Solved plroblem of microprocessors
All miroprocessor problems and answers
42 :-D
Posted on Dec 24, 2008
Solve the plroblem in di 620
The 13xx - printer engine malfunctions
13F0 -400 dpi SOS sensor detection failure.
13F1 -600 dpi SOS detection failure.
13F2-universal tray adjustment failure maximum.
13F3-universal tray adjustment failure minimum
13F4-optical system out of adjustment
Dec 15, 2013 | Minolta DiALTA Di520 Laser Printer
Powers up but only cd function and volume function works manually
I worked in a Sony warranty center for years...these units had a manufacturing problem that would cause many problems to arise...the grounds inside the unit would not make proper connection and cause all sorts of problems...this sounds like it may be the problem, of course there may be other causes too...simply put, if you know how to solder, then you can try to fix the unit yourself...you need to find the grounding screws that ground the circuits inside, then you will need some pieces of wire to "bond" all of the grounding points together. If that does not solve the problem, then the problem may be either in the switching IC or possibly the microprocessor...If the microprocessor is bad then I wouldn't even consider fixing as the cost of a microprocessor is veery high
Dec 19, 2010 | Sony STR-DE345 Receiver
Since i switched to comcast cable and added an on demand dvd box
you have a problem with the cable box. If you have a dvd player hooked up you can play a movie as a test, but I'm sure you will find that the dvd plays fine because the audio plroblem you are describing is a common issue. Also you can try to unpug your cable box power for thirty seconds that will reset it and it may solve the problem.
Apr 05, 2009 | Vizio VO47L 47 in. LCD TV
New Blackberry came without the application such as Help, Blackbe
Once you get a blackberry email account set up through your phone you'll have to turn your phone off then on and then your phone will automatically download and update itself, and you'll have your applications :)
Mar 18, 2009 | RIM BlackBerry Pearl 8100
Caller ID doesnot attear
Sorry it took so long to get back to you with a answer to you problem. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Nov 21, 2008 | Emerson Smartset Clock Radio
Cordless handset phone will not connect to base
A Microprocessor Problem, beyond ecconomical repair.
AL
Sep 16, 2008 | Sony SPP-A2780 Cordless Phone System
Smarset clockradio
Sorry it took so long to answer your question about the Clock/Radio. This look like a problem with the Clock/Radio's Microprocessor. You will need to reset the microprocessor by removing all power sources to the microprocessor. This means removing the Clock/Radio from the A/C power source and removing the internal battery (CR2430). After removing all the power sources from the Clock/Radio, let the Clock/Radio set for a period of about 3 hours. This will let the power completely drain from the microprocessor and reset it to the factory settings. You can then reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio should have reset and the functions returned to normal operations. If The Clock/Radio functions have not returned to normal. You will need to let the Clock/Radio's microprocessor drain off the power again and put a new internal battery (CR2430). Then test the Clock/Radio's functions again. The Clock/Radio functions should have returned to normal operation. If you are still having problems getting the Clock/Radio to return to normal operation. You can call the Emerson customer support at this telephone number 1-800-909-1240- Call them between the hours of 8am to 4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for their assistance. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Apr 29, 2008 | Emerson Smartset Clock Radio
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
Dec 17, 2007 | Emerson Smartset Clock Radio
Monitor problem
Hello Pappa, From the way u state it is not clear which monitor u r using. Any ways let me guess u r using a 15" Samsung monitor ( possibly 56v). It can only be the problem relating to your microprocessor inside the monitor ( Either the microprocessor or the section relating to it).
May 12, 2007 | Samtron MONO TTL 13 Monitor
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
