Question about DeLonghi BCO120T Programmable Espresso / Coffee Maker
Delonghi BCO120T Drip coffee portion not working
On my Delonghi BCO120T combination coffee and espresso machine the drip coffee has stopped working. When I press the drip button to start it the button just flashes. Any idea what is wrong? I have had the machine for only a week and it has been working fine and then this morning it just wouldn't work.
  • Anonymous Jan 08, 2009
    Mine doesn't work either. In the manual, it says if your red light is blinking, you need to clean the lime out by descaling your machine.
    My light stays red...
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
  • 1894 Answers
SOURCE: Describe your DeLonghi BAR 32 Espresso
i think your thermostat is dead
have u check it out?
Posted on May 15, 2008
  • 199 Answers
SOURCE: My coffee maker won't brew the coffee. Mr.Coffee GBX25
you tube is clogged pour in 2 cups of vinagar an brew this will eat away the calcium deposits. in your coffee maker if you water is hard where you live you may want to by distilled water or use some type of filter or water softener
Posted on Jun 23, 2009
EsWorld
  • 1618 Answers
SOURCE: Water goes directly to drip tray instead of to the brewing head.
Thr coffee grind is too fine, adjust or try tamping lighter.
Posted on Aug 06, 2009
  • 5 Answers
SOURCE: DeLonghi BCO120T coffee maker side does not work.
TYPICAL FAILURE OF THIS MACHINE = THERMAL FUSE MALFUNCTION.
WHERE ARE THE THERMAL FUSES: There are 2 thermal fuses under the coffe tray and 1 fuse under the espresso boiler. (YOU WILL HAVE TO REMOVE THE BOTTOM COVER OF THE MACHINE). What this fuse does is regulate the temperature of the heating element so that everything doesn't melt (yep, I tried to bypass the fuse and found out the hard way..testing...testing..). Anyway, replacement for these thermal fuses are sold at RADIO SHACK for about $2.00. (Yep, only $2.00) If you open the bottom cover of the coffee maker and you will see the 2 fuses, they look like resistors. they are covered in a plastic tube to prevent damage. Clip them off I used a small wrench(radio shack) to pry open the small clamps that hold them, replaced them, then reclamped the new fuse back on.
REPLACEMENT FUSES: The thermal fuses have the watts/Amps and temperature stamped on them. There is 1 part that I use and has been working well for over a year ( over a year, yes this machine can last a long time!!).
The part # is Labeled - Raido Shack 270-1321 Thermal Fuse 438°F (226°C) 250VAC 10A (For heating devices like coffee makers and hair dryers). The temperature may vary + - a few degrees° on the label, from what I have seen.
HOW TO TEST THERMAL FUSES: These fuses are not only used for temp control but they also close the curcuit. If the fuse blows then it is open and will not heat. I use my ohmeter (put 1 prong at each end of the fuse) and if it reads open it means that the thermal fuse is bad, it has blown, there is no current running through it. I believe a light meter can check for continuity also and are much cheaper. Test by putting the test leads at each end of the fuse (1 prong at each end).If the light turns on then you are good, getting continuity. If you cannot get no light then it is bad. You can test your light fuse with a simple wire, touch each end and the light should go on, cut the wire in the middle and no light!!easy.
fyi. If your coffee does not get hot enough the fuse may need to be replaced also.
HOW TO READ THE OHMETER.
Know that a reading of OL means "over limit." That means the resistance is off the charts, and you have a break in the circuit. If you got an OL reading for the plug wires, you'd know there was a broken wire that needs replacing. In this case, we got an OL reading because the light switch is in the "OFF" position.
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwX1LcJD
Consider that a low reading, anywhere from 0 to .5, indicates very little to no resistance. This means there's a continuity of current in the circuit. This is the reading you should get
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwXjz6C0
Posted on Sep 30, 2010
Delonghi combination coffee/espresso machine
Depending age of coffee maker, it may need to be cleaned with vinegar or it may be plugged. Use a pipe cleaner or something small to clear tube.
Sep 09, 2016 | DeLonghi Coffee Makers & Espresso Machines
Espresso part is working, hot water/steam draining into drip tray.
I had the same problem on my Delonghi ESAM3300; you need to replace the "Tap" #7313216621 you can buy at eReplacementParts.com and search on how to install on Youtube. Its easy. No more leaking. Good luck
Oct 07, 2015 | DeLonghi ESAM3300 Magnifica...
How to make the clock/drip coffee maker work. The display does not turn on anymore.
DeLonghi BCO120T Programmable Espresso Coffee Maker Team De-Brewerz.com says:
1. Your coffee maker PC board/display might get fused or blown off. You just need to replace the PC board.
You can claim the warranty if recently purchased through www.De-Brewerz.com. If you are in India then contact us at de.brewerz@gmail.com
Nov 03, 2014 | DeLonghi BCO120T Programmable Espresso /...
Pressing the green button to make coffee. machine made strange noise and stopped. Now I can't remove drip tray and everything seems stuck.
Remove the power chord an plug it in again. This shoud seht the machine into starting position.
For details see www.cofffeemakers.de
Regards Fred.
Jun 26, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Is it possibe to purchase this coffee maker in azure blue
You can buy DeLonghi products on their site. That said, I am not sure this product exist in blue.
Apr 30, 2010 | DeLonghi BCO120T Programmable Espresso /...
How do i decalcify the unit?
de-scale solution available from most coffee machine retailers.
Sep 19, 2009 | DeLonghi CAFE DUO Dual Drip Coffee Maker
DeLonghi BCO120T Programmable Espresso / Coffee Maker Logo
322 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
