Question about Compaq NC6000 Notebook
Battery question for compaq nc6000
I just received a new "used" battery and it's different than the original. Original battery is10.8V 4.4 AHr and the new "used" is 14.8V 4.4AHr and is labeled:
FOR USE WITH COMPAQ SERIES PP2140 FAMILY OF COMPUTER PRODUCTS ONLY.
Should I throw the battery away (I mean recycle) or can it be used?
    Genius:
  • 1,061 Answers
No voltage is wrong. please recycle.RICHARDM69
Posted on Dec 04, 2008
    President:
  • 2,110 Answers
No it cant be reused...
Hp nc6000 when pushing on , it will on orange light and off againg
1,check power supply.
2,check battery.
3,check the fan is trying to run.if its not it may need cleaning.
4,over heating can stop it from starting.
Jun 27, 2014 | HP Compaq nc6000 Notebook
What the solution of laptop hp compaq nc6000 when turn on won't start up
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/original-hp-compaq-nc6000-ac-adapter-65w-cord.html
http://www.chargerbuy.com/replacement-hp-compaq-nc6000-ac-adapter-18-5v-3-5a.html
Nov 13, 2012 | HP Compaq nc6000 Notebook
Software forfeit
Call the software company
Feb 28, 2010 | HP Compaq nc6000 Notebook
Hi,My HP Compaq nc6000 just developed a problem of not coming on. I have checked the battery and its okay. I have blown its internal parts and it remained off. It only indicates the orange light for some...
try taking the battery out completely and see if the laptop runs of the main power from the outlet, if so then the battery may have a bad cell in it and would need to be replaced.
Primary Batteries
6-cell Lithium-Ion (4.4Ah) – standard
8-cell Lithium-Ion (4.4Ah) – optional
Power SupplyExternal 65 watt AC adapter
from looks of it the battery has gone bad
http://www.laptopbatterystore.com/product/2151/compaq-business-notebook-nc6000-batteries?utm_source=GoogleProducts&utm_medium=CSE&utm_campaign=Compaq/HP&utm_term=HP18S6-Compaq-Business-Notebook-NC6000-Battery
Aug 20, 2009 | HP Compaq nc6000 Notebook
No usb
If your USB ports are installed correctly and enabled in BIOS, you will see Universal Bus Controller list in the the Device Manager. Double-click your USB in the Device Manager and a dialog box will appear. Click on the driver tab and update the driver. To get to Device Manager right-click on My Computer>click on Hardware>Device Manager. If your computer has a built-in USB device and does not detect the device through the Device Manager, confirm that the USB is enabled in the computers BIOS and that the BIOS supprts USB devices.
Dec 29, 2008 | HP Compaq nc6000 Notebook
Cant get past power up on my nc6000 hp
Here's how to do it. Read this forum link:
http://www.techimo.com/forum/mobile-computing/126058-hp-compaq-nc6000-problems-4.html
There's a few things you need to do besides removing the CMOS battery. Get a couple of small screwdrivers out, you are going to need them.
Nov 29, 2008 | HP Compaq nc6000 Notebook
Charger Voltage and Watt Differences
it hardly matters if u are using a 90 watt adapter instead of a 65watt
it will charger the battery much more faster
so you can use it
it should power on your system without the battery.... just check that first
Jun 07, 2008 | HP Compaq Presario C304NR Notebook
HP nc6000 windows hangs up during installation
Did you check the memory? Sounds like the memory has went bad. Is it noticing all of the memory? Even if it is noticed it could still be going bad or the slot could be going bad. I have seen this happen. Are you positive that the hard drive is not bad. Did you run any test on the hard drive?
Jun 06, 2008 | HP Compaq nc6000 Notebook
Battery Problem?
HI,
Compaqs rely on a decent battery.
You could try removing the battery and see if it boots at all.
If it does,nt this will answer your question.
Suggest e-bay for a replacement, the chinese sellers offer great items for replacement, usually cheaper than U/K sellers. shipped and received within 10-14 Days.
Regards mike @ compurepair.
Mar 28, 2008 | HP Compaq nc6000 Notebook
Compaq NC6000 Notebook Logo
162 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
