Question about Acer AL1916B 19" LCD Monitor
Blurry Screen I have pressed the Auto Configuration button on the front of my monitor and now my screen is very blurry and hard to read. I have pressed the Auto Configuration button again but the settings do not change. Any suggestions?
  • chambersk12 Mar 14, 2008
    ACER 1916 very blurry screen . Have tried auto config - no changes.
There are various things that can lead to this.
i've had some trouble with it as well, but now it's solved.
i used to disconnect my vga cable, and then connect it again. mostly, that kept my screen sharp for a day or two.
but since my screen broke (it turned pink) i returned it to the story i bought it, and they shipped it to an acer center. there i got new software installed on my screen, and since then it's been sharp.
there's a note on this in the manual you got with your screen, maybe that could help you too.
Posted on Apr 09, 2008
Delete the plug and play monitor driver and reboot. Trouble is this worked for only one day and had to be done the next. Wish I knew a permanent solution. It appears to be a driver issue. Will see if I can reload the monitor specific drivers instead of plug and play.
Posted on May 08, 2007
Hp dv6000 laptop screen blurry
Hello Al,
I hate to inform you but the graphics chip in these laptops are known for doing this. HP is aware of that. Every time some one brings me a Hp Dv6000 laptop about 75% of the problem is the system board or overheating issues.
First try cleaning the laptop screen with laptop screen cleaner
Walmart LCD Display Screen Cleaner for TVs Computers and Cameras
if its still blurry connect a external monitor to your laptop to see if the display is blurry on the external monitor (to get to toggle the video from your laptop you will have to press the Fn key + F4)
If its still blurry then its the graphics card or chip needs to be replaced. They are all integrated with the system board / mother board.
If its clear and images are good then the laptop screen will need to be replaced. hope that helps.
Jan 21, 2014 | HP Pavilion dv6000z Notebook
Blurry Screen
If you're using a VGA cable (a.k.a the blue plug) you'll have to use the Auto-Adjust feature on your monitor.
Jul 13, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Image on Monitor is slightly blurry
Try reducing the screen resolution to 1/2 of what it is now!
Jan 20, 2010 | Acer AL1916W 19" LCD Monitor
Icons are blurry
Did it happen all of a sudden? In other words, was it OK before?
Try going to screen preferences, settings, and look at the resolution slider - is it set to the native resolution of your monitor (1280x1024)? If not, correct and accept changes.
If the resolution is set OK, then multiple other things might have happened, but not knowing a bit more about the situation it's hard to advise anything...
Nov 08, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Blurry screen
check your cable VGA or DVI - reboot - if not work, uninstall your drivers and reinstall them
Sep 01, 2009 | HP vs19 (Silver) 19" LCD Monitor
Blurry flat screen computer monitor Almost impossible to read. 17" Hyundai about a year old.
have you tried upgrading your drivers? or changing the screen resolution?
May 26, 2009 | 2006 Hyundai Sonata
Al 1916 problem
really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
Focus is way off...screen is blurry????
is the monitor a flat screen? if so, you can try the autoadjust button, which is found by pressing the monitor menu button, and cycling through.
Jan 06, 2008 | Acer X221WSD Monitor
Blurry Vision
What are you looking at on the screen? Before or after the shot? The this point the taking sequence-point camera at scene look in screen blurry image - half press the release - autofocus comes into play- press all the way picture takes.Sharp picture in the taken images what are you doing?
Sep 08, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Acer AL1916B 19" LCD Monitor Logo
485 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
