Hi, I am receiving an E-4 error message on my FT5832 copier. I have tried shutting off and restarting the copier a few times, and this hasn't fixed the probem,. Please advise. Thanks!
Hi, press the "." button which is right next to the "0" and reply back with the numbers on the display when you do this. Then I will be able to help you.
Same Problem
Mar 12, 2009
-   need to know what to do with an E-405 error code on a Richo FT5832-   funpac
The transfer belt contact home position sensor is not activated. Transfer belt contact home position sensor defective Transfer belt contact clutch defective Main control board defective If you are not technician he is complicated lamentably will need to go to the technical service.
hi, I were have the same problem, there are sensor can't retun back to the right place after the machin on if you have few exprince, you can solve it, turn off the machin and open the back cover of the machine and see the sensor. it is in a smal motor up the dram tray to return it to the place betwen the two black sid, Be careful
if you are not a technician here you cannot do nothing because the problem is around the main motor. The main motor may be loced or some gears in the drum unit are broken. This problem can solve only official ricoh technician. But this is a old machine so if need to be replaced the motor is better to not do that because for those many you will by some new machine. I advice to call a service because if you want to operate your self you may damage something and from nothing to became a large scale problem
I have a copier that needs servicing. It is an old Xerox XC1040 model and it needs a new drum or...
(More)
I have a copier that needs servicing. It is an old Xerox XC1040 model and it needs a new drum or someone who can clean it properly. Do you have in-home service?
Hi, I am receiving an E-1 error message on my FT5832 copier.Then when i press gain to (,)to know...
(More)
Hi, I am receiving an E-1 error message on my FT5832 copier.Then when i press gain to (,)to know more about this eror i receive 41.. please give me a solution thnk u
