Question about RCA R52WM24 52" HDTV Projection Television
Where can I purchase the FL231 fuse? - RCA R52WM24 52" HDTV Projection Television
    Genius:
  • 1,030 Answers
Union electronics or just google. rca part # 259213
Posted on Dec 04, 2008
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
Does the rca 52950 have the fl231 fuse? If so where is it located? If not which fuse controls the convergence. I fixed my newer model tv with the fl231 fuse but I dont see it in this tv.
no the fl231 fuse is only for model itc222 rca's . these older set unfortunately do not have that fuse convergence is contolled by a sepreated cuircit board. also these set have no stk ics that are common for most set that control convergence. it uses a series off transistors.
Jan 03, 2011 | RCA P52950 52" Rear Projection Television
R52WH74 FL231 FUSE
You will need to replace FL231, DL231 and CL230 you can get the parts at the following link with free instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jun 07, 2009 | Televison & Video
FL231 Fuse Location
the fl231 fuse is a small rectangular fuse tan or brown in color. located on the deflection board next too what is known as a flyback transformer. this is a large black componet with two wires coming from the top. one large red one. it looks sort of like a dristibitor of a car ... too the right there is three small rectagular parts these are fuses the one in the middle is the fuse
Apr 04, 2009 | RCA HD52W59 HDTV Projection Television
RCA model P61950
fl231 is the convergence fuse, and is soldered to the board in proximity of the convergence ICS, on RCA rear projection TVs.
If
fl231 has blown, TV usually does not turn on at al, if you get bowed picture, that means that the convergence ICs must be replaced.
The fuse is on the same board where you find convergence ICs, if the fuse had blown, or the pico fuses at the base of the STK convergence ics had blown, the STKs must be replaced.
There is need of purchasing the service manual to do the job.
The repair shuld be done by a technician.
This is the convergence IC, model may vary:
Dec 13, 2008 | Televison & Video
Rca 52 fuse blown
Convergence Fuse FL231 400ma. Go to website http://servicemanuals.vstore.ca HAPPY NEW YEAR!
Dec 05, 2008 | RCA D52W23 52" HDTV CRT TV
Fl231 fuse compatibility
yes, thats the replacement fuse for your set. However unless you have replaced the convergence power supply also chances are the fuse will blow again, as the power supply shorting is what causes the convergence to get out of alignment and it will then blow FL231 thereby removing the convergence option from the menu.
Sep 02, 2008 | RCA HD52W59 HDTV Projection Television
RCA fl231 fuse
www.vancebaldwin.com has them they are RCA part number 259213 they are a 400ma 125v fuse.
Jul 17, 2008 | Televison & Video
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
106 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
