It makes a clicking noise the faster I go the harder it sounds and if I engage the 4wd the noise stops . The sound is coming from the front diff
SOURCE: 4.7 liter jeep motor making tappinf sound and motor is missing
sounds like the lifters losed prime! here is a little trick that ive learned add a half off quirt off transmission fluid to the oil to prime the lifter
SOURCE: Loud clicking noise when 4wd is engaged on left wheel when turnin
Check your cv (constant velocity joint) , It may have a big clearance which is the source of the noise when turning left or right and when 4wd is engage. Juts like front wheel drive cars, if the cv joint is with clearance it will tend to sound in the left or right turns. It is not exactly clicking sound , nmore like knocking sound , low in pitch, but not heavy.
SOURCE: Jeep Liberty Clicking Noise
Check the wheel bearings. Run the car and check where the noise is coming from. the wheel bearings make a gravelly, clicking noise if the bearing is bad. Lift the car and move the wheels up and down , to the sides etc. Listen or if the wheel moves , your bearing may be bad.
SOURCE: Loud roaring noise in front, steering wheel has vibration, replaced tires didn't help.
Wheel bearings are likly and I've changed many to solve this problem but it's esy to pick the wrong one with e vehical jacked and on jack stands suporting the car by the lower control arms ( normal ride hieght) run the car with a driver and listen to ti run , of course theres no load on the powertrain so there will be some lash ( power on to power decline ) cheack up. The roaring noise can be isolated by puting a sounding bar ( long metal rod ( sr=crew driver)) other against the part till the sound is rounded up rear but possible the carrier bearings in the (rear end) front drive. The axel bearings and on some units the carrier bearing thats in the CV axel on the block. Sounding rod will find and change the noisey part. Professional help is a good idea if you can't carry this out saftly
On
these issue, there are few solved help links for troubleshooting the
issue easily.-------
Click
the link below: ---
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction
control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light
flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These
details will help.
Thanks.
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
4X4
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
4X4
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
4X4
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
4X4
On
Click
the link below: ---
Traction
4WD light
These
details will help.
Thanks.
On
these issue,there are few solved help links for troubleshooting the
Click
the link below:---
No 4x4 light on dash?
4X4 Truck makes roaring
noise in the front end?
Car will not go into 4WD
high or 4WD low?
4 wheel drive system will not disengage?
4WD light is flashing and
beeping? NO 4WD high?
2002 Jeep Wrangler: 4WD Idiot Light is ON?
Traction
4WD light
2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing?
4x4 front differential will not engage the
axle on ford?
4x4 will not engage on Ford F150?
http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4
light keeps flashing
4X4 LOW LIGHT
IS FLASHING ON DASH
Ford 4x4 front wheels will not engage?
These
details will help.
Thanks.
On
Click
the link below:---
high or 4WD low?
Traction
4WD light
axle on ford?
Dodge Ram 4x4
4X4 LOW LIGHT
IS FLASHING ON DASH
These
details will help.
Thanks.
