Question about Sony Cyber-Shot DSC-P72 Digital Camera
Fokusing .. I have repaired my stucked lenses but along the way, made another problem. I've broken a little flat 6-wire cable that goes into the lenses. Managed to repaire that also, but now I haven't managed to have a bright focused picture in zero fokus position. Is it called bad back fokus? So , i have been told. If a fokus picture just a little bit, everything is fine. Now I am looking for service manual with zoom/lenses assembly instructions. I have an idea, what should I do, but I would rather read it first. Anybody done this or have manual? Help..
    Sergeant:
    Champion:
  • 326 Answers
Service Manual maybe is not the best solution, because in this manual there is no info for repairing the optical unit. Replacing the lens unit part number: 175892511 is the only solution. Cost for the optical is about 100 Euro (for my account) If you need more info, please advice. Arpi
Posted on Mar 17, 2007
SOURCE:
Zoom lens won't retract. Can you repair it?
May I point out that Fixya do not provide a repair service to any equipment - all the members can do is make suggestions based on their experience. It is then up to you to decide what advice, if any, to follow.
May 05, 2016 | Olympus FE-100 Digital Camera
Cable replacement on six-sheet crosscut shredder Executive Machine EPS-611X?
Fairly simple fix then; figure out what length of cable you need (or would like to have if you need something a little longer (like 1 or 2 feet more)) and run down you your local hardware outlet; a place like Lowes, Home Depot or Ace Hardware and pick up a 2 or 3 wire replacement. Make sure it is th same guage wire inside. This will involve opening the unit to install the new one. Take the head unit off, open it and see where the wires from the cable attach to. Make a drawing or take a picture of it before you take things apart and along the way so that reassembly with be easier. Disconnect the old broken cable, and connect the new one. If it is solder to a circuit board, or soldered to the switch, cut the wire back (the old one) so that you can splice the new cable to it. If it uses little connectors, you can disconnect it, and take them along when you go to get the new cable and see if they have similar connectors you can use on your new cable. Reassemble it, and test it. Should be a pretty simple fix. Let me know how it comes out. If you need any additional help, just post it here. -Coss-
Dec 10, 2013 | Executive Machines SESS640HD 6-sheet strip...
Cuts of when walking
The headphone cable maybe faulty.
To locate the fault along the headphone wire, while you are listening to music slowly flex along he cable from the headphone to the plug in your player, When the music stops then you have located the broken wire in the cable. This can be repaired by fixing the break. You may need a friend to help you repair the cable.
Apr 11, 2013 | Bose QuietComfort® 15 Acoustic Noise...
How to open sony tv remote control rm-ed008
The Sony RM-ED008 remote is opened by prising the case apart, starting in the centre of the short end that does not have the little LED. Other remotes may be held together with one, two or three screws. Don't over-tighten these screws on reassembly - they only screw into plastic.
If your remote is broken because of something spilt on it, it can usually be repaired by careful disassembly, washing in warm water, leaving until thoroughly dry and reassembling.
Remember when replacing the batteries that the spring terminal in the remote always goes to the -ve terminal of the battery and the remote's flat connector goes to the +ve end of the battery. The little dimple sticking out of one end of the battery is the +ve terminal. If the battery terminals are corroded you must clean them carefully before replacing the batteries.
You cannot see the light from the little LED at the end of the remote when a button is pushed, but your phone camera can. Point the remote at the phone and view as if taking a photograph. Press a button on the remote and you will see the light flash on the phone viewfinder screen if the remote is working ok.
Apr 02, 2012 | Televison & Video
Zoom--mm blinking and can't change mode
Your zoom motor is probably stuck. Remove the two screws on the front side of the tiltable head. Pry off the two tilt caps using a small flat head screwdriver (they are glued on). Remove the 4 screws found under each cap. Now you can separate the two sides of the head and take out the two lenses (remember exactly how the lenses were positioned). Try pushing the flash in or out (it should move with a little force). See if the flash now responds before reassembling.
Mar 21, 2010 | Canon Speedlite 430EX TTL Flash
Darkened image
same for you, please red this: "My camera is 2 years old. 6 months ago horizontal lines began appearing in all pictures" The problem is not the sensor as the first solution has been posted, the real problem is connected with the flat cable inside lenses that is broken. You cannot replace it, you can raplace intere zoom. The problem is frequently on this type of camera and direct connected with camera frequent use. The fixed and automatic diaphragm do not work bacause broken flet is broken and the sensor is receiving too mach light. Take the camera, switch it on then light with a flashlight the lens, you see a diaphragm movement or hear a click on the lens, if not the flat wire is broken (means microcut inside flat invisible without a magnifying glass). Most time same problem is present with no image on the screen because diaphragm is completelly closed.
Oct 23, 2009 | Konica Minolta DiMAGE E50 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Yep. another lens stuck.
it depends on what the problem acctually is. In my experience with cammeras such as these, a problem of this nature is not worth the trouble, but if you really like the cammera then take the covers off by removing the screws around the cammera body. Start by removing the back peace. you wont need to remove the door for the batteries or the two screws around the mount on the bottom of the cammera that hold the screw tripod mount in place. once you remove the backing you will expose at least one more screw on the side that holds the front cover on. you will want to very carefully remove the wires for the backing by pulling back the ribbon cable retainer clip and the ribon cable retainer clip must be pulled back carefully for the shutter switch as well when removing the front pannel of the cammera. Unplug the yellow wire for the micro switch in the front if applicable and then you will have exposed the lense. remove the screws holding the lense assembly in and then look around at the operation. THERE IS A CAPACITOR IN THE FRONT OF THE CAMMERA THAT WILL SHOCK YOU!!! DO NOT TOUCH THE BOARD. I've been shocked by the thing at least 3 times today so dont get all hasty. you will probably notice one of the gears are stuck or something you can buy a new lense assembly and install it but it is probably just as much as the cammera. I would sugges trying to repair it or if it is too damaged throw it away. It depends on what you find. you can look up small gears on line but it also may just need to be set back in or cleaned. You may also want to replace the cammera battery while you are in there. When removing the back pannel start from the bottom of the cammera and slightly hinge up and pull the backing away genly as to not snap the retainers in the upper part of the cammera or yank out the ribbon cable. REMOVE THE BATTERY BEFORE YOU BEGING. WITH THE BATTER REMOVED THE CAPACITOR WILL STILL SHOCK YOU. be careful.
Aug 16, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Hoizontal lines in images
The problem is faulty CCD sensor ( this device converts light into image ) so faulty sensor means either poor quality pics or no pics at all. Have sensor replaced and camera will work fine.
Sep 11, 2007 | Konica Minolta DiMAGE E50 Digital Camera
Sony Cyber-Shot DSC-P72 Digital Camera Logo
77 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
