Question about Dual Electronics CECT P168 Cellular Phone
Change clock from am to pm
I cant figure out to set the am and pm either on the clock nor the alarm>? any suggestions
It recognizes military time...but once you set it to 19:00, for example, and press save or done, then it shows up as being 7pm.
Posted on Dec 04, 2008
How do i set the Barbie Glamtastic alarm clock radio
Barbie Glamtastic Alarm Clock Radio 11765268
There are four (4) buttons on the back:
  • Mode
  • Set
  • Scan
  • Reset
Everything regarding setting dates and times is done starting with the Mode button, and using the Set button to adjust various settings.
Set Year
  1. Press Mode until the date appears.
  2. Press Set. The year will begin to flash.
  3. Press Mode until the correct year is reached.
  4. Press Set.
Set Date
  1. Press Mode until a date appears in the form of MM-DD.
  2. Press Set. The year may flash first. Press Set again. The month (MM format) will begin to flash.
  3. Press Mode until the correct month is reached.
  4. Press Set. The day (DD format) will begin to flash.
  5. Press Mode until the correct day is reached.
  6. Press Set.
Set Time
  1. Press Mode until the time displays.
  2. Press Set. The hour will begin to flash.
  3. Press Mode until the correct hour is reached. Keep in mind the AM/PM indicator in the far left of the screen. Make sure that the hour to be selected is with the correct AM/PM indicator.
  4. Press Set. The minutes will begin to flash.
  5. Press Mode until the correct minute is reached.
  6. Press Set button.
Set Alarm
  1. Press Mode until the the Alarm screen displays. The Alarm screen has an AL in the far right of the screen.
  2. Follow steps 2-6 above under Set Time (these same steps are just being done on the Alarm screen).
Turning Alarm On and Off
The left side of the radio has an On/Off dial (for the radio) at the top, and a slide selector button (for turning the alarm on and off) at the bottom.
  • Sliding the selector to the far left will result in Barbie's voice as the alarm.
  • Sliding the selector to the far right will result in a piercing noise as the alarm.
  • Sliding the selector to the middle slot will result in the muting of the alarm.
There are graphics on the left side of the clock that denote each result above.
Mar 28, 2014 | Barbie Glamtastic Alarm Clock Radio...
How do you set the time? I figured out the alarm clock but can't find a way to set up the time.
Setting the Clock
1. Press and hold the HOUR button for 5 seconds (Fig. 5). The time will begin to flash
2. While the time is flashing, press the HOUR button until you reach the correct hour. Then press the
MINUTE button (Fig. 5) until you reach the correct minute.
NOTE: PM indicator will appear on the left side of the clock face for evening hours (Fig. 5). If the
PM indicator is not illuminated, the hour is set to AM. Be sure to set the time for the correct
12-hour period - AM (morning) or PM (evening).
NOTE: After 5 seconds, the time will stop flashing and it will be set.
Mar 03, 2011 | Homedics SS-4000 Clock Radio
My alarm clock does not distinguish between AM and PM. it simply does not turn on the sign for either, so i cant tell if my alarms are set for am or pm...kind of important.
Sounds like a display problem where the indicator isn't working. This might be a bad connection or it could be the display itself or the driving electronics. In any case, it would probably cost you more than the clock radio's worth to have it repaired (assuming you find someone who'd take it for repair in the first place!).
Here's a "solution", though. Set your alarm for a time only a couple of minutes later than the current time and wait around. Depending on whether or not the alarm sounds, you'll know if it's set for AM or PM. At least you'll be able to keep using it until you decide to replace it.
Oct 06, 2010 | Memorex iWake MI4004 Clock Radio
How do I set the clock on a room tech beingz
There is a switch on the back to set time, alarm, or display time. Select the switch to time set first. Tap top of unit to toggle between settings blinking display is the one to be set. Change it bi tapping on the sides ( ) or(-) don't forget the 12 hour display or military 24hour. Switch back to clock display when hour and minute display are both blinking or the setting will not take effect
Jan 26, 2010 | Hasbro Room Tech Beingz Alarm Clock Radio...
Mossimo alarm
While in (digital) Clock mode (NOT in alarm setting mode!!!), push the bottom-right button and then the top-right, to toggle alarm on & off.
Jan 29, 2009 | Bulova Men's Watch
Good Morning. I was given this alarm clock which is driving me crazy cause i cant figure out what to do. I tried researching the internet for a manual, but failed. It is a RCA CD Clock dual wake Radio....
Following are the instructions for the RP5610 which looks very similar to the 4801A (that I also have). The only difference in the instructions is that the 4801A doesn't have a clock icon, just press the SET button until the center colon dots are flashing, Press the rewind or fast forward arrows on the circle next to it to set the time. Set the alarms by pressing the set button until bell 1 or 2 is displayed. Nap is also set with the set button - not sure how to stop it yet.
To set the clock:
  1. Press the SET button until the clock icon is displayed (circle with hands at 10 and 2)
  2. Press |<< REV or >>| FWD to set the time.
  3. AM or PM icon will show besides the time.
Dec 24, 2008 | RCA Radio Alarm Clock
Unable to set the alarm
To Set the alarm time: Press and hold the ALARM button down, and then press the hour/minute buttons to obtain desired time (Note the PM indicator on the screen for PM times)
To Enable the alarm: Move the sliding switch to AUTO or ALARM (Auto is for radio wake and Alarm is for beeping noise) *remember to turn up the volume knob if using AUTO (radio) setting.
Dec 04, 2008 | Lenoxx Electronics Clock Radio With CD...
Setting the am/pm feature of the clock
You probably have to advance the time setting until an indicator turns on to show PM time.
Mar 07, 2018 | Salton /MAXIM Westclox 114661 Meteor Black...
Sharper Image Projection US Atomic Alarm Clock (model number OQ311)
try looking up the manual on the model number you might find it online. I have the maual for this model.
Jun 10, 2008 | Audio Players & Recorders
Dual Electronics CECT P168 Cellular Phone Logo
112 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
