Laptop wont take a charge or turn on. It has no battery power or battery power Supply: Model No.:MA3
    Scholar:
  • 81 Answers
You do not have a battery in it AND it's not plugged in? It requires at least one to be present. Can you explain what you mean?
Posted on Dec 04, 2008
Asus notebook wont turn on
Please be more specific!
What model Asus laptop do you have?
Is the battery fully charged?
Is the external power supply plugged in and operational?
Have you press the power button for more than 5 Seconds and then again?
Sep 28, 2017 | ASUS Computers & Internet
My laptop wont charge i think it has a broken internal power supply
Bad cord/charger, bad battery? What give you the idea that " i think it has a broken internal power supply" Your saying your laptop will not charge the battery? Does the laptop work? If so the power supply is OK.
Nov 06, 2012 | Sony VAIO VGN-CS310J/W PC Notebook
It wont turn on unless it is plugged into my laptop and i have charged it.
Hi
There are 2 possibilities
1. battery is bad and does not charge itself.
2. The charge board has a problem which is why the battery is not charging and looses power once disconnected from the main supply. IN THIS CASE YOU HAVE TO REPLACE THE BOARD.
reply with all the details of the laptop make, model etc., so i can help you more.
Jul 14, 2011 | Computers & Internet
I can't get it to turn on. the battery shows a charge but nothing happens.
Its definately you`re Laptop charger.Its not pumping enough juice to power up your laptop. The battery will show a charge but it wont turn on,Its you`re power supply charger.
Ive seen this many times before.
Oct 18, 2010 | Computers & Internet
My daughters power supply for her C640 has a pinch
I suggest you DONT USE PINCH POWER CORD FOR SAFETY.
PLEASE TELL ME IS YOUR POWER CORD & THE PINCHED CORD ARE SAME? I MEAN SAME MODEL? AFTER PLUGING OF YOUR CORD, THE BATTERY CHARGING LIGHTS ITS ON? IF NO THEN I GUESS THAT CABLE NOT SUPPORT HER LAPTOP.
VISIT A DELL SERVICE CENTER OR A SHOWROOM AND BUY NEW CORD WHICH IS MADE FOR YOUR DAUGHTER LAPTOP MODEL.
OTHER WISE SOME CHANCES OF SHORTCIRCUIT ON MOTHERBOARD.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Dell Latitude C640 Notebook
Battery wont charge and will not power without battery
It sounds like you have a bad power supply (power cord). If you already know someone that can charge your battery, check if their power supply will fit. It probably will. Make sure the plugs (into the laptop) are the same, and make sure the output voltage is the same on both power supplies.
Dec 17, 2009 | Dell Inspiron 1000 Notebook
Laptop wont charge battery
its a comment fualt with laptops the micro switch that switches between charge and main power goes faulty on them, you could be acutally onto some thing here because ther eis alot of people with laptops that wont charge at all, and if they knew ur little sequence you got going on there maybe you could save their laptops been door stoppers.
Dec 01, 2009 | Dell Latitude D410 Notebook
Easynote r1004 wont power on
The battery is too low and the power supply can't charge the battery and also power the laptop at the same time.
Try this:
1. Remove the battery from the laptop
2. Plug in the power cord and turn ON the laptop.
3. It should work ok.
4. After the laptop is "stable" (what 5 minutes?), you can put the battery back into the laptop while it is ON.
5. Leave the laptop ON so the battery can get charged.
6. Lower / close the lid so that the screen will turn OFFand not take up power from recharging the battery.
If this doesn't work for you, try these steps again, maybe wait a few minutes between steps.
This WILL work!
Hope this helps!
Sep 03, 2009 | Toshiba A15-S1292 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
David Payne
David Payne
