Question about Hotpoint Ultima WF865 Front Load Washer
Hotpoint WF865 Drum getting stuck?
During a normal wash, randomly the drum appears to be getting stuck during the anti clockwise cycle only. The machine will try a couple of times and then just stop until the counter goes to 1 minute and then does no more. If you open the door and turn the drum manually there is no friction and is free to turn. Thanks for your help.
I THINK IT MUST BE A LOOSE COIN,STUCK IN MOTOR
Posted on Feb 08, 2007
Simpson swt8043 top loader washing machine agitates anticlockwise only from new.
The agitator is designed to “ratchet” and turn one way but not the other. If your clothes are being twisted, that is most likely a transmission problem where it tries to agitate and spin at same time
Oct 05, 2018 | Simpson Washing Machines
Drum problem?
You May have solved this but it sounds like the drum bearings have worn out...
Apr 16, 2014 | AEG Washing Machines
My hotpoint WNA64 has been making loads of noise during the spin cycle now the belt has snapped are the two conected?U
I say so think its drum bearing failure common on this machine is the drum noisy on its own try a hand turn and see could also be a sock stuck in it if not free....Please leave feeddback
Apr 08, 2010 | Hotpoint WMA64 Front Load Washer
Noisy bearings
ok, turn the nut at the back anti clockwise, i normally jam the pully into the cut outs in the drum, when you have taken off the nut hold the inner drum inside the outer drum and tap he pu;;y anti clockwise, not too hard or it will crack, remove pully, place nut flush with shaft on the thread and you will be ablt to tap the drum out without damaging the thread.
Apr 07, 2010 | Washing Machines
The water will not drain from my drum. The spin
Check the filter, which is located at the bottom front right of washer behind a flap or drop down cover.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thankyou.
Jan 28, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Very Loud banging on washing machine spin cycle
Ah,,,,Sounds like drum bearings havee gone the circles iassume is oil from the bearing it will be very noisy on spinen and a lot of play on drum ..quite a big repair..hope you get on ok
Sep 30, 2009 | Washing Machines
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Sounds like a loose screw/bolt/nut during the spin cycle
There is nothing wrong with your machine. Don'f bother with the sound , You said you threw 2 pair of jeans, so its bottons are causing the sound against the drum during cycle. Finished your laundry and worry no more. To make sure, throw some another clothing asides form jeans, like shirts, and feel the normal silent of your machine.
Good Luck,
Eriez
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint Ultima WF865 Front Load Washer Logo
388 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
