Question about Canon MX300 Office All-In-One Printer
Override alarm for color ink cartridge
I never use the color ink cartridge on this mx300 and would like to override the alarm which has stopped all usage of this machine. Any ideas?
  • redtaill Dec 22, 2008
    Thanks for the great tip!
  • 66 Answers
Hi Redtail,
Try the following. It will not disable the alarm but will reset the in counter.
  1. Power off the printer
  2. Hold the stop/reset button then press and hold power (for 5 secs)
  3. Hold Power and release the stop/reset button
  4. Press the stop/reset button twice
  5. Release power button
  6. Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
  7. On the 3rd press the inicator should be orange.
  8. Press the power button to set data
  9. To set data remove cartridges then replace.
  10. leave for 20 or 30 secs
  11. Press the power button again to shut down
  12. Then press power button to power up.
  13. The printer will feed one piece of paper through
  14. then set language and counrty.
  15. Then ink should be reset
Posted on Dec 22, 2008
  • vinsky0910 Jan 03, 2011
    Sam88kid, thanks for a thorough and crystal clear instruction! You nail it down and saved me a lot of headache.
Override empty ink tank on Canon PIXMA MX860
The title of this topic is for the MX860. It has no "RESUME" button, so the advice submitted by cene765 does not work. But there is a solution.
The MX860 has two black ink cartridges--one small (like the colored ones) and one large. So, you will run out of colored ink way before you run out of black. I found that by selecting the "Gray scale" printing option, I could still print with color cartridges being very low. Even when the printer told me that the color cartridges were empty, I could still print by clicking the "OK" button. However, this does not last. Eventually, the printer will flag the color cartridges with an alarm. When that happens, the printer stops working, freezing at the alarm until you replace the cartridge.
However, you can still print. What you need to do is press and hold the STOP button for a few moments. The alarm will be released and then you let go of the button. Printing can resume. This happened to me where the alarm was triggered by the cyan cartridge, before I could even try to print. When I used the STOP button bypass, printing started but was then flagged by the magenta cartridge. I thought for sure that pressing STOP while in the middle of starting the print cycle would abort it, but thankfully it did not--the alarm was cleared and printing resumed.
May 24, 2012 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Alarm on. says "check ink U163"
Hold down Stop/Reset for 5 seconds (until it beeps) to disable ink level checking. http://www.morefill.com/TechZone/TZ_TS_MFM.htm
Apr 22, 2010 | Canon MX300 Office All-In-One Printer
How can I override ink level gauge? I took my "empty" ink cartridge to cartridge world and they said there was still 3 grams of ink left, but I am unable to use it. Please help!
Works for the mx300 try it may work for you.
1. Disconnect the power cable.
2. Connect it while holding down the "power" button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button.
5. The printer turns into factory mode: wait for about 10 seconds, then it says "Idle".
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning". A test page will print..
9. Open the cover, like you are about to change the cartridges.
10. Disconnect the power cable again.
11. Take out both cartridges.
12. Close the cover.
13. Connect the power cable once again.
14. Turn the printer on.
15. Put the cartridges back.
Jan 18, 2010 | Canon PIXMA MX330 Multifunction InkJet...
I am getting a U163 check ink error, I just installed a new b&W cartridge but color cartridge is empty but still in printer.
Replace the ink
cartridge(s), or press the
OK button.
When selecting to press
the OK button, ink may
run out during printing.
Oct 11, 2009 | Canon MX300 Office All-In-One Printer
Scanner won't work
How to use the scanner with a black ink cartridge install and no color ink cartridge install, plus the alarm light is on
Sep 13, 2009 | Canon MX300 Office All-In-One Printer
I just replaced both ink cartridges and the alarm light is now on. The LCD screen reads check ink, U053, BLK COL. I can't get the printer to work or perform any functions.
On the canon MX300, holding the "reset" button down for about 10 seconds will extinguish the alarm light & should normalize all functions. The ink level will still indicate "low" , just ignore it.
Rogert
Apr 08, 2009 | Canon PIXMA MX300 All-in-One Printer
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Unable to clear alarm light
I have the same problem and happened after 2nd refill
the only answers I could find was that
  1. the copper strip with the dots could be dirty and need cleaning
  2. It could be overfilled and need ink drawn out
  3. It could just now be a faulty catridge
I tried the first 2 with no success but intent to keep trying to clean it and draw some more ink out even though it doesnt seem too full. If it still doesnt work I am going to just discard it and get another and keep re filling it as I have a second one that I use with no problems.
  • Also the printer has to be reset when a new re filled cartridge is used as it will still see it as the empty one. to do this if you dont know how.
To Reset the Canon Cartridges Works 100%
Relase power button
Nov 12, 2008 | Canon PIXMA MX300 All-in-One Printer
Canon MX300 Office All-In-One Printer Logo
588 people viewed this question
old marine
old marine
