Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
2 Wire 802.11g wont stay connected
Have a 2wire 802311g p/n1000-00023-000 an older card. got the drives from 2wire.It will work fine for about 2 min. or fust enough time to get to where tou may want to go, and connectionis lost. box comes uo saying 2 or more location found. i can see my netgear a liksys and others but wont connect to any!!! Have to unplug and pugin the card on the laptop, it finds it a connection, connects to it, then drops it. tried using other dirvers from 2wire but no luck eather wont see the driver or same thing happens. runing xp. thks for any help.. rob
Hi, had the same prob. I was able to fix it. The file set you downloaded for the driver (TWWGPC_TEMP) has a file in it called Wireless Cfg, run that if you haven't already, that will configure the card. Then open the folder CMG and run the Setup file. This will install the Wireless Client Card Utility. In the utility add the network(s) you connect with to My networks. After I did that the intermittency of the connection went away. I hope it works for you too.
Posted on Jan 12, 2009
I have a 2wire modem from att. i made a 50 foot eathernet cord, i have a eathernet transmitter teaster to test the cable to see if it is good (and it is) but i still cant get internet on the other side of...
Try with a shorter enet cable and see if you get internet, if you are able to get internet with a shorter cable then the cable might not be working fine. Else get a wireless card installed on your computer since the 2wire modem has wireless connectivity. It would be more easy and convenient to connect to wireless using the 2 wire modem.
Jun 24, 2010 | 2wire (1000-000057-000) Modem
Xbox 360 wireless adapter wont connect to my 2wire
Have you tried removing all security protocols on the 2wire and trying to connect?
Good Luck!
Jesse
Jan 05, 2010 | 2wire HomePortal 1800HG Router...
My adapter wont stay connected
look for latest drivers. visit www.driverguide.com. free registration is required.
Dec 09, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Purchased linksys router, have 2wire wireless but no cd
go online and download the wireless card driver to the computer connected to internet. then run the software in your computer and after you will be able to connect.
Aug 30, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
2WIRE Router, Belkin Card, and 10 vs. 13/26 digit encryption key
I would give you two options
1. to change ur wireless key to fit to this card
2. u can still let windows configure wireless for this card as well
However would like to have a clearer report about the problem
Jul 05, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
I cant connect my 2 wire
Try going to the 2wire website ...
http://support.2wire.com/index.php?page=download
Not sure from your post if your using the adapter or their gateway.
Apr 18, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
2 wire modem power problem
check your modem power cable for any loose connection.
Nov 06, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Can i connect a 2wire 2701hg-b with roadrunner cable internet ? I had the 2wire dsl with at&t but recently disconnected the service
It is possible but it may not work as a router (2 wire 270). The 2wired router only has a phone port and ethernet/usb for computer connection. So if you will connect the roadrunner modem to the 2wired, you can connect it to the ethernet port of the 2wire, but the 2 wire will not function as a router any more. It will work just like a wireless bridge. This one setup that you can.
May 02, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Occasional reboots
i too have found this problem with the 2 wire 2700 and found that if the router tries to alter the connection speed and finds it cannot connect at the faster speeds it has to reset itself to revert back to a slower connection speed, so keep an eye on your connection speed which can be found in the routers settings on the initial page and check if the speed registered is faster than that of which your line can carry, if so then you need to contact your isp.
Aug 31, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
193 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
