Need to reset siemens se 587 router - Computers & Internet
    Scholar:
  • 81 Answers
Please verify it's a se 587 because I found no routers with that info...... However this being said to do a 'hard reset' meaning it will reset the router to the factory default... on the back of most routers will be a small little hole the tip of a pen/penicl or paperclip will fit. Press in there and you will push a button and hold for 20 seconds or if possible and you can see the front if you see all the lights flash twice and then power down. This should reset the router
Posted on Dec 04, 2008
Configure router to different supplier
hold the reset button at the back of the router for a couple of seconds, connect your pc and run the installation. During the installation process, it will ask for the ip address, input the new ip address of your new provider.
Aug 22, 2009 | Efficient Networks Siemens 5930 Router
Pvc selection keeps changing to dial up mode
  • delete the dial up connection on the internet option
  • click tools-internet options on the internet explorer - click connections tab, delete all dial up on the box, and select never dial a connection
Aug 04, 2009 | Siemens SpeedStream 2624 Router...
Linksys WMP45G will not connect to wireless modem
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
ypur connection won`t drop after this.
Jun 09, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Error 51330 on nintendo wii siemens gigaset se587 wlan used.
hi
i have just solved this problem on the SE 587, hope it works for you.
1) in internet explorer type 192.168.1.1, which should bring up your router settings - then select "wireless" and then "basic wireless settings" - under "auto channel" set it to "disable" and the set "wireless channel" to "1" , then "save settings" - my pc briefly went offline and quickly came back.
2) when setting up the connection on the wii you need the code from the bottom of the router - make sure you have "caps lock" ON on the wii when you set up.
3) now everything works perfectly on the wii - you dont even need the pc on! just the router.
good luck, IAN.
Dec 16, 2008 | Siemens (120-5830-001) Modem
Im having problems conecting my nintendo wii to my tiscali siemens gigaset se587,can you help me please as i have tried to link them both together with a wireless conection but i just get an error message?...
hi
good luck IAN.
Sep 02, 2008 | Video Game Consoles & Games
Do I need an ethernet adapter with the siemens 587 router? I have an ethernet card that is enabled and working properly but I keep getting an error message saying that I need an ethernet adapter. The...
1. Test your system with another ethernet card to be sure of the status of your ethernet adapter.
if it works fine that means all is well,if not update the neworking protocols on your computer so that it would be compatible with the routers TCP/IP net. protocol
Apr 22, 2008 | Siemens SpeedStream 2624 Router...
Siemens 587/advent 7096
Hi ,
If the problem is the wrong key entered then you should just modify it in the Access Point settings. Access Point settings can be accessed as Below.
In Tools->Settings->Connections->Access points
delete it then create a new one, or modify it !
Kindly give a feed back for this.
Thanks and regards
Mar 28, 2008 | Computers & Internet
Siemens se 587 router
HI,
You can try manuall setup of da router.
The Default gateway for Siemens Gigaset SE587 is 192.168.1.1. Open Internet Explorer and put the def gateway in the browser.
The default username and password for siemns router is admin.
Click on Setup Tab than Basic Setup on left hand side. Update the details as folloing-
Use – Tiscali data PPPoA Interface
PVC Selection – Tiscali data PPPoA
Authentication – Auto
User Name - Tiscali u/n
Password - Tiscali password
PPPoA Connection Mode- Always On
NAT - ON
And click on save settings. To confirm if the customer is connected, check the status of Online light – which should be green
. Alternatively click on status (On top) to check internet status to confirm connection.
Setting Up Wireless connection – Click on da wireless tab on the top.
Ensure that the Auto channel is disabled and the wireless channel is 11, wireless n/w is Enabled and mode is Mixed.
To secure the wireless connection – Click on Wireless Security option on left hand side
If you want the Security mode as WPA than select the wireless security mode, as WPA and enter WPA Shared key which would be on the base of the router. Again click on save settings.
Try connecting to the wireless network again and I m sure it should work..... lemme know if it does.
Cheers
SHADAB
Mar 26, 2008 | Siemens SpeedStream 2624 Router...
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
