Question about HP Compaq nx9020 Notebook
Compaq nx 9020 battery charging problem
I have a compaq nx 9020 laptop.
earlier whenever i used to charge the laptop battery using the external charger,it used to charge normally,go upto 100% and the battery charge indicator LED used to change to green after the battery got fully charged.
Now it does not get fully charged,stops mid way between 60-75% and switches to AC Power(the Battery charge indicator LED keeps on blinking after that)and if i take out the charger,comp shows "critical battery".
However if i remove the battery and put it back again for charging,it increases upto 80% and ten the whole drama happens again.
Do i have to buy a new battery or there is some internal circuit problem?
  • 64 Answers
Damaged battery or internal circuit problem it is hard to to say. Bring your laptop to a repair shop. They can check the battery and tell you what the problem is.
Posted on Dec 04, 2008
My laptop is compaq Armada M700 with Windows XP Professional version 2002, how will i know if my battery is already fully charged? i have been charging it for a day and when I disconnect the charger tha...
From your description it seems the battery hasn't been charged right, so there maybe something wrong with the battery or laptop. First, do a clean to the your Compaq Armada M700 battery and the connection chip on your laptop, then to see if there is something get better. When you charge you laptop, there will be a lights to note the state, do you have noticed? Else if your Compaq laptop battery are used for 2 years please try a new one
Aug 25, 2011 | Compaq Armada M700 Notebook
Battery is not charging hp nx 7010
Batteries last only 1 or 2 years in my experience, unless higher capacity batteries are used. If your laptop doesn't charge, it's likely a new battery is required to enable good charging of the battery. Try amazon.com or ebay.com for your make and model.
Dec 18, 2010 | HP Compaq nx7010 Notebook
How to get my laptop to charge.
If you battery is totally dead you need a replacement unit - remove the battery power the unit up using external power pack then refitt the battery - if it won't charge the battery is dead. get a new battery
May 19, 2010 | HP Compaq Evo n610c Notebook
I replace new battery. It does'nt take charge. the
If u are able to power the laptop with power from the mains (AC) then your problem is the connection between the battery and its socket and not the battery. In that case power management will not see it as u indicated because there is no connection. You have 2 options:
1. Continue to use with mains only 2. Take it to a techie
May 13, 2010 | HP Compaq nx7300 Notebook
Problem HP Compaq nx 7300 Yelllow light 8x
Have you had previous problems with your laptop power supply and battery? I have this same laptop and use it very regularly. I do have problems with battery life, but never actually powering on. I suspect the battery is not accepting a charge. My suggestion is to replace the battery and see how things go.
Oct 18, 2009 | HP Compaq nx7300 Notebook
Laptop Charging Help!!
you should get your laptop plug fixed for sure.
Patrick
Oct 18, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Nx 9010
Simply plug the ac adapter into the wall, the laptop will charge the battery itself.
Keep in mind this... in general, a laptop runs at full speed when it is plugged into the wall. When most laptops are running on battery, things are running more at 50% capacity to save on power, this giving you more battery life. A dimmer lcd and slowing the processor down when not needed are common traits.
You can use the FN key (function key) and the corresponding dim control on the keyboard to adjust the brightnedd of the backlight. It should be marked on your keyboard in a different color, like blue or maybe green (not familiar with that models keyboard).
Oct 21, 2007 | HP Compaq Business Notebook NX9010
HP Compaq nx9020 Notebook Logo
348 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
