Question about Polycom SoundPoint IP 501 IP Phone
Polycom ip501f error, application is not present
  • Anonymous Dec 16, 2008
    i have same issue
  • 24 Answers
Make sure you have the latest BootROM and SIP config files for this polycom(sip.ld, sip.cfg, etc...) on your TFTP server. If you do not have this - download from here - http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip501.html
If you do not have a TFTP server, you can download one for free.
Posted on Apr 14, 2009
  • 4 Answers
Had the same problem with with a Polycom 330.
downloaded the upgrade from this page:
http://downloads.polycom.com/voice/voip/sip_sw_releases_matrix.html
then used FileZilla, configured the client and password as PlcmSplp and set the shared folder where i had the phone software.
then i configured the phone. disabled the DHCP, set an static IP, static subnet mask, and static default gateway. and set the server user and password. rebooted the phone and it pulled the files from the FTP server.
if you need more information, you can contact me at eduardoventura81@hotmail.com.
Posted on Dec 01, 2009
I have a problem regarding my Polycom Soundpoint IP331. It doesn't boot anymore. It shows only an error which is error.cfg.
You need to reinstall all the files back onto the phone. You can get the files from the Polycom Website. You can also follow the instruction from my Polycom 501 Fixya blog to see how its done.
Jun 15, 2011 | Polycom SoundPoint IP 501 IP Phone
Polcom phones stop ringing
go to this website and go to customer support www.polycom.com
Jun 24, 2008 | Polycom SoundPoint IP 501 IP Phone
Polycom 501 phone keeps trying to reboot itself. We rebooted manually a few times and get the same error message: 'Could not find boot server current configuation" Any ideas?
try to turn off the Polycom device. When you turn it back on, press Setup. from the options, select server then click edit. Then select the item Trivial FTP (that setup depends on your ISP), and type the IP address assigned to your network (example 192.168.90.90) then hit OK. click exit several times then press Save & reboot. If it did not work, let us know...
Jun 19, 2010 | Polycom SoundPoint IP 320 SIP IP Phone
I has polycom soundpoint ip33, while booting its giving error " error loading 0004f220429c.cfg" and its not booting at all.pls guide me how to fix this problem.
Can you pls check the configuration file on the tftp server
some wrong information is there
pls compare with any other ip phone
Oct 30, 2009 | Polycom SoundPoint 330 IP Phone
Error loading 0004f220429c.cfg
This means the phone cannot find its <mac>.cfg file on the boot server, and does not have one loaded in its own flash memory.
You will need to configure a boot server to host the SIP software, BootROM, and all the config files (these are included in with the SIP software).
You can download these from Polycom's product support page:
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Aug 18, 2009 | Polycom SoundPoint 330 IP Phone
"Couldn't contact DHCP" error
Check on the router if you are distributing enough IP addresses.
Jul 30, 2009 | Polycom SoundPoint
Polycom IP 330 SIP C Will not boot up
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
Dec 16, 2008 | Polycom SoundPoint 330 IP Phone
I am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
Aug 28, 2008 | Polycom SoundPoint 330 IP Phone
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
Polycom SoundPoint IP 501 IP Phone Logo
3,405 people viewed this question
Top Polycom Computers & Internet Experts
Clive Gray
Justin
Justin
Tom Chichester
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
