Question about Holmes Products HCH4953-U Ceramic Compact Heater
"Screw Stud Melted After Faulty Power Cord Occured".
I have a "Holmes Whisper Quiet Twin Ceramic Heater (Model #: HCH4953)" that has a melted screw stud after a fault occured at one the sides of the power cord (the positive side of the cord; which it's on the narrow~prong side of the plug). As an electronics technician student, I'd already found the fault of this particular hearter of mine, but is there is a way that I can can somehow manage to mount the screw to the melted stud or allow the screw to stay in its appropiate place? Thank you very much to whom it may concern.^^
  • 706 Answers
Hello LILSHAUNLSS5,
I am not sure I understand the description of the problem but let me take a shot at helping you. First off, you obviusly had a short of some sort that drew excessive current , causing a fault and ultimately got hot enough while drawing that excess current to melt something.. Here is where I am a bit confused. Power going to the heater elements comes off the thermostat and onto one side of your elements. If that is where the screw melted, can you remove th eoriginal screw and redrill and tap a new hole for a new screw to be used? If there is any question about the integrity of that termination then I wouldn't mess around with it since anything you do wrong , may result in a fire. So whatever you decide, be careful. If you can provide a picture or sketch of what it is that failed, I may be able to assist you further.
Good Luck,
Regards,
Rick
Posted on Dec 04, 2008
How do you open the back plate to access the power connection. On a shark model G1568 iron??
We have a Euro Pro GI472, which kept going off and on, and the problem seemed to be an intermittent connection in the power circuit. If we "fiddled" with the cord, the power light would go off and on. To get the back off, I removed the two screws below the rubber feet, near the identification tag. Then I had to pop the red plastic light lens off the top of the iron. The lens is held by two plastic "claws" one at the top and at the bottom of the lens. Once the lens is out, there is a small Phillips-head screw visible between two light sources. I removed the screw, and that freed the cover, and made it possible to access the wiring. Testing continuity from the wall plug to the two wires inside the iron, and flexing the cord, quickly led to a spot in the cord that was slightly kinked, and that was the location of the fault. Both wires under the insulation were broken. In fact there were small balls of melted copper near the breaks. Then it is a matter of making sure you know which wire of the power cord goes to which spot in the iron (a photo or a sketch will save mistakes when reassembling) cutting out the faulty wire, getting a suitable crimp connector and a wire nut and rewiring the iron.
Jun 08, 2014 | Euro-Pro Irons
The Holmes Comfort Temp ceramic heater works fine on Low setting, but once it is set to High temperature the illuminated digital display fades out and the unit turns itself off. Unplugging and letting the...
These heaters were not designed to be serviced in the field. If it's not over a year old, it may still be in warranty. Contact Holmes through there website www.holmesproducts.com for more info.
Jan 19, 2011 | Holmes Products HCH4953-U Ceramic Compact...
Holmes Heater HCH 4163 purchased 2 years ago & has seen only light duty. Upon turning heater on there is a severe electrical smell allthough heater appears to function normally; cord & heater do...
I think the warrenty on this heater is one year. If the heater housing and cord are not overheating then I would remove back panel and clean fiter and brush,vacumn,or use compressed air to clean motor and fan blades. It's possible that if you have not been using very much that it's just burning off debris and causing the smell. I hope this helps you. Thanks
Dec 20, 2010 | Holmes Products HCH4163 Ceramic Compact...
Change power cord four prong fisher and paykel
The power cord for your dryer depends on the available receptacle. For a 4 wire cord connect the two outside wires in the cable to the two outside screw terminals , connect the center white wire to the center screw .. and the green wire connects to the ground stud , typically above the screw terminals.
For a 3 wire cord connect the two outside wires to the two outside screws ,., connect the centerr wire to the center screw and then add the ground strap from the stud above to the center screw terminal.
Dec 07, 2009 | Fisher and Paykel DGGX1 Electric Dryer
The heating coil isn't working. I am trying to get the screws out but they have triangular shaped indentations in the screws. Where do I get a screw driver bit to fit them?
the screws are tamper proof screws because it isn't meant to be user friendly. however if you have an old philips screwdriver and a dremel tool you can make a driver for those screws.
Oct 24, 2009 | Holmes Products HFH104 Ceramic Utility...
When temp. is set it will not come on at set temp.
The temp setting is not an "exact science" and is conditional:
The unit may be too close to a wall or other obstruction, such as an enclosure. It must be able to sense the temperature in the general area. When you move it, give it a few minutes the first time. After that, it will work correctly.
Oct 05, 2009 | Holmes Products HCH4953-U Ceramic Compact...
Replacement power cord
Fryers draw high amps.Goto home depot,lowes and buy a 15amp 125 volt plug.Cut the exsisting plug off the cord,strip the cord down 2 inches you will see 3 wires black,white,green, connect the green wire to the green screw on the plug.connect the other 2 wires on either of the remaining spades(it doesnt matter).let me know
Nov 22, 2007 | Bravetti EP4305FS Deep Fryer
Holmes Products HCH4953-U Ceramic Compact Heater Logo
81 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
