Question about Goodman CPLE24-1 Air Conditioner
Erratic goodman GMPN 100-4
My 8 year old furnace fan sounds like it is stuck or binding (had a problem like that with twin furnace for first floor)
This unit heats the second floor of a small comm.space.
Heat will run for a while, then fan will hum and furnace stops. If I kill power for a half hour and restore, it fires up fine, then repeats problem.
Any thoughts?
Thanks
  • 96 Answers
Sound like you have a bad fan motor
Posted on Dec 04, 2008
I have a goodman gmpn 100-4 furnace that gives off a puff of flame when it lights
remove burners and dump out rust and dust then put burners back in and restart gas preassure in burners blocking burner ports with rust and dust
Jan 04, 2013 | Goodman GMS90703BXA Heater
I have a Goodman GMPN furnace and the motor that runs the twin blowers has quit. How do I take it out and replace it?
Sorry to read about your problem, I hope this helps you out.
i suggest you call a service company.. you may replace the motor and have a control relay problem
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Heating & Cooling
If you mean the blower wheel, I wonder how you diagnosed this problem so you were 100% sure the motor is bad. I recommend to make sure of the diagnosis before spending to buy parts.
The blower wheel is shaped like a twin blade. But it's only one wheel.
However, to answer the question; Step one is turn the power off.
Then; Find the blower housing in the lower compartment on an upflow configuration.
  • Remove 2 screws on the blower housing, on the upper inside of the blower compartment to slide the blower housing out.
  • Disconnect blower motor wiring at the harness and at the control board if connected. You can cut them if you have exact replacement motor and wire nuts.
  • Slide the housing out, turning it on the side that exposes the motor.
  • Remove the 3 mounting screws holding the motor to the housing.
  • Loosen the lock nut holding the fan blade (wheel) to motor shaft.
  • Slide motor and shaft out and away from the fan blade, as they are connected together and cannot be separated. Use penetrating oil SPARINGLY.
Installation is the reverse of the removal instructions.
IMPORTANT. Make sure to leave equal space between both sides of fan blade and housing when re-installing the wheel.
Luck to you. Let me know how that turns out.
Russ
myairfixer@gmail.com
Dec 23, 2010 | Goodman GMS90703BXA Heater
Ihave a goodman GMPN furnace. The blower will not work, even in the fan on position. If I put in heat position, the burners ignite, but goes out. The module blinks 4 times showing open limit. The blower...
Maybe not! there is a limit switch that has opened not allowing power to pass and start the furnace. You will need to tale a Ohm meter and follow the wires thru any safety switch. In your case, it may be the thermo-disc near or over the burner box. Jump it out to test it. Now why is your blower not working (which could have been the reason why the thermo-disc opened)? Once you find which safety switch is open and you have jumped it out, take a jumper wire and jump between the R and G terminals on the circuit board. This should start your fan. If not, either the fan is stuck, the fan motor is bad or hopefully noy; the circuit board is bad.
Jan 18, 2010 | Goodman GMS90703BXA Heater
GMPN 100-4 furnace. Blower motor runs when not calling for heat.
The board is bad. The unit thinks a flame is present, so it tells the blower to come on. Replace the board.
Oct 07, 2009 | Goodman Heating & Cooling
I have a goodman gmpn 100-4 REVB furnace that will not stay lit
If the igniter lights the burners the ignitor..... is not bad. Its like a light bulb.... it works or ot doesn't.
You are describing a dirty flame sensor. Dishonest contractors will sell you a new ignitor but clean the flame sensor when the are installing the ignitor. It is located at the opposite end of the burners than the ignitor. It has one wire going to it. Remove it and clean the rod with a piece of fine grit sandpaper. this should be done every year before heating season.
Good luck
Mar 28, 2009 | Goodman GMS90703BXA Heater
GMPN goodman furnace: Water leaks from the base.
Check the drain tubes inside the furnace. There may be a loose connection or a split tube.
The unit could also leak from the gasket between the secondary heat exchanger and the vent fan housing. The secondary heat exchanger ould also be leaking or cracked.
Hope this helps.
Matt
Jan 08, 2009 | Heating & Cooling
Goodman furnace
sounds like the fan switch in the furnace is coming on and off. This is common for Goodman. or could be the heat anticipator on the t-stat. While there are several reasons this happens these are the most common.
Guy
Oct 29, 2008 | Heating & Cooling
GMPN 120-5 FURNACE
If you want some help on this I will need some more info. Does the unit shut off completely? does the fan run after the burner shut off, or is off simultaneously? do you have a digital thermostat or the old type?
Dec 01, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
190 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
