Question about Dryers
I have a KitchenAid gas dryer that won't heat; Model # KGYE650VALO. How do I troubleshoot this so that I don't replace unnecessary parts? Where can I get a repair guide; preferably online and free?
5 Suggested Answers
SOURCE: gas dryer will not heat
The dryer will not heat i check the vent to make sure no upstruction and open the back to make sure no wire was lose. where will the fuse be kenmore model 76722697 serial No. 0702383
Posted on Jan 18, 2008
  • 117 Answers
SOURCE: Dryer spins but does not get hot
The problem could be a faulty component such as the timer, heating glow bar, gas coils, safety or operating thermostats. First thing to do is to check the venting to make sure it is not plugged. I cover that more in detail if you wanna check it out.
http://tclaundryrepair.com/dryer
Posted on Feb 26, 2009
  • 5 Answers
SOURCE: Dryer won t heat 100 74732400 model
dryer element. Common problem easy repair.
Posted on Jun 07, 2009
erpaalai
  • 999 Answers
SOURCE: Gas Dryer isn't producing any hot air or heat
Sears will not tell you before they come. It will be over $150 when they come out. There are several possible parts, Thermal fuse, ignitor, thermostat, coil on the valve. Verifying voltage to the valve will tell you where to look next. If it is a thermal fuse then what caused it to blow needs fixed or it will just go again.(over heat due to restricted air flow or stuck thermostat). You should be able to get the parts for under $50.
Eric
Posted on Jun 20, 2009
  • 512 Answers
SOURCE: Kitchenaid Gas Dryer will not heat. Model
Sound like the therm switch under back cover. They are small round and silver with wire on each side, also one is white around 2 inches long with wire attached to each side. check with a tester to see if good, if not jump from one side of wire to other, plug dryer back in and turn on, if it works change switch, this should solve your problem, cheap easy fix.
Posted on Jul 03, 2009
Kitchenaid gas dryer won't ignite and heat. Everything else seems to work fine -- drum rotates, timer works, just no heat. Model# KGYL517BWH1.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | KitchenAid Dryers
Doesn'theat the air - I guess it may be the element. I took the covers off to have a look but I don't want to unnecessary dismantle parts. What does it have to comes off to get to the element?
heatman101
Aug 01, 2011 | Dryers
Kitchenaid gas dryer model # kgye800swh1 starts, but does not heatup
heatman101
Jul 04, 2011 | KitchenAid Dryers
The drum turns and the dyer blows air. It does not light, when I took it apart the ignitor does not come on. We replaced our gas coils about a year ago. what do you think might be causing the...
heatman101
Apr 26, 2011 | KitchenAid KGYS850LT Gas Dryer
Kitchen Aid Gas dryer KGYE664WWHI does not heat up
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at http://appliancehelponline.com/gdryertroublevideo.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Aug 03, 2010 | KitchenAid KGYS850LT Gas Dryer
Dryer will dry one day and will not dry the next.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 04, 2010 | KitchenAid KAWS850L Dryer
My dryer runs, but does not generate any heat. Is
heatman101
May 31, 2010 | KitchenAid KEYS750LQ Electric Dryer
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
KitchenAid Gas Dryer wont heat everything else
Does the dryer heat at all? turn you dryer on for about 1 minute then open the door, any heat? yes= check to be sure you venting is good and clear. if good then you have 2 common issues i would check first. the thermal fuse could be blown or the gas valve coils could be bad. give me you model number and i can give you more suggestions of what to check and how
Mar 22, 2010 | KitchenAid Dryers
No heat in dryer
heatman101
Mar 04, 2010 | KitchenAid KEYS850LQ Electric Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
