Question about HP LaserJet 1020 Printer
Printer problem Hi, Were you ever able to fix your printer spooler/installation problem? I am having the same problem and it's making me crazy!!! Please email me at ncakim@sbcglobal.net. Thank you so much for your time. Kim
  • ncakim Dec 11, 2008
    Ok here is the problem....
    When the printer is installed, it continually spits out the same print job that was requested last. However, I have tried to print other things, but I will get an error message about the printer spooler, and then it will spit out that same print job from before..not even the new job I am requesting. In addition to that, there is no print job listed in the printing queue.
    I have tried disconnecting the printer and re-installing it, but the same thing happens.
    I have been instructed to set the printer spooler to automatic, which I have done, and I'm still having the same problem.
    Does this all make sense?
    techgurus- I have no performance and maintainence icon. Is this normal? Should I try something else?
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    Could someone here post their problem and I will help you
    Master:
  • 479 Answers
To make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
pls do rate the solution if helped. thanks.
Posted on Dec 10, 2008
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
Scan problems
Hi there
Print spooler is no less than the chief boss of printing action. Print spooler is a linking part between your PC and printing hardware. Print spooler is the only master of print department of your PC office. Print spooler is a master of all printing procedurees and it’s that what is responsible for the redress printing queue and serial printing of your documents. Any messages like “Spooler subsystem app has encountered” and “Spooler subsystem app stopped working” are a unfavourable sign that you have met printer problems and need facilitate. Spooler virus is not so wide spread but it can be a reason of printer spooler service keeps stopping. If printer spooler keeps stopping our tool is a best thing to sort it out.
Fortunately I know the program which can help you to eliminate print spooler virus without extra efforts. I see Print Spooler Fix Wizard as an optimal medicine for print spoolerWhen the whole province stopped because of corrupted print spooler function it’s significant to discover an trouble as soon as possible. Don’t wait a wonder from your printer – it’s nothing without its print spooler. It’s not required to find another place to copy any documents because you can cure your own printer with the assist of Printer Spooler Fix Wizard for five minutes.
Printer problems: is it an boring chance or a reason of why the whole department interrupts its earn money? When you end your earn money sending a paper into your printing waiting line print spooler only begins its earn money. Are you really sure that high-effectively your print spooler will ever hold out against print spooler virus? You needn’t activate to buy a up-to-date printer if you have Printer Spooler Fix Wizard. So fast and effectual treatment as Spooler Fix Wizard may become a salvation of your province printing capabilities. Just as you need your printer earn moneys now and printing tasks can’t be call off we suggest you Printer Spooler Fix Wizard.
You have a choice: try perennially to cure your print spooler by yourself or get Print Spooler Fix Wizard last and all the time. Doesn’t an hour of your work cost less than Print Spooler Fix Wizard? It’s better to get high effective solution for several minutes than try to cope with printer problems manually. When you choose Print Spooler Fix Wizard you decide successful help.
All the best Pineworks
Apr 24, 2010 | Lexmark X5650 All-in-One InkJet Printer
HP print spooler problem and error 1068. Want my printer back!!!
to make spooling work its necessary to make it work
4)click system
Nov 23, 2008 | HP PSC 1610v All-in-One Printer
Printer Spooler service!
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
hi,buddy
you have to start printer spooler by this.
click "start btn"
click on "run"
write here "services.msc"
double click on "print spooler"
select status type "automatic"
than click on "start"
now install your printer.
Jul 27, 2008 | Lexmark Z645 InkJet Photo Printer
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP PSC 1400 series printer won't load
Hi Flame,
Please click on the web link given below and perform the steps as provided in the web page to fix the installation issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00625472&cc=us&lc=en&dlc=en&product=441115
Make sure that you have completed all the steps perfectly and carefully.
Please perform this additional step.
click on start >> Run
In Run box type services.msc /s and press enter.
You will see a services page.
Search for print spooler
Double click on print spooler.
Make sure that start up type is "AUTOMATIC"
CLick on stop and then start the service.
Then start installing the printer software, this should fix the issue.
Have a great day!
Mar 25, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printing blank pages
I am working on the same problem. While you will not like the
answer here it is for the canon mf6530. What is causing it
is the shutter over the laser is failing to open. There for
it blocks all exposer. A temperary fix is to carefully lift the
shutter and tape it open using black electrical tape. Then
try a few prints you should have an image if this is your
issue as it is mine. I do not recommending running it in
this condition very long. When I find the final answer I
will attempt to post it.
Jan 05, 2008 | HP DeskJet 880c InkJet Printer
click on the start button -> run -> type services.msc then hit OK
look for Printer Spooler and make it run
Dec 25, 2007 | Epson Stylus CX4600 All-In-One InkJet...
HP LaserJet 1020 Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
