Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Saw will not start Husqvarna 350
I set the chainsaw down in the snow while it was running and when I went to pick it up it was shut down. I could not get it started again.
  • 1 more comment
  • erisbucky Dec 05, 2008
    After three pulls compression was at 95 lbs and when I put oil in the cylinder I could only pull two times and it was at 90 lbs. It has spark and I put gas in the cylinder it may fire once, but not start. I even took the fuel filter off and that didn't work. It hasn't been that long since it has been rebuilt.
    I can smell gas on the plug.
  • erisbucky Dec 10, 2008
    The saw had spark, but the coil was still bad. It would hit once, but would not start. I took it to a place and he put a used coil in it and it ran good. He than put the original coil back in and the results were the same as before.
    Again,
    Thank you
  • 211 Answers
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Posted on Dec 05, 2008
  • Savu Mihai Dec 05, 2008
    Hi
    Take off the plug wire terminal from the sparkplug.Pull the starter few times.Check if the sparkplug has gas on it.If so there is still a fuel delivery from carb.There are a lot of prts to be checked.Get in touch.
    cheers savumihai71
    Hi
    The sparkplug in that condition has to be wet of gas(not smell).If the engine has spark and the fuel/air mixture reaches the spark plug the engine has to explode.
    regards savumihai71
I have a husqvarna 345 run for a few cuts then stops.
either blocked fuel filter in the fuel tank ( hook out and replace ) or the fuel tank breather is blocked thus causing a vacume in the tank, to prove this, when the saw starts to die slacken off the filler cap, this will allow air into the tank and it should pick up again, the breather is pressed into the tank on the r/h side rear.
Sep 19, 2012 | Husqvarna Forest & Garden No.967012396 345...
. Have a 350 Husqvarna chainsaw which idles
This sounds like fuel starvation, replace the fuel filter in the fuel tank, if this does not help, when it starts to die just slacken off the fuel filler cap, if it picks up and runs normaly then it is a tank braeather issue, the breather is on the top right hand corner of the fuel tank, replace it.
Oct 06, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a husqvarna 350 that wont start, wondering if anyone can tell me what is the factory compression rating?
Hi and welcome to FixYa, I am Kelly You should have 120 PSI or greater compression. There is a ported compression release so you may see as little as 110 PSI but it is best to see 120 or greater.
The Owners manual is here:
http://www.northerntool.com/downloads/manuals/195946.pdf
carb basic settings are on page 29 of the manual.
The saw has a Zama C3-EL18 carb.
The manual for the carb is here:
http://www.zamacarb.com/pdfs/TechGuide_2007.pdf (Click and wait 2.50 mb)
Your carb is the C3
The workshop manual for the saw is here:
http://www.scribd.com/doc/8152011/Husqvarna-Chainsaw-Workshop-Manual-340345346XP350351353 (Must have a facebook account to download but can be viewed online)
Thanks for choosing FixYa,
Kelly
Sep 23, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I have a 350 husqvarna, starts up fine, runs fine when at half throttle, when u put into full throttle it lacks power and backfires, go back to half throttle runs fine
This is classic fuel starvation, start by removing the fuel hose from the tank and replace the filter on the end, if no better, it may be a tank breather issue, when the saw starts to die slacken the fuel cap, if the saw picks up you need to replace the breather, if no better you can make a small adjustment to the H screw on the carb, unscrew ( counter clockwise ) the H screw this will richen the mixture, you will need to pull the anti tamper sleeves back on the screws, this can be done by gently screwing a suitable self tapping screw into the sleeve, when it hits the screw head under neath the sleeve will start to pull back, once pulled half way off you can enter a 2mm screw driver through the centre if the sleeve and intp the slot in the adjuster screw underneath.
Mar 01, 2011 | Husqvarna 350 Rancher Chain Saw
My husqvarna chain saw will start fine and run good and cut good for a few minutes then it will start running fast then slow down run fast slow down it will do that 3 or 4 times then cut off any idea...
It certainly sounds fuel related, remove the fuel hose from the fuel tank and replace the filter on the end, try the machine again, if it is no better it could well be an issue with the fuel tank breather, to test this run the saw until the problem starts to occur, slacken the fuel cap enough to allow air into the tank, if the machine picks up and runs well you will need to replace the tank breather, let us know if this works and i will will go through how to change the breather.
Feb 09, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
How to start a Husqvarna 445?
Set choke to full on. To do this depress throttle all the way down and set choke lever to on. Pull starter rapidly until saw fires . Once it has fired set to start and pull starter cord until it starts. If it doesn't start in ten - twelve pulls,reset choke for two or three pulls,then switch back to start. Pull starter cord until it starts. When it starts it wii be at full R.P.Ms. Let run for twenty to thirty seconds. then move switch to run. Hope his helps, Thanks
Nov 18, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
Reference the Husqvarna 350 chainsaw. Why does the chain continue to turn at idle? I just installed a new clutch. Adjusting the idle down causes the saw to shut off upon trying to accelerate.
Sounds like the clutch is still grabing. Easy solution is to apply the chain brake at idle to stop the chain turning. Try adjusting the L screw for a smoother idle.
Aug 05, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
350 chainsaw will not start and run, getting fuel
check set screws on the side of carb turn the all the way in the turn out till idles or check the screen in the muffler
Feb 03, 2010 | Husqvarna Garden
I have a Husqvarna 350 (1998). Just replaced cylinder and dismantled the saw for a complete wipe down. After reassembly, the saw runs great if I start with a squeezed throttle. Will not idle at all. Help!...
Kinda hard to hook up the throttle rod incorrectly. When you replaced the piston did you notice which way the arrow on the piston head pointed. It should point towards the exhaust. Also, you probably should have replaced the two crank seals just to be on the safe side. Sometimes, those little creatures can cause total agony and most guys do over look them.
Jul 05, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
591 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
