Question about Hotpoint NVL333EY Electric Dryer
Sounds as if you have a bad bearing, guide or drum slide. You need to take the drum out and check these components. Go to GEappliances.com and look up the your model number and pull up the diagrams.
Posted on Jan 06, 2009
SOURCE: whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool
dryer to be noisy.
To find out what is causing the noises, you
need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to
pinpoint where in the dryer the noises is coming from. Once you have
an idea of the area, you will need to disconnect the dryer from the
wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your
dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of
the drum, in other words, the baffles job is to separate the pieces
of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot,
the drum baffles holding screws will become loose. Loose drum
baffles will cause noises. All you need to do, is to open the top
panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the
front and two on the rear. The job of the drum support rollers is to
keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start
to make squeaking noises and the roller bearing will start to wear
out until the bearing on the roller is gone. When the bearing on the
roller is gone, the noise will change from squeaking to a clanking
noise.
The blower wheel:
The blower wheel is use to circulate the air inside of
the dryer drum. The most common Whirlpool blower noises are cause by
something falling inside of the blower housing and hitting the
blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on
the belt. There are two types of idler pulleys, the pulley with the
wheel and the pulley with the teflon slide. A bad idler pulley could
cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to
run kind of noisy. When the motor starts making noises, the solution
to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These
belts work very hard making the drum tumble. When the belt stretch
just 1/2 inch more that it supposed to, the belt will start slipping
and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become
noisy in your dryer. When your dryer starts making noises, make sure
to check it out before it gets worse.
Posted on Feb 09, 2009
SOURCE: ge dryer makes grinding noise when drum is turning
If youve made sure that its not a roller thats dry or a belt idler pulley that dry,than yes its the motor,and oiling that will only make it worse.
Posted on May 21, 2008
SOURCE: My hoover tumble dryer hnv
TheOsteopath is a pure genius - have had an increasingly noisy hnv 380 and was about to get the yellow pages out for an expensive repair (or replacement) but followed the instructions to the 't' and it works perfectly. Many many thanks. You've saved my pocket and my eardrums. JS.
Posted on Jun 28, 2009
SOURCE: my whirlpool cabrio electric dryer makes grinding noise
could be a bearing gone
Posted on Mar 27, 2010
SOURCE: Hello I have a Samsung dryer model # DV337.Today I
When you pulled the lint filter something may have fallen into the blower which is just below the filter. Use a flashlight to try and see down the chute, if you cant find what is stuck there, you may need to call for service to disassemble the dryer to remove the object so it does not destroy the blower.
Posted on Apr 19, 2010
Apr 14, 2014 | GE Dryers
Jan 26, 2014 | Whirlpool Dryers
Apr 26, 2010 | Maytag SDG3606A Gas Dryer
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
Apr 21, 2009 | Estate TEDX640JQ Electric Dryer
Mar 22, 2009 | LG DLE3777 Electric Dryer
Jan 27, 2009 | Maytag Dryers
May 20, 2008 | Dryers
Feb 01, 2008 | Kenmore 63942 Dryer
100 people viewed this question
my whirlpool cabrio dryer makes a funny grinding noise when i turn it on
