Question about LaCie 80GB Mobile 80GB 5400rpm 400Mbps FireWire 480Mbps USB 2.0 USB 2.0 IEEE 1394 Externa... (300765FT) Hard Drive
Lacie mobile external hard drive
Well I just bought it new in the box and installed the CD but not able to find it listed under My Network Place. also, cannot see if has copied files on it. Many thanks for your help. Kind regards
    Novelist:
    Champion:
  • 202 Answers
Not sure if you meant "My Computer". You should see the drive there. Did you see you the computer install the drive when you hooked it up? You may need to unplug it then hook it back up so the computer can find and install any drivers. Let me know, Tim
Posted on Feb 08, 2007
I cant see my external lacie hard drive on my mac with the Lacie Network Assistant. The hard drive is visible with the finder though. With the dashboard and with the finder I am able to move or copy files...
for the product that you selected for your question, it is impossible for the LaCie Network Assistant to see it because it is a Local drive (USB).
The LaCie Network Assistant only detects the Network LaCie drives.
Regards,
Jan 25, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I bought a few years ago a Lacie d2 safe hard drive with AES Encryption (with biometric fingerprint sensor). Currently not my Toshiba desktop or IBM laptop pick up the hard drive when I switch it on. The...
Hi... Problem with your external hard drive, pc don't recognize it...
it possible you have bad sector in your disk drive, or your usb cable is not responding.... the best way to find out open your box then take off our hard drive and install it into a pc and see if the hard drive work... or you box it self the controller inside our external box maybe damage,
Oct 20, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Not turning on.... I turned it off to move its location and now i cant turn it on...Power cable and everything is in place and live, but no joy..
Same problem. Bought a new power supply at extortionate price from Lacie but still no joy. I'm hoping to find a way of converting to a dumb external USB HD.
Oct 16, 2010 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I just bought my LaCie 301888KUA 1TB Starck Desktop USB2.0. I was following set up directions in the manual until I realized that my Mac OS X (version 10.5.8) is not recognizing the hard drive . It's not...
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jul 31, 2010 | LaCie 301888KUA 1TB Starck Desktop 1 TB...
My lacie external drive wont transfer my data from a mac to a pc
Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
Feb 13, 2010 | LaCie Hard Disk 750GB with Hi-Speed USB2.0...
The drive is not listed in
Try a replacement USB cable first, and test the LaCie on a different computer, to ensure the fault is on the external storage unit, and not a computer system problem.
There are two possibilities:
The LaCie USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. New Lacie are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be LaCie.
Check if your LaCie is Sata or PATA (IDE) before buying the enclosure.
Oct 20, 2009 | LaCie 250GB External USB2.0 7200rpm 250 GB...
Imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
Oct 17, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
Lacie hd problem
This is a pretty old thread, but I just figured out the work-around for my Lacie drive with the same symptoms. I took the Lacie case apart to find a pretty standard 3.5" Seagate Barracuda drive inside the case. If you pull the actual hard drive out of the box, you can either purchase a new external hard drive adapter box ($30-80) or install it into a tower computer. I installed it into an older G3 tower and it mounted right up. I decided it wasn't worth investing in a six year old hard drive, so I will be purchasing a new drive and pulling the data off the old one.
Mar 05, 2008 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Computers & Internet Logo
65 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
