Question about Samsung HP-T4254 42 in. Plasma Television
HDMI jack is loose/wobbly
I have a 3 1/2 year old 40" Samsung LCD w/ only 1 HDMI jack. It is now wobbly and partially seperated from the circuit board. How difficult is this to fix? And does it need professional attention or can I do it?
rlamkin
  • 44 Answers
SOURCE: Loose HDMI Connection
Dont use the HDMI connection OR replace the main board. Its directly soldered to the main board. The back should come off IF you have removed ALL the screws and the little screws things that hold on the VGA connections etc. There are also some obscure screws holdin the back on.
Posted on Jul 03, 2008
  • 7 Answers
SOURCE: My samsung tv turns on and off repeatedly at
Mine was doing that then it quit even turning on so I replaced the 4 Capacitors today on the power supply board that had bulged up on the top 3 had split open they where on the top right corner of the board where the ribbon jumps from the power board to the main board with ones from Jameco Part Number 606521 they worked perfect but make sure you put them in with the correct polarity easy to do just keep an eye on it. Very simple repair and took me about 30 min to take itapart solder on the new ones and put it back together all for under $10.
Posted on Jul 09, 2009
  • 4090 Answers
SOURCE: no picture on Samsung LCD 40" TV
Nobody could guess that! it depends on where you are in the world. For Instance I am in australia network.
Call outs generally run to $AUD90 and $90 and hour Min 1 hour.
You do not say whethyer the power light lights up so its again guesswork.
If the power light IS lit then there is power from the wall to the primary coil of the power transformer. I would then suspect either the secondary transformer has failed, or that a fuse after the secondary and pre picture/sound module has blown. The power supply ( cant by bits) costs around $200. The fuse 0.60
add to the callout fees and you get some idea of the cost can cost half the value if a $1000 TV The plasma screen hasnt gone so that's always a plus and its rare for the video board and sound module to fail simultaneously. So my bet is the poer supply side and fuse
Posted on Aug 13, 2009
Testimonial: "Thanks I appreciate all the info and help!"
  • 927 Answers
SOURCE: Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Posted on Jan 02, 2010
SOURCE: 3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Posted on Jan 30, 2010
What could cause my crankshaft pulley to wobble if it just has the 1 bolt in the center of it holding it in
Year/make/model?? Check to see if bolt is loose. Some crank pulleys have a rubber insert that can seperate causing a wobble.
Mar 09, 2016 | Cars & Trucks
Problem with Samsung LNR408D 40 in. HDTV LCD Television Broken HDMI port HDMI port in rear of TV seems to be no longer connected to board. How much would that cost to get fixed and/or how easy is it to...
After you are sure you have hooked up the receiver to the TV properly and with the proper setting in the menu, if you are still having problems then you need to change the main board (the one with all the jacks on it). You will have to take the back from off the set. You will have to get the number from off the board itself and it should start with BN94-. Do a search on ebay with the part number or go to shop jimmy.com for price and availability. Also try to google search. The board is easy to change just unplug and unscrew from the panel.
Nov 07, 2011 | Samsung LN-R408D 40 in. LCD HDTV
LN-S4041D 40 in. HDTV LCD Television: OUR SAMSUNG T.V IS A 40 INCH AND IT CLICKS, CLICKS...
Is there a clicking sound? Unplug the power cord for 20 seconds and see if this helps reset the circuitry. If the clicking continues, go to http://www.fixya.com/support/t722954-samsung_lns4051_dx_makes_clicking. If you can see defective caps on the power board and don't feel comfortable replacing, parts can be ordered at PartStore.com.
May 16, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Purple star shape spots on my 40" Samsung LCD TV
you have what is called panel seperation it was a very common problem a year or two ago you will need to replace the lcd panel
Jan 18, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung 650 lcd 40" tv picture blacks out for a few seconds.
Dude, better check your cable and also your TV's power management settings. This might also happen due a issue with the HDMI output of the satellite box.
Jan 07, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
Imput problems with Samsung DLP TV
The parts required for this are available but difficult to find. The overall repair is not that difficult for anyone that has fixed these before. You'll spend more time getting to the jack than replacing it. Try calling Samsung parts and give them the model as well as the circuit designation of the jack. This designation will be written on the PC board. For less than $5 you should be able to get the jack. Ask a local service shop to install for you and you are off and running.
Dan
Aug 12, 2009 | Samsung DLP HL-P5663W 56" TV
How to connect IBM T61 to my Samsung LCD TV 40'' 3xHDMI
If you have an s-video port you will need to buy s-video cables and a separate audio cable for sound. With HDMI you will only need 1 cable for both video and sound. Just connect your s-video cable to your s-video output ( your laptops quick reference manual should show you where your s-video jack is at ) and the other end to the back of your LCD tv video input ( consult your lcd tv manual )
Jan 02, 2009 | IBM Lenovo ThinkPadĀ® T61 PC Notebook
Loose lcd
do you mean the whole part that flips up? if so my phone is the same way, it is a 540 though, hasnt caused a problem yet.
Aug 03, 2008 | Samsung SCH-u540 Cellular Phone
Samsung HP-T4254 42 in. Plasma Television Logo
Jerry Greenberg
Jerry Greenberg
