Question about HP Compaq nx5000 Notebook
Nx 5000 dual screen problem
Hi I amtrying to setup dual screen for a couple of these laptops .the setup works like this : user will use a external screen and his laptop screen and will be extended onto the external screen If the setup is done and external monitor connected ,you can reboot and will work fine ,will pick up external screen dual view works cool if you shutdown and take out vga cable of external screen and switch on laptop and only work on laptop screen at home ,come back ,place vga cable back in laptop you have to manually enable the extended option so that external screen works again .it does not keep the configuration of how external monitor works .I have updated bios to latest ver as well as the intel graphics controller (82852/82855 gm/gme)controller but still doesnt keep settings .Does anybody know this prob and a solution for it?
    Novelist:
    Champion:
  • 202 Answers
What program are you using for the dual setup? Place a shortcut in startup. usually an external monitor is used in place of the laptop LCD. The Monitor may need to be #1 and the laptop LCD#2 http://www.intel.com/support/graphics/intel852gm/sb/cs-009064.htm?iid=search& This site may help too. Good Luck, Tim
Posted on Feb 08, 2007
SOURCE:
I have laptop hp compaq nx 5000, its DVD drive is not working when I connect external DVD drive it does not shown in my computer and show error message og hub power surge problem. Kindly guide me how to...
external devices must be formatted to work properly. You can try to roll back your onboard dvd driver to an earlier version and possibly by doing so it will once again work properly
Aug 12, 2010 | Computers & Internet
Using an external monitor with 1920x1080 resolution in my laptop
Well IF the Drivers support it then YES you can. Simply, make sure that the setup, is dual monitor, with extended desktop, active. Now, go into properties, and click, on the external screen, IF you can set this resolution, to what you wish, you will be able to do so. Both Monitors Do NOT have to be the same, usually, a laptop['s screen, resolution, isn't that large, but certain, screens and drivers, can support this. Ensure you have the most up-to-date Video drivers, for your Card.
Apr 04, 2010 | Dell Inspiron 1150 Notebook
I have a 5515 Acer Laptop. It was working Great. I installed an AT&T sim usb for internet. It said it was installed successfully and to restart the Laptop. I restarted laptop and now the keyboard is...
theres a couple of options.
1:) you could try using an external USB keyboard.
2:) you could try inserting a system restore CD, into the CD/DVD drive. when prompted use the repair console, or roll-back to a previous installation.
3:) obtain a replacement hard-drive, setup windows. to get the system up and running, then connect your original hard-drive, via an external adaptor. and copy any required files. From external to new drive. Finally. If you can access the laptops CMOS Battery. remove it, and clear the settings to thier default Values.
Mike @ Compurepair.
Dec 01, 2009 | Acer Computers & Internet
Res sir i have a laptop nx 5000 and probelm is
if screen is blank, that doesn't means that u've to replace ur screen.
Can u see BIOS screen when u start ur laptop ?
if yes then its ur operating system's problem. and if u cant see the BIOS screen, try to contact HP Assistance service.
Aug 29, 2009 | HP Compaq nx5000 Notebook
Hooking 2 monitors to laptop?
Only way is to replace your lcd screen if you dont want to spend on a external video card,heres a parts break down of your machine ,
http://supportapj.dell.com/support/edocs/systems/ins8500/en/8500/sm/system.htm#999507
Cheers Misterdj
Honestly buy the external card or a second 8600 and transplant the lcd
Please rate me thanks
Aug 12, 2009 | Dell Inspiron 8600 / Latitude D800 /...
Hp nx 5000 - memory problem
The memory modules are located at the bottom of the laptop under one of the panels.
The memory modules may be OK and may only need reseating. Then boot up the laptop to see if it works, if it doesn't work, the memory may be faulty, take it to a computer shop to get it tested.
Apr 07, 2009 | HP Compaq nx5000 Notebook
Laptop dispalys to monitor but laptop panel cannot be activate
Thanks for all the details..
The issue seems to be with the video card drivers here...
Go to www.hp.com/suport and download the latest video card and the chipset drivers
before you download ...uninstall the nvidia chipset or any display software from program and features.
after you have installed the software.. go to the nvidia control panel > setup multiple monitors. and browse throughout the options >
It should be dual display and not extended display.
Also try with a new user profile...
Hope this helps..
Regards,
Anup
Apr 05, 2009 | HP Compaq Evo n610c Notebook
Toshiba Satellite Laptop refuses to allow Dual Monitors
I have an A105 set up on dual screens, and it works great. As I recall, you have to do the dual screen setup in the control panel, display, settings.
Mar 17, 2009 | Toshiba Satellite A105-S4074 Notebook
Acer Aspire 3680 Cracked Screen *help*
Hi there
yes you can plug an external monitor to the laptop, the screen switch keyboard toggle is hold down Fn and is should one other the F keys with a monitor icon on it, just press that to activate the external monitor
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Acer Aspire 5050-3242 Notebook
When you turn it on nothing happens
I just bought a lap top and no nothing about them it is a hp compaz nx 5000 I turned it on and the screen is still black don't know how and where to turn the monitor on
Apr 05, 2008 | E-Machines M5310 PC Notebook
HP Compaq nx5000 Notebook Logo
127 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
