Question about Mitsubishi WS-55809 55" Rear Projection Television
PICTURE LOOKS BOWED OR ARCHED - Mitsubishi WS-55809 55" Rear Projection Television
  • anycom Dec 20, 2008
    You neeed to mess with the aluminum heatsink type piece in the back on the inside usually pushing down on it works and it looks like new!!!! let me know
Had same problem with ours. We had to replace a "Heat Sink".
Posted on Dec 08, 2008
My 52 inch rca hdtv comes on but it looks like the screen is bowed and the colour is you know of any solutions to this problem.
My rca 52 inch hdtv picture looks bowed on the top and bottom of screen. And everything looks like it has a red shadow behind it.
May 12, 2010 | Televison & Video
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture is distorted, double vision, looks like 3d.lines are arched or curve. colors don't line up. screen is bowed or warped. its a sony kp- 57ws600, 57 in. rear projection television. can you help me...
Try going into the video section of your menu, and pressing RESET on your remote control. If this doesn't fix it, try your quick start guide for setting the convergence and focus.
May 17, 2009 | Sony KP-57WV600 57" Rear Projection...
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Looks 3D
I had a repairman replace the convergence boards. The picture is fine now however red & green colors are messed up.
Nov 11, 2008 | Samsung HCN653W 65" Rear Projection...
Color distortion and arched picture
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
Oct 31, 2008 | Sony KP-51WS510 51" Rear Projection...
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Arched picture on Sony KV-34XBR800
Your TV has problem in Pin-Out area. I know its technical term but I have no other words to explain it. TV needs qualified technician to fix it.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Convergence out of addjustment
You need to get a service tech for that problem,it might need new amps for the convergence and then adjustments that only can be done from the service menu.
Aug 30, 2006 | Mitsubishi WS-65908 TV
Mitsubishi WS-55809 55" Rear Projection Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
