Question about Roper FGP305 Gas Kitchen Range
Insufficient gas for cottage during winter
I was recently deer hunting. Our cabin has an older 4 burner roper gas range and two gas lights that all run off the same LP tank. We've never had problems before last year when the regulator was changed, but we now can't run more than 1 buner on the stove and NO lights. Does it sound like my brother-in-law put the wrong TYPE reulator on? I'm not sure if it's a low or a high pressure one. For the described system, which would we need? As an asise, by banging on the tank we got a much better flame for about 30 seconds.
  • 1,543 Answers
Sure, there are lots of regulators, but one commonly used for gas grills should be fine. (maybe the brother in law used a step down regulator for natural gas, which won't work for you) I don't know your location, but another factor might be your outdoor temperature. If it is very cold, the liquid petroleum (LP) in your tank will not vaporize fast enough to satisfy demand, regardless of regulator size. A full tank in a warmer location would help immensely, but it is not real wise to have the tank indoors.
Posted on Dec 04, 2008
Caloric range oven, older at least 20 years old, the range burners spark, but will not light, i am assuming that its electronic ignition, no pilot light?
If you don't smell gas, then it is probably electronic ignition and not a pilot light.
But if your oven and none of the range burners light, are you sure you are getting gas to the unit or from the range valve to the burners and oven? Can you light the burners with a match? If you can you can rule out the valve and incoming gas line, and concentrate on the ignitors.
Jun 07, 2011 | Kitchen Ranges
I have an old Vulcan 6 burner commercial gas stove with a 24" griddle. The gas was turned off during a remodel. Now the gas is back on and the gas burners work fine but I cannot get the oven pilot light to...
Hi- This should have a gas Safety Valve, this is the main valve to the oven (this probably has 2). If you remove the lower panel under the doors they are probably right there. Looks like a large gas valve with a button on it, sometimes the button is red. You need to hold in that button while lighting the pilot and keep holding it in for a few seconds until the thermocouple gets hot enough to tell the valve to keep the pilot on. You'll have to do this for both ovens if there are 2 valves. It's possible the valves are located somewhere else on the range so you may have to hunt a bit. If the pilots still won't stay lit you may need new thermocouples in which case I'd call a Tech out to look at it. Hope this helps. Good Luck.
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Burners on top will not light with the pilot lights
To Clean:
IMPORTANT:
Before cleaning, make sure all controls are off and
the oven and cooktop are cool. Do not use oven cleaners, bleach
or rust removers.
1. Remove the burner cap from the burner base and clean
according to “General Cleaning” section.
2. Clean the gas tube opening with a damp cloth.
3. Clean clogged burner ports with a straight pin as shown. Do
not enlarge or distort the port. Do not use a wooden
toothpick. If the burner needs to be adjusted, contact a
trained repair specialist.
4. Replace the burner cap, making sure the alignment pins are
properly aligned with the burner cap.
5. Turn on the burner. If the burner does not light, check cap aligment.
May 27, 2009 | Roper FGP300 Gas Kitchen Range
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Pilot blights wont stay lit on older model American gas range
Take a very small wire and clean out the pilot holes. Then find the pilot flame adjustment screw and re-set your pilot to 1/4 inch flame.
Mar 24, 2009 | Kitchen Ranges
The burner ingitors are clicking when burners turned off
behind the knobs you will find the switches that makes them ignite ,it they are wet they will try to ignite by then self. make sure they are dry.
Nov 22, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Gas Range Oven use without electrical power
It will be necessary to change the top burner orifices when converting to propane. You should be able to light the top burners with a match or lighter, however, the oven will need proper operating voltage.
May 22, 2008 | Amana Ovens
Roper Gas Range
F1 Error
My Roper gas range is sounding an alarm call with number F1 flashing. Can anyone reveal what the code means before I call service? Thanks!!
Mar 24, 2007 | Roper FGP305 Gas Kitchen Range
Roper FGP305 Gas Kitchen Range Logo
118 people viewed this question
Top Roper Kitchen Ranges Experts
Justin Duby
Justin Duby
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
