Question about Indesit WA 115 Front Load Washer
Indesit washing machine wi101
You put it on the programme and it fills sometimes ,and just clicks continously and the timer goes around to every click?? I checked the board and all connnections seem ok and there are no hairline cracks?? Pump is fine but maybe i need to check the heater element as I saw a bit about where the timer won`t advance but on newer models maybe its a bit confused. I can`t seeing it being the timer! Please can you help cause we don`t like the washing to pile up!!lol thanks I`ll appreciate it.
I have the same issue, have just returned from a 9 month break and now the washer does the click thing, but if you open and close the door a few times and set to program 4 is seems to work after about 10 minutes! It was perfect when I left, not 18 months old either. Can see it being the timer either, maybe a pickup of some type not detecting a level? Peter
Posted on Feb 10, 2007
  • Peter Martin Feb 12, 2007
    Hi Fixed it!
    Took out the PCB board from the back, at the bottom on the left as you look at it from the back. Unclipped the wires, opened the unit, took out the board, re soldered the contacts on the relay's. Used some servisol on the connectors and wire sockets, put it back together and all works!!!
Indesit WA6x washing m - dial clicking around...
This sort of problem is usually associated with a faulty control board
If there is a reset point on the timer, then reset it, and try again, if it still does the same thing, then it it is going to be the control board.
Mar 22, 2010 | Washing Machines
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
hiya
the fault code will be displayed by the number of flashes that the doorlock light makes, if you can count them and let me know i'll be able to diagnose the fault, i think you are on the right lines with the heater, but it's best to check and make sure.
another little tip for you, if the washing up liquid causes lots of bubbles that you find hard to remove, set machine on a rinse cycle and add some fab conditioner, this will rid the machine of all the bubbbles.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Washing machine wont do anything
rotating timer knob indicates that there is a fault, obviously, so its a case of going through a checklist, based on info given, check in this order, outlet pump, for open circuit, then heater element for open circuit, then maybe the water valves, you have given little information for me to go on as an engineer, please understand, the more you say the more detail we can give ..... ok cheers with looking for the fault, best of luck and work safe
Dec 21, 2007 | Indesit W 123 Front Load Washer
Indesit w123s on daily wash program no8 it starts to fill stops and emptys then starts clicking around on the selector knob the only way to reset it is to switch off and leave for a few minutes all the...
you need to open up the small door where the filter is and clear it out. Mine does this everytime my son puts his trousers in the wash and forgets to empty the pockets! we've had all sorts, elastic bands, wrappers, and money. Usually the machine still has water in it as the filter is blocked it won't continue the programme until this is clear and thats why the continuous clicking happens.
B. Green.
Nov 03, 2007 | Indesit WA 115 Front Load Washer
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Indesit wd12s washer dryer
after all you have checked out I think it must be a programmer fault. Sorry I dont know how to check it out for sure
Oct 24, 2007 | Washing Machines
Indesit WA 115 Front Load Washer Logo
210 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
