Question about Kenmore Washing Machines
Can't separate the pump from the motor on my Kenmore HD 80 Series
I removed the hoses and the two snap-clips from the pump, but cannot sepatae the pump from the motor. Should the pump simply lift off? Is it because of the leak I have in my pump that has caused some rust on the motor shaft that is preventing the pump from being removed?
    Genius:
  • 1,028 Answers
Best solution remove screws holding clamps to motor remove motor wire and clips take complete assembly of and try tapping pump off with hammer being careful not to hit motor area around shaft when reinstalling pump clean motor shaft of as musch rust as possible do not tap new pump on shat if willo not push on by hand sand some more yes leak caused problem
Posted on Dec 05, 2008
How do I remove the back of the machine on a Model #11026892690 Kenmore 80 Series Washing Machine to change the belt?
don't touch the back,there isn't a belt in kenmore washers and don't touch the back panel,there are white covers on each side of the top panel,pop them off and remove the two phillips screws,one on each side,then flip the panel up,with a screw driver pop the two metal clips,just stick the screw driver in the hole and on top of the clip and push back to the wall and the clip will repease,now in the middle of the clips you'll see the lid switch connector,separate it,open the lid and grab the frame,tilt it up and back at you and remove the frame,on the bottom you'll see the pump,remove the two clips and pull off the pump,then remove the two screws and pop the two clips and slide out the motor,on the back of the motor you'll see the coupling,that's what broke,you need to replace the motor coupling
Oct 30, 2010 | Kenmore Washing Machines
My kenmore 80 series will not spin or drain
You probably have a jammed water pump. The pump won't let the motor turn, so the washer will not spin either.
Vacuum out water.
Pull the two screws holding down the control panel, tilt the panel up and back out of the way.
Lever the metal keepers out with a screwdriver.
Unplug the wiring harness on top of the housing.
Rotate the housing forward and pull out.
Pop two clips holding on pump.
Hold pump over bucket, remove from hoses using pliers on clamps.
Remove debris from pump (needle nose pliers).
Reassemble and test.
Nov 19, 2009 | Kenmore Washing Machines
I have a Kenmore washer #110 92380200 that will no longer spin or
STOP STOP if you lay it on the back watch the drain hose you will see the pump 2 clips..undo by sliding clips over edge take hoses off pump and remove pump.unplug motor connector plug wires 2more clips hold the motor but they have screws in them you need to take out push them off then pull motor out change coupler PUT THREE BOLTS IN TUB BACK...
Aug 05, 2009 | Kenmore 23822 Top Load Washer
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Leaking Model 80
Hello Friend, Yes, I'd say your pump is leaking. Sometimes these pumps wear out a circular shaped hole in the front of pump housing but most of the time the rear seal on the pump goes bad and leaks from there. It's easy to replace the pump on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, you can easily remove the pump by snapping off the two spring clips. The pump will slide right off the motor shaft. Please rate my help. Happy to help, Tim.
Jun 27, 2009 | Kenmore 24032\24036 Top Load Washer
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
Will not agitate or spin
Hello Friend, Your solution is very simple. You need to replace the motor coupler. It's easy to replace the motor coupler on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, just lay the washer on it's back. At this point you will see the water pump, motor, and transmission. Remove the pump by snapping off the two spring clips. The pump will slide right off the motor shaft. Now, remove the two screws that hold the two spring clips attached to motor. Unplug all the wires etc. and then snap the metal clips off motor. Lift motor straight up, it should slide right off. Now you will see the motor coupler. Half of the coupler is on the transmission shaft and the other half is on the motor shaft. There is a rubber center connector ring that connects the two together. Just remove the old coupler pieces by prying under them with slotted screwdriver and replace with new ones. Re-assymble the washer and the problem you are encountering should be solved. Happy to help, Tim.
Mar 19, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer will not spin or agitate
This is a bad coupling, part # 285753. It is available from timerking.com for $9.99, and other places as well. To replace unplug and lay the machine down on its back, remove the 2 pump clips, and slide the pump out of the way. Then remove the 2 motor clips and remove the motor. The coupling is between the motor and gearcase. Hope this helps!
Jan 13, 2009 | Kenmore 24032\24036 Top Load Washer
Does not spin
there is a coupling between the motor and gearbox, that fails.
it is a simple repair, and well worth trying
remove cabinet
  • pop off edge trims from control console
  • remove screwss from under edge trim
  • slide console forward and up ~1inch
  • flip the console over the back of the washer, the hinges are plastic and a little fragile
  • remove brass clips holding cabint inplace remember how they fit
  • lift cabinet ~1inch and remove forward
repair coupling
  • motor gearboxpump is at front bottom center
  • remove lock screw from clip holding pump to motor
  • remove two spring clips
  • pull pump off motor and swing sideways on hoses, tie off to left with a string
  • remove lock screw from clip holding motor to gearbox
  • pull motor off rubber coupling
  • pull nylon spider off gearbox shaft
  • pull nylon spider off motor shaft
  • install new spiders to shafts. Use a hammer to strike a wooden dowel on the center of the spider, dont hit the legs of the spider they break off
    Note the new coupling spiders have metal centers to stop further breakage, common fault
  • turn gearbox spider 1 leg up two legs down
    turn motor spider , 2 leg up 1 leg down so the spiders will interlock
  • install new rubber coupling on gearbox spider, install motor on coupling.
reassemble all clips and screws in reverse order
reassemble case in reverse order
on reassemble ensure plastic level sensing hose is not dislodged from water level switch body
takes longer to type than to do the repair
at parts store "Kenmore gearbox coupling" will get the correct part
Sep 07, 2008 | Kenmore 23822 Top Load Washer
Kenmore 80 series not agitating
Most likely you have a bad motor coupler. If you open the console and remove the two brass clips, this will let the front, sides and top all come off as you tilt it forward. At the botom center, you will find two metal clips holding the pump on. Remove. You will find 2 screws holding similar clips holding the motor on. Removed. On the back of the motor, is your coupler. Replace. Then re-assemble.
Jun 08, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
51 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
