Question about Olevia LT42HVi 42 in. LCD Television
42" Olevia LCD Screen going very dark. Unable to control bright.
I have a three year old Olevia 42" LCD TV. The screen has been going progressively darker and is now almost unviewable. The onscreen menu controlling the video options is not adjustable. When I try to adjust the brightness, the progress bar bounces back and forth between 42 and 45. The manufacturer states that this set does not allow a backlight bulb replacement without replacing the entire panel which costs over $900. (Not worth the money). If the problem coul be fixed with a "main board" replacement at $200 I would fix. Is this three year old television repairable without spending over $1,100?
  • djbyram Dec 07, 2008
    Does this problem sound like it could be fixed with a simple main board replacement?
    Thank You for responding. Olevia tech support states that they do not sell the backlight bulb seperately and that it is incorportatd into the panel. Other LCD's I've looked at all sell the backlight seperately. Please recommend a cheaper solution. $300 to $400 is in the ballpark. $1,000 is way over the top.
  • 505 Answers
If the on screen bar jumps around when you try to adjust the brightness, I believe the problem is in the main board not the backlight. Any backlight issues shouldn't effect your menus functionality whatsoever. You main board is likely sending bad data causing the problem. Does the menu malfunction on any other adjusments? Try rebooting the set (unplug for 2 minutes) to reset the microprocessor.
Posted on Dec 07, 2008
  • 10,594 Answers
Please see HERE CCFL backlight for 32" panel.
You need to ask them for 42" CCFL for your TV. When you got it, a good TV tech can replace defective CCFL easily.
Its low cost solution.
    Genius:
  • 1,239 Answers
Hi
Turn off the the OPC feature in the Menu. If that doesnt help, what youre seeing is most likely the Advanced Dynamic Contrast going to work. In layman's terms, it automatically adjusts the contrast depending on the video signal it is receiving. If you want to disable this, change the AV settings to "User" (button underneath the bottom door on the sharp remote)
    Guru:
  • 558 Answers
You should go for checking the Main board Power supply board for any loose or worn out ciruit, and if require replacing it.
I would suggest, it is better to purchase a new one instead of going it repair.
  • Puneet Jain
    Puneet Jain Dec 07, 2008
    You should go for checking the Main board (Power supply board) for any loose or worn out ciruit, and if require replacing it.
  • 2,296 Answers
I would not be certain that the entire panel needs replacing but there could be low power getting to the back light inverter board and that is why the image is getting darker due to the lower power provided by the power supply.
If you can use a multimeter to check the 24 volts from the power supply to the back light inverter, you might be able to see if the power supply is defective.
Let me know if you require further assistance.
Posted on Dec 05, 2008
  • Jaime Hernandez Dec 18, 2008
    You might want to check this website to see if they can find the parts for your TV.
    You can also look for the parts by part number because other TV manufacturers might be using the same.
    Sergeant:
  • 276 Answers
It has to repaired as this is necessary to be done to get it repaired.but a local technician would not charge u that much.it will be under that estimate amount.but fault u told that is ver correct.
    Top Expert:
  • Olevia Master
  • 70,387 Answers
You will need to have the backlight for the LCD replaced, LCD's don't emmit any light of there own, this is what the backlight does, it won't cost even close to $1,000, at most $300
Our 42" lg tv is
no. there's some problem on its display circuits that it need to be corrected, picture becoming dark has some problem with the inverter power supply circuits that responsible for lighting the small lcd flourescent light. maybe some loose connection in the components cause that to happen
Feb 06, 2011 | LG 42LC2D 42 in. LCD HDTV
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Screen wont cut on but audio works
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 19, 2009 | Olevia LT42HVi 42 in. LCD Television
Adjusting color/ user mode??
The TV will not let you set brightness, contrast, color or tint in the preset modes like Vivid, Movie, Standard etc. Look for a mode that says custom, user etc..
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
Red spots on Olevia TV
pixels are bad/going dead. look up dead pixel issue on PSP for really good explanations, or just trust me.
Dec 22, 2007 | Olevia LT42HVi 42 in. LCD Television
Cable question
Make sure your refresh rate is set no more than 60HZ. Your monitor might not support refresh rates higher than that.Also try lower resolutions.
Here is a list of specs: (also try another cable)
Features/Specifications:
  • Olevia LT23HVX 23-inch HDTV Compatible Widescreen LCD TV
  • General Features:
  • Black cabinet
  • 23-inch active screen size
  • 16:9 widescreen aspect ratio
  • HDTV Compatible
  • 1366 x 768 native resolution
  • 1600:1 contrast ratio
  • 8 ms response time
  • 178° horizontal and vertical viewing angle
  • NTSC TV system support
  • 480i, 480p resolution support
  • Progressive scan
  • Color temperature adjustment
  • Built-in 5 watt x 2 speakers
  • PC resolution support up to 1024 x 768 @ 60Hz
  • English/French/Spanish language
  • Sleep Timer
  • V-Chip parental control
  • Energy Star compliant
  • Remote control included
  • Wall mountable
  • Front Panel Features:
  • IR sensor
  • Power
  • Menu
  • Channel down
  • Channel up
  • Volume +
  • Volume -
  • Source
  • Rear Panel Features:
  • 15-pin VGA
  • Audio in
  • Headphone
  • Component Y, Pb/Cb, Pr/Cr
  • Composite RCA video inputs
  • S-Video
  • Antenna
  • Power Specifications:
  • 100-240V, 50/60Hz, 2.5A (max)
  • 110 watts AC power consumption
  • Unit Dimensions:
  • 16.5 x 27.1 x 8.3-inches (H x W x D)
  • Gross Weight: 23 lbs
  • Net Weight: 21 lbs
  • Regulatory Approvals:
  • FCC
  • CSA
  • UL
Package Includes:
  • Quick Start Guide
  • Manual
  • Remote control w/two AA batteries
  • Power cord
Additional Information:
  • Notes
  • Model: LT23HVX
  • Product Requirements:
  • Satellite cable or antenna
  • PC with 15-pin VGA adapter
  • Stereo system with component, S-Video and composite jacks
  • Available power outlet
  • Disclosures:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 20-Inch to 23-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15mm (bright to bright dots)
  • Minimum distance between defects: 5mm (dark to dark dots)
  • Disclosures:
  • Consumer Notice:
  • This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the Nation’s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission’s digital television website at: www.dtv.gov.
Nov 29, 2007 | Olevia LT23HVX 23 in. LCD Television
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Olevia LT42HVi 42 in. LCD Television Logo
41 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Dave Naylor
Dave Naylor
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
