Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Wont print i have been using epson print cd program to print on to a disc. it recently kept asking me to reload the cd/dvd tray all the time. i contacted epson about this and they said if the 4 white marks on the tray were damaged in any way the sensor wont recognise it. i ordered a new tray and it does the same. when i reload the tray nothing happens at all . if you have any answers to this problem please let me know, thank you for your time. steven murray
  • steven680 Dec 05, 2008
    yes i have been using the epson print cd that came with the printer. it moves to start printing then stops and asks to reload the tray. it prints on a4 ok.
  • Arcadian Duran
    Arcadian Duran May 11, 2010
    I not sure the white marks are the problem, sdince theres nothing that senses these marks. you have to have the right program and tell the program that you are printing on a CD or manually insert the CD to the printer, I have a epson r200 i see the white mark you are talking about i dont think the printer senses these marks.
    Which program are you using? are you using the epson cd print that came with the printer??
    Sergeant:
  • 284 Answers
I think it might be the rollers of the printer are going bad. since its need to be in timing correctly, what i do is this.
when the printer start taking the cd tray in a bit push it in aq bit while its going in. DONT FORCE it in just push it in as it goes in, the roller are not catching the CD tray properly, its not the tray itself as youve found out, the rollers are going bad or are to dirty.
try cleaning the area of the CD tray with alcohol, then see if that helps.
good luck
Posted on Dec 06, 2008
The cd/dvd tray is not set correctly.
reload the cd/dvd tray then press the maintenance button
Feb 16, 2010 | Epson Stylus Photo R320 InkJet Printer
Canon MP810-CD-R Tray loading-printing problem
I am trying to print on DVD with Canon MP810 but the image won't line up - seems to be taking the tray too far in and printing some of the image on the F tray! Help.... it's driving me nuts
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
I have an Epson R 300. It worked fine with my PC. I recently got a new I-Mac and I cannot print CD/DVD's. I have the Epson "Print CD" application loaded but when I try to print on a DVD I keep getting an...
If you are using a leopard operating system, you have to install easyprint. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=26322&prodoid=37368458&infoType=Downloads&platform=Macintosh,
Trash / re-install epson print cd.
There is a work around for that. Please contact epson.
Apr 30, 2009 | Epson Stylus Color 300 InkJet Printer
I read on another site that you must wait until prompted on the screen to put the tray into position. Opening the inner door and loading the tray before asked to and then pressing OK was the key to fixing the problem on the MP830.
It's the simple things that always get you into trouble, I guess.
Oct 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson r800
Here is the problem... Because the printer has more then one feed, your program(i.e. MS word) is selecting the CD tray by default.
The solution in MS Word is to go to the Envelopes and Settings then select OPTIONS.
There should be a option in here to select the other tray.
Apr 25, 2008 | Epson R800 InkJet Printer
Epson Stylus Photo R300 CD/DVD Tray
The answer to this is to insert the cd tray then click to print then when its about to print put some light pressure with your fingers and you will see the tray will go in and it willl print just fine does it with mine all the time so thats what i do to rememedy the problem...good luck
Sep 17, 2007 | Epson Stylus Photo R300 InkJet Printer
Unable to print on DVD/CD
The latest R800 driver for Windows
epson12379.exe
(which is probably required for Vista as well as XP) has a hardware interface problem.
When you try to print on a CD, the power button should blink slowly and the paper feed button should turn red until the media (CD) is readied by holding the paper feed button down for a second. However, with the driver above, the paper feed button instead blinks very fast (the printer is being "probed" by the PC in a tight loop I would guess) and so the CD cannot be readied.
The previous version of the driver,
epson11222.exe
does not have this problem. But I doubt it will work under Vista.
If you would like this driver e-mailed to you, send me an e-mail to my "junkmail" account asking for it (include this documentation so I know what you want) and I will send it.
My junkmail account is jim3 underline porter6 at fastmail dot fm
(underline, at and dot are not words but single characters)
Sep 04, 2007 | Epson Stylus Photo R800 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
