Question about Gateway Computers & Internet
Yesterday I turned on my compture and it had said that I needed to change my ip address and it was not connecting to the internet. I turned off the wireless and when dirctly through the modem and restated my computer and now the internet works and I havent been asked to change my ip address again. Do you think the problem is fixed or does the computer only asked you once to change your ip address?
  • 395 Answers
Shound like there might of been a ip conflict, something else on the network wanted the same ip as a device already on the network. it can be fixed the same way as you done it last time. its hard to say if it will happen again? is you network secured or an open network. if your network is open i could very well happen again
Posted on Dec 04, 2008
I cannot connect to the WFC because it needs the ip adress and the connection fails
Click start type cmd press enter you will be in DOS mode
type in ipconfigpress enter you will see all of your internet connection details type in your default gateway ip adress into your internet search should read something like 10.0.0.138
Your IP Address should be thought more as your computer's phone number than it's address, if you have multiple connections, you have multiple IPs if you dont have a connection, you dont have an IP.
Without further delay If you need your computers IP address:
This will work in almost every case, it simply requests the website's server to tell you what your IP is. http://whatismyipaddress.com/
I have included a link to make things easier.
If you are in a network and need your computers local address.
Hold the windows button (looks like the windows banner, usually between left ctrl and left alt) and press 'R'.
A box will display, and type in "cmd.exe" and hit enter.
The 'command prompt' will display, a black screen with white lettering.
Simply type in ipconfig. This gives information on all your internet connections.
Look for the line "IPv4 Address".
If you need to find the IP of a current connection you can type (from the command prompt) "netstat".
This will give you all your current connections.
To identify a specific one, the easiest way is to run it before you establish the connection then again afterwards.
Change IP Addresses
Your IP address is a series of numbers that identify your specific computer on the Internet.
If, for some reason, you want to change your IP address, you can do so without going into the command prompt.Click "Start," "Control Panel," "Network and Internet" and "Network and Sharing Center."
Click "Change adapter settings."
Right-click the network you want to change and click "Properties."
Click the "Networking" tab.
Put a check either next to Internet Protocol Version 6 (TCP/IPv6) or Internet Protocol Version 4 (TCP/IPv4) and click "Properties."
Click the radio button next to Obtain an IP Address Automatically if you want Windows to assign one, or click "Use the following IP address" to manually change it.
Enter the requested information and click "OK."
Mar 01, 2014 | 2wire Wireless-G 802.11g ADSL Gateway
Change ip address
Type cmd in Start menu-Run. A little black window will open. Type: ipconfig/all and Enter. It'll list your IP among other info.
If you want to change it: Start menu->Control Panel
Type "adapter" int the search box. You'll have "Network and sharing Center". Click "View network connections". Select "Internet Protocol version 4 (TCP/IPv4)" and click Properties. There you can change your IP settings.
Jan 17, 2014 | Lenovo IdeaPad Computers & Internet
What is the ip address
IP address
noun Computers. a code that identifies a computer network or a particular computer or other device on a network, consisting of four numbers separated by periods. See also IP.
http://dictionary.reference.com/browse/IP+address
PS. Free points for newcomers or are you to lazy to google it?
Aug 23, 2013 | Comtrend CT-520 Router
Ip address
Find my IP Address
type in ipconfig press enter you will see all of your internet connection details type in your default gateway ip adress into your internet search should read something like 10.0.0.138
How to Change IP Addresses
Aug 16, 2013 | HP Photosmart C6180 All-In-One InkJet...
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address
Jul 24, 2013 | Computers & Internet
Why will it not connect to the internets IP address?
If you reset the modem and ip address will not change and remains same hence it is static ip address.If you reset the modem and the ip address change ,it is dynamic ip address.
You can get the Ip address from your internet service provider.you can check the ip address using the site Ip-details.com .
Jan 25, 2013 | RCA DCW615R Wireless/Cable Modem
I use a HP LaserJet Printer P2015dn. I intalled it by changing it's default IP address (169.254.83.96) to 192.168.0.7. Yesterday I have shared my ADSL internet connection through this network. And...
Try to change your Printer's IP address to 192.168.1.XX. XX means any number that hasn't been used in your network. I suggest you to use IP address 192.168.1.10 (easy to remember)
cheers
Feb 10, 2011 | HP LaserJet P2015dn Printer
Hi, previously all the 30 pc's in my office connect to the D- link switch and having no problem access the internet. yesterday, i changed my ISP and also the new router using 1 fix IP but all the pc's...
Your new isp probably has different dns addresses. Configure your dhcp to assign the new dns addresses. you can refresh the pcs by typing "ipconfig /renew" at the command prompt and your PCs will have the new dns addresses.
Hope that helps...
Oct 25, 2010 | Computers & Internet
Having prob with a new compture laptop a compac connecting to my wireless router and cant get in to router to get nomber
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 03, 2010 | Computers & Internet
Cannot share connection
The IP address that you have is an automatic IP address the Windows generates. It basically means your computer is not getting an IP address from the router (DHCP). You should try powering everything off. Then, in this order, power on your modem, wait 30 seconds, then, power on your router, wait 30 seconds, then power on your computers...This should fix the problem since one computer is working already.
Mar 22, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Computers & Internet Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
