Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker trap door, ice will not come out, gets clogged in door
There is not enough pressure from the ice to open trap door.
Thanks,
Mike
Why does ice cube door builds up with ice
Posted on Feb 05, 2010
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
Tip
Hot point side by side with ice maker
My Hot point side by side has water and ice dispencer, when we use the ice maker the trap door stays open we have to close it by pushing it with our finger. We tried some lubricant on the hinges still stays open. We were wondering if there is a solinoid that acuates the door closed.
on Apr 30, 2008 | U-Line CO2075F-B Echelon Refrigerator Ice...
Wsf26c2exf ice maker not making enough ice.
CHECK THE WATER PRESSURE AND FILTER,ICE MAKER PROBABLY IS NOT GETTING ENOUGH WATER,ALSO CHECK IF THE FREEZER HAS A GOOD TEMP 0 TO 10 DEGREES..
Jul 05, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not making ice. There is no jam and all swithes are in the on position. I think a hose has disconnected, where can I find the hose to check it
Icemaker not working: Check the shutoff arm, the shutoffarm fails to move upward when the ice bucket is full. Check the water pressure. If thereis not enough pressure, the ice maker will not have enough water to make ice.Ifwater flow pressure is good, check solenoid valve activate and also it'scleaned. Locate your ice maker, remove theice bucket. Pull the cover off the end of the ice maker. Locate the holes "V"and "L". Take a paper clip (jump clip) and tape. Straight the clip and put tapein middle. Hold the taped side and insert the clip into "V" and "L". This sendsthe power to water valve. If water goes into ice-maker, water valve is good. Ifnotreplace solenoid. Check thefreezer temperature. The proper freezer temperature should be around 5 degrees.The warmer it is in the freezer, the more difficult it is to make ice. thanks,helpful?
Mar 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker won't make ice
First make sure there is a water line connected to the unit and the valve is on. Second, make sure the selector located on the side of the ice maker is in the down position.
Another thing you can do, pull the fridge away from the wall so you can get behind it. If there's a filter installed; turn off the water valve and open the line before and after the filter.
There will be residual pressure in the line after valve is turned off. if you open the line before the filter and pressure is releived with a little spurt of water...reconnect the line and turn on valve; which will build up the pressure again - turn the valve off; and open the line after the filter...no spurt of water means the filter is clogged.
Bypass or replace the filter.
Hope this helps,
Mike.
Nov 17, 2009 | Hotpoint HSS25GFP Side by Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Ice Maker Trap door may be broken
I am having the same problem. My husband took off the front panel and we discovered there is a small piece of plastic holding the ice dispenser door in place that is broken so the door doesn't seal.
I called Sears to see if the part is replaceable -- it's not. I have to buy an entire freezer door for $464 because a .10 cent piece of plastic is broken.
This seems to be a common problem. My refrigerator is only 3 years old. Perhaps we need to make a complaint to Sears/Kenmore together.
May 14, 2008 | Kenmore 53642 / 53644 Side by Side...
No Ice
Clogged filter?
On most ice makers, if the water pressure drops too low, the valve will not open to fill the ice maker.
Frozen water line?
On some units, the water line supplying the ice make can freeze up preventing water from getting to the ice maker.
Freezer cold enough?
Are you sure of the temp inside your freezer?
Place a small thermometer that can register temps around the freezing range. (example of a thermometers not to use are: a candy thermometer or a thermometer used to take a person's temp.) If you do not have one or do not want to purchase one, put a bowl of water in your freezer. If the water does not turn to ice in say 6 to 8 hours, your freezer is not cold enough.
Feb 21, 2008 | Refrigerators
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Nov 07, 2006 | Sub-Zero 690 Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
194 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
