Question about Wasp WPA206 (633808504021) Portable Terminal
Backlight Failure I wonder if anyone can provide me with a contact that can repair the above device. The backlight on the lcd screen has failed. Thanks
    Novelist:
    Champion:
  • 202 Answers
Mitsui, here is the wasp home site maybe you can send it in on an RMA and get them to repair it. http://www.waspbarcode.com/default2.asp Good Luck, Tim
Posted on Feb 09, 2007
When I turn on my tv, the screen lights up for about 5 seconds then goes black
Hello, the most common problem on this set is a backlight problem. about 85% of the time it's the backlight inverter board that fails, but sometimes the CCFL tubes in the LCD panel can fail, if anyone of the 8 to 20 CCFL tubes depending on screen size fail, the set shuts down. you can find the inverter boards on ebay or shopjimmy if want to try that for under $50,,,,,thanks, Terry
Sep 20, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My laptop screen went black every thing is working but i cant see anything what might be the problem
hold the unit slihtly to a light if you can see the icons dimly on the screen then your screen has gone into freeze mode if you cant see the icons then your screen is probly blown to reset the screen from frozen it needs to be un plugged from the motherboard and plugged back in the plug is located under the panal above the keys
best luck
Oct 14, 2010 | Computers & Internet
Screen dull on Janome mc 8000
There is an LCD Backlight Panel that illuminates the screen, and yes, they do fail.
Before you start, just check the screen contrast dial inside the top cover, front right, they can be easily knocked and this will also cause the screen to go light or dark.
Janome no longer supplies the LCD Backlight, however, we have an after market replacement at our store, and also provide fitting instructions and a good deal more besides.
If you care to contact me I can send a Diagnostic Routine and the Screen Reset instructions for you to check if there is anything else causing troubles.
Please remember to give details of your dilemma as we do receive a lot of requests.
Contact Link
Cheers
Martyn
May 15, 2010 | Janome Memory Craft 5700
Power ok no display
Tilt the screen so that light strikes it at an angle
If you look carefully at the screen can you see an image in the background.
If you can then the inverter for the backlight or the backlight itself has failed
No image is the LCD
Cheaper to buy another monitor !!!
May 23, 2009 | Dell E173FP 17" LCD Monitor
The screen is black but if you look hard you can see the background very lightly
Hi, your monitor's backlight is burned out or malfunctioning. The LCD monitor consists of two major parts - the LCD panel where images are created, and the backlight which forces light to pass through the LCD panel so you can see things. Your backlight is out. Viewsonic has great warranty support and service. You should contact them, provide them with the serial number, and they'll probably repair it under warranty for you. This is a hardware malfunction, so it needs to be repaired.
May 15, 2009 | ViewSonic VA1912w 19" LCD Monitor
Back light on ibm t21
This is an known problem I think you must replace the backlight:
look for example ebay partnr: 260327530145
only for example if this is your problem.
PRODUCTS ITEMS
LCD CCFL BACKLIGHT LAMP IBM THINKPAD T20 T21 14.1" SCREEN
LAPTOP & MONITOR LCD SCREEN PROBLEMS
SOME COMMON SYMPTOMS FOR BACKLIGHT LAMP REPLACEMENT
- Flickering, red or pinkish hue to display and even total darkness. These symptoms are a result of a failed or ageing backlight or a failed, damaged. This is caused by the defective backlight lamp and all you need to do is replace the backlight.
DESCRIPTION
Our high brightness LCD cold cathode lamp (CCFL) with long life, it is more than 50000 hours, with Japanese new cathode, phosphor, glass, and other materials, they are perfect for all LCD backlight application and other purpose, such as instrumentation, medical devices, and all type devices.
COMPATIBLE MODELS
Suit for
Any 14.1” LCD Screen (2.0mm in diameter and 290mm Length) and (2.0mm in diameter and 292mm Length)
CUSTOMER SERVICE / CONTACT US
Email: mkproco@gmail.com (12 Hours Response Time)
Oct 14, 2008 | IBM ThinkPad T21 Notebook
Bose P1 - lost backlight
Bose support repaired two P1 remotes for me. The first one they did for free (well out of the warranty period). The second one in the last 18 months cost $50 for a complete rebuild, new case, etc.
Feb 20, 2008 | Bose 023795 LCD Touchscreen Remote Control
Janome memory craft 8000
We have about 30 electroluminescent backlights for the 8000 still available .These are not original Janome parts. You will need a Janome service person to install then for you as it requires taking apart alot of the machine to get to the display. We can provide instructions if this person is unsure how to fit. Once the display is out, the process is simple. They are AUD$60 each including shipping. Email at megan@christini.co.nz
Nov 24, 2007 | Janome Memory Craft 9000 Computerized...
Wasp WPA206 (633808504021) Portable Terminal Logo
130 people viewed this question
Top Wasp Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Wasp Computer and Internet Expert? Answer questions, earn points and help others
