Question about Microwave Ovens
Haier Microwave, only the #1 and 2 buttons work. None of the rest of the numbers do anything.
  • Microwave Ovens Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Otherwise, you can contact Haier customer service here for more help.
Posted on Dec 08, 2008
Whirlpool microwave AVM 585 - none of the control buttons are working, except the number 1.
The electronics on your control panel have gone bye bye. That is why to this date I have always preferred the nukes with the old fashioned timer. They always work and when anything goes it is the little motor that can be easily replaced at nominal cost..
Newer is not always better. Might look better but .....................
Sep 14, 2015 | Whirlpool Microwave Ovens
Replaced 20A fuse - now display blinks
Here is the parts page for your unit with an exploded view and parts list
http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R-9H84B/0958/0123245/P0050209/00001 It is possible the switch is bad the look at part number 1-6 hope this helps.
Nov 08, 2013 | Sharp R-9H84B Microwave Oven
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
Sep 27, 2013 | Emerson MW8168B Microwave Oven
Micro has a message F3 and and none of the controls work when i push the buttons
You have one of 2 problems, an open Thermocouple or a bad control panel DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I locked my buttons on my ge spacemaker microwave by accident. How do I unlock it?
I did same thing tried everything be pressing and holding the off button about 5 seconds it worked.
Feb 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
We have a fairly old Sharp Carousel microwave, model number R-2A95. Out of the blue the entire keyboard stopped working. The numbers were still on the screen, but none of the buttons worked. We took the...
Before you invest too much time, look and see if the touch pad is still available. Sharp is pretty quick to discontinue parts right after about 5 years. There is a place called encompass parts. They are a distributer for Sharp, you micght check with them.
Oct 07, 2017 | Sharp Microwave Ovens
None of the bottons work on my microwave and only the "L" for light is lit up on the display
A serial/model number would help... MV1526W? MV1604SBQ? I apologize for needing to ask, but am not that familiar with them. I would unplug the entire unit and let it rest for at least 30 seconds, and even try to push buttons while unplugged to dispel latent static electricity within the system. Then plug it in and see if you still have the problem.
I have found a website that may help, depending if they have uploaded your particular model.
http://www.hammerwall.com/Manuals/Goldstar/Description/MV1604SBQ/GoldStar%20Microwave%20Oven/L0521424/
Sep 26, 2010 | Goldstar Over-the-Range Microwave
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave, Model #JVM1540SN1SS, buttons don't work
The membrane keypad has failed.
The keypad itself is not available as a separate part, so the control panel frame with keypad would have to be replaced.
This is actually a pretty simple DIY job.
You can part number WB56X10826 from the Pros here for $114.62 plus shipping (that compares to $166.50 from GE!).
You can also find helpful exploded view diagrams at that link.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then disconnect your keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
May 27, 2010 | GE Microwave Ovens
Kenmore Microwave Hood Combination oven Model Service code (SE) ?
The 401 in the model number is the model prefix for Samsung, who manufactured the oven.
SE error means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
I would need the rest of the model number from the tag to help you more.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly with your brand, model and symptoms for more FREE help & do-it-yourself advice.
Please include this URL, too:
http://www.fixya.com/support/t2931196-kenmore_microwave_hood_combination_oven
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 12, 2009 | Kenmore Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
