Question about Splendide 2100 Vented Washer-Dryer
Not a problem more a question
We recently purchased a mororhome with a splendide 2100, works just fine. my question is does this machine have some sort of lint filter that has to be delt with after use the same as the domestic machines I am used to? It makes me nervous to think that there is a huge ball of lint building up somewhere.
At the bottom of your machine in the front there is a panel that will pull off. It runs the width of the machine and is about 3" in height. Just pull and it will come off. Under this panel is a lint filter that is behind a screws off front,( it is round, about 3" ). Be sure to put a towel under it before you unscrew it as it will drain some water. Pull the lint tray out, clean, put vaseline on gasket before reinserting. Be sure to tighten so it doesn't leak.
Also, if it is vented to the outside, reach into the dryer vent from outside and check for a lint build up. If the lint is allowed to build up and is not cleaned out it will slow down your drying time, also it could cause a fire if it got too hot.
Posted on Dec 15, 2008
CAN you use the all in 1 detergent and softener pods in this machine?
PUREX makes a sheet that contains detergent and softener. I cut them in half to use in the RV. It is perfect for a combo.
Sep 01, 2012 | Splendide 2100 Vented Washer-Dryer
Where can I find parts for the Splendite Washer/Dryer unit model WD2100
westland sales splendide parts ordering and tech support 800 356-0766
Mar 13, 2010 | Splendide 2100 Vented Washer-Dryer
We bought a used motorhome with a Splendide 2100 w/d combo. It does not dry the clothes, but washes fine. There was no manual on this appliance, so don't know how to find out the problem. Can you help?...
Your heating element could be out. This could be just a bad element or if you don't hear the fan come in the the dry cycle, the fan probably failed and caused the element to burn out. If your clothes are getting warm but not drying completely then you need to check your exhaust hose and make sure it is not clogged with lint.
Jul 13, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 vented washes clothes just fine but now when it goes into the dryer mode just roates the knob around without doing anything. This only happens in the dry mode.
This means that the washer has found something wrong and it is going to a diagnostic mode. When the knob starts going around, immediately begin counting how many times the red light blinks. Call Splendide and they can diagnose the error from the number of blinks you counted. I would recreate the problem more than once so you know that you counted right.
Jul 07, 2009 | Splendide 2100 Vented Washer-Dryer
Hose replacement
yes , I recommend stainless hoses because they will not break.
Phil
Jun 10, 2009 | Splendide 2100 Vented Washer-Dryer
Doesn't completely dry clothing
Make sure lint filter is clean and vent pipe and outlet are not clogged.  If the clothes are getting warm then the element is working.
May 30, 2009 | Splendide 2100 Vented Washer-Dryer
Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
Jan 27, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Aug 24, 2008 | Splendide 2100 Vented Washer-Dryer
2100 Splendide
The cycle knob rotating means the machine is in self diagnostics mode. You need to count the flashes that the led is giving, they are in 1 second intervals then repeats after a 5 second pause. Mine had 13 flashes and after contacting Splendide they say it was either a broken wire or a bad ETC sensor. With the help of a Ohm meter it turned out to be a broken wire. Mine is a 2100 vented by the way.
Jan 13, 2008 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 Vented Washer-Dryer Logo
182 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
