Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Epson photo rx600
Suggestions for a dead display on a epson photo rx600
  • Epson Master
  • 10,695 Answers
After quite a bit of searching on the internet, I found a solution that involves soldering a "jumper" across a fuse (F1) on the board behind the LCD screen. It was tricky because the fuse is very small and I burnt my fingers a couple of times, but finally it worked. Did that several years ago and my printer is still working today.
"It is on the board located directly behind the LCD screen. I looked and looked before finding it - it is very close to a larger component and that sort of hid it - you will need a magnifier glass unless you have great vision. It is about 1/16" long and as a matter of fact, the F1 wording is bigger than the component."
Here are instructions posted by John Phillips on "FixYourOwnComputer.com:"
Steps I took – and it worked beautifully – display problem solved !!
1. Ease off the plastic facia that covers the control buttons – (no screws – it just clips on)
2. Remove the cross head screw that is seen to the bottom left of the display unit.
3. Flip display unit open – remove the cross head screw that holds the dark plastic support clip that is behind the unit and top right ish!!
4. Remove the display unit – unscrew the 4 small cross head screws that hold the display assembly together – NOTE THAT THE CONNECTING RIBBON RUNS THROUGH THE HOLE – I didn’t make a note at first, and it took me ages to work out where it went when trying to re-assemble it !!
5. Mark the connecting ribbon so that you know which way up it should be, then carefully pull it away from the black connecting block – Re-assemble merely by pushing it carefully back into place.
6. On the circuit board you will see a large (ish) black Integrated Circuit – using a magnifying glass you will see a tiny soldered fuse marked F1 just to one end of this Integrated Circuit.
7. Using a single strand of clean copper wire ( a single strand taken from a multi strand piece of speaker wire is ideal) carefully solder it across the two terminals
8. Having a soldering tip small enough is vital if you are to attempt this – an ordinary tip is TOO BIG. I used a piece of copper earth wire (obtained from ordinary “Twin and Earth” electricians household mains wiring cable) I then wound it around my soldering tip and filled it down to a fine point.
9. Re-assemble – switch on – and if you have been careful and succeeded in this feat of micro soldering – you should have a realistic chance of having a fully functioning display once again.
Posted on Jun 29, 2015
    President:
  • 2,110 Answers
If the LED display screen on your printer is blank please try disconnecting
the USB cable from the computer and then disconnect the power to your
printer. Reconnect the power to a different power outlet, and turn your
printer back on. If the same issue occurs, your printer will require
service.
Posted on Dec 04, 2008
My epson stylus photo RX600 says Scanner error occured. What do I do to get printer working again?
Hello, all you have to do is to reinstall the printer software in the system, so it can repair any error that is occouring
Mar 27, 2011 | Epson Stylus Photo RX600 All-In-One InkJet...
Display is dead on a epson photo rx600 any suggestions?
Go to http://www.fixyourownprinter.com/forums/printer/30847
and scroll down for suggested fix - bridging a fuse link with wire or a repalcement fuse. This appears to be a really common problem
Hope this helps
Dec 04, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson printer -parts at their end of life!
Where can I find ink pads for my Epson Stylus Photo Rx600 ?
August
Doodlehyde@juno.com
Jul 29, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Rx600
Here is a link to the Epson printer RX600 support page which has downloads of latest printer drivers for your unit.
Did you remove any type of protective material that may be on the cartridge before installation?
Apr 26, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
The printer will not scan
have to installed the software that came along with it ? Can you make sure that
1. the lights in the printer glow as they used to..
2. The software that came with it is uninstalled and reinstalled again.
This usually does the trick
- Ranjit
ranjit@supportminds.com
Nov 02, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Sylus Photo RX600
press the on, stop, color & b&w buttons at same time and hold them down for awhile......seams to reset everything....good luck
Oct 23, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
131 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
