Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Display is dead on a epson photo rx600 any suggestions?
We have an epson photo rx 600 with a dead display.
any body know what is going on?
  • Epson Master
  • 11,722 Answers
Thanks to John Phillips who responded on the FixYourOwnComputer.com about how to fix this problem. I followed the instructions and my Epson has been operating for several years without further problem:
1. Ease off the plastic facia that covers the control buttons - (no screws - it just clips on)
2. Remove the cross head screw that is seen to the bottom left of the display unit.
3. Flip display unit open - remove the cross head screw that holds the dark plastic support clip that is behind the unit and top right ish!!
4. Remove the display unit - unscrew the 4 small cross head screws that hold the display assembly together - NOTE THAT THE CONNECTING RIBBON RUNS THROUGH THE HOLE - I didn't make a note at first, and it took me ages to work out where it went when trying to re-assemble it !!
5. Mark the connecting ribbon so that you know which way up it should be, then carefully pull it away from the black connecting block - Re-assemble merely by pushing it carefully back into place.
6. On the circuit board you will see a large (ish) black Integrated Circuit - using a magnifying glass you will see a tiny soldered fuse marked F1 just to one end of this Integrated Circuit.
7. Using a single strand of clean copper wire ( a single strand taken from a multi strand piece of speaker wire is ideal) carefully solder it across the two terminals
8. Having a soldering tip small enough is vital if you are to attempt this - an ordinary tip is TOO BIG. I used a piece of copper earth wire (obtained from ordinary "Twin and Earth" electricians household mains wiring cable) I then wound it around my soldering tip and filled it down to a fine point.
9. Re-assemble - switch on - and if you have been careful and succeeded in this feat of micro soldering - you should have a realistic chance of having a fully functioning display once again.
- jegohio
Posted on Sep 19, 2015
Go to http://www.fixyourownprinter.com/forums/printer/30847
and scroll down for suggested fix - bridging a fuse link with wire or a repalcement fuse. This appears to be a really common problem
Hope this helps
Posted on Jan 31, 2009
My epson stylus photo RX600 says Scanner error occured. What do I do to get printer working again?
Hello, all you have to do is to reinstall the printer software in the system, so it can repair any error that is occouring
Mar 27, 2011 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus RX 600 printer, copier, scanner
What error are you getting ?
Need more information regarding your problem .
Oct 28, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
My Epson Stylus Photo RX 600 had been working fine until yesterday, when I tried to use it it wouldn't print or scan. It says "Cannot read memory card or storage device" All the wires are connected and...
when the machine is powered off and power cable has been removed, try removing all dust and foreign objects from the card reader with compressed air. disconnect all unnecessary cables and retry the print/scan job. if this doesn't work, either the card reader or the system board is defective (most likely the card reader)
Sep 27, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson printer -parts at their end of life!
Where can I find ink pads for my Epson Stylus Photo Rx600 ?
August
Doodlehyde@juno.com
Jul 29, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson RX520 feed problem when using glossy photo paper
clean the rubber rollers that pull the paper. hoping it 2 work fine....
Jan 13, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Sylus Photo RX600
press the on, stop, color & b&w buttons at same time and hold them down for awhile......seams to reset everything....good luck
Oct 23, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
241 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
