Question about TTX Medallion Series -8570 (White) 15 in.CRT Conventional Monitor
Grey Squares on the monitor
Hello, I am trying to use a TTX 17 inch CRT monitor (not sure which model, doesn't say anywhere, it's basically a discarded monitor from some office) along with my regular monitor (ViewSonic E90f+), in dual-view mode. I have a GE force 6600 with all the latest drivers, and my computer is an AMD Athlon 64 x2, also with all the latest drivers. my motherboard is an asus A8E-N with the latest bios. I don't know why it doesn't work because I have tried the dual-view feature with at least 3 other CRT monitors and it worked *perfectly*, at 1280x1024 resolution with 75 hz refresh. But now the problem is this: the monitor turns on, but will only display a bunch of grey squares. Then it turns off, and back on, with more grey squares but at different resolution. And it just keeps on doing that, and simply never reacts to anything I try to do from my computer, as if it's just not plugged in. When I unplug it from the computer, however, the only difference is that the squares turn white. My Nvidia property menu detects this monitor as being "TTX Digital Display" but as I said, seems to have no way to affect it in any fashion whatsoever. The buttons on this TTX crt don't do anything either, believe me, I have tried all of them, and I also tried keeping them pressed for 15 seconds each and stuff like that but nothing happened at all. i also went on the TTX website and downloaded the drivers that they have there, and installed them, but that also didn't change anything at all. So there you go, I'm completely at a loss. Should I just look for another CRT to dual-view with?
    Scholar:
  • 78 Answers
Try reducing the resolution, Since the CRT you are referring to is old monitor, it might not support high resolution.
Posted on Apr 22, 2010
Hello sir, i hav LG CRT 15" monitor. After turning on, its LED continuous blinks and power button does not work and displays nothing. so plz suggest me what should be deffect?
Any 15-inch CRT-style monitor should be replaced by a 15-inch or 17-inch LCD-style monitor. You can find "previously-owned" monitors for $30 to $50, which is less than taking your CRT monitor to a TV/video repair-shop for an *attempt* to get it repaired.
Oct 04, 2010 | Computers & Internet
Hi, My DELL 17' CRT Monitor is not getting power suppply. Please help me out for the same. Kart.
Spend $50 (or $100) and buy a used (or new) 17-inch LCD monitor, rather than "investing" $50 to $75 to pay a TV/video technician to *TRY* to fix your CRT monitor.
Sep 24, 2010 | Dell E773C 17" CRT Monitor
The monitor is blank (pale gray color). No information How can I find a monitor to replace it? The computer is a Dell Dimension 4600 series. I don't know what are the video characteristics of this...
Hello
OK, the package comes standard with a 17 inch screen(CRT). So, basically you have 2 choices, you can either buy a replacement CRT screen or you can buy LCD, these are the cheaper options available at this moment.
I would personally go for a LCD screen. the size is a personal choice, but i will not go any bigger that a 23 inch with the graphics card installed.
You will be able to buy it at almost any computer store, and it is cheaper than you think.
Please let me know if this was sufficient, if not, i will try and better explain myself.
Kind regards
Andrea
Sep 08, 2010 | Dell Dimension 4600 PC Desktop
Hello My PC monitor/CRT 17 inch. not getting
check the signal cable bend it in on condition and look what difference in color occurs if so then replace the cable if not that fault then ther is a dry solder on the base of monitor find out and clear it
Apr 05, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
I AM USING A SYNCMASTER 753S MODEL MONITOR NOW THE LETTERS ON THE SCREEN ARE NOT CLEAR (FOCUS OUT) WHAT IS THE SOLUTION
your CRT is need to be recharged ..It can be done in any electronics workshop..Its basically due to aging of monitor...
Thank You For using FIXYA!!
Dec 01, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
LOOKING FOR DRIVERS FOR TTX 9154 USB TOUCH SCREEN MONITOR
I poked around the www.ttx.ca website for you, and found the following blurb:
"A. All models manufactured after 1999 are “plug and play” compliant, therefore “plug and play” drivers supplied with your specific system will work the same as the “TTX.inf” driver found on our website.
If so, here is the link to their "TTX.inf" driver.
http://www.ttx.ca/support/Monitor_Drivers_and_Manuals.asp
Now, a closer look on that page said "CRT Monitor", and that may not be what you have. I did stumble across another of their pages talking about Touchscreen Manuals and drivers. Find that here:
http://www.ttx.ca/support/Touchscreen_Drivers_and_Manuals.asp
This page says to match the last two numbers of the product ID on the back of the unit to their chart of drivers and manuals.
Hope that helps!
May 22, 2009 | Computers & Internet
Brightness
there is two transistors in brightness section near eht so you can check all small transistors around eht
Jun 24, 2008 | TTX Advantage Series -1770 (White) 17...
Circuit diagram
i need circuit diagram of 107e61/94 model.
Feb 19, 2008 | Philips 107E61 17" CRT Monitor
Princeton CD770MCN 17 driver and or setup program
My only suggestion: responsibly recycle that 17-inch CRT, and buy a used 17-inch LCD; around here, the local "government surplus" store is selling 3-year-old 17-inch LCDs for $50, plus taxes.
If it was a "plug-and-play" monitor, then there was _NO_ need for any "drivers" at all, because the monitor would identify which combinations of horizontal/vertical pixels and refresh-rates that it would support.
Oct 27, 2007 | Princeton Digital Custom CD770MCN 17...
TTX Medallion Series -8570 (White) 15 in.CRT Conventional Monitor Logo
107 people viewed this question
Top TTX Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a TTX Computer and Internet Expert? Answer questions, earn points and help others
