experimenting by adding parts as its going to knock you against the wall if it bites you. You should start out with a service manual and check the voiltages as now thinking it could be the power supply voltage regulator also. Please call a pro to assist you with this repair. Good Luck
Aug 02, 2006 | Sony KV-32V35 TV
Sony KV-32S26 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
