I have a digital TV with an outside antenna and rotor.I rcv analog channels w/o any problem.I can rcv channel 19.1 on my TV and on my old TV with a converter box. I have gone to antennaweb.com to get the proper orientation of my antenna.I CAN'T rcv any other digital stations!! My neighbor(two doors up) rcv digital TV with an antenna smaller than mine.I have tried bypassing the splitter from my antenna,using a signal amplifier ,but nothing works! I even tried using rabbit ears-no dice. I live in Benicia ,CA 94510 and rcv both San Francisco and Sacramento analog beautifully. What else can I do(other than going to cable or dish)
  • 4,889 Answers
You will probably need to get a digital HDTV box from your service provider. This would be the easiest fix to resolve this issue. You can get a box for as low as 35$ and its definitely worth it.
Posted on Dec 04, 2008
    Genius:
  • 1,011 Answers
Sir,
may be the rc cables have fault. check the cables.
thanks
  • 734 Answers
If you’re using a directional indoor antenna, like rabbit ears, then it might be as simple as switching to a multi-directional indoor antenna that's designed specifically for digital reception. These newer antennas are flat and may be amplified.You might have to upgrade to an outdoor multi-directional antenna if you're receiving a bad signal due to proximity to the transmission tower or obstacles blocking the signal. Antenna Web is great resource for finding the right outdoor antenna for your address.
If you know your antenna isn’t the issue then you might need to change the coaxial cable connecting the antenna to the tuner. RG6, preferably quad-shielded, is the recommended type of coaxial.
It’s possible that the digital signal is coming a lower point on the tower than the analog signal. This is a line of sight issue. Once analog disappears the signal should go back to the top of the tower.
  • futureloginn
    futureloginn Dec 04, 2008
    for further help follow the following link -----
    http://tv.about.com/od/frequentlyaskedqu...
    Thanks
  • futureloginn
    futureloginn Dec 10, 2008
    Thanks
  • 2,335 Answers
Some TV tuners might not be very sensitive to the OTA HD signals and that is why you're not picking up all the available digital channels.
I've experienced with two different brand of HD TVs. One is a sharp LCD picking up more HD channels then an Insignia LCD even with a rabbits ears.
    Sergeant:
  • 217 Answers
The frequency catcher of the antenna may be weaker then required.to receive the digital channels u can attach a network booster which will solve the problem.
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
I have a 19" magnavox
Do you have a digital converter box. If not, you need to get one to receive the analog channels.
Feb 06, 2011 | Televison & Video
I live in Victoria Tx. I can not afford cable or dish. I am able to recieve all 4 of the the number 25 channels. Why am I not able to recieve any of the three number 19 channes. All 19 and 25...
Channel 19 actually broadcasts on VHF channel 11 (approximately 201MHZ) and channel 25 actually broadcasts on UHF channel 15 (approximately 479MHZ). I know that sounds a bit weird but it has been done so that stations don't have to change there "call" channel number when we switched to Digital TV. Your digital converter box keeps track of this. This is important to understand because you need and antenna that is good at picking up both UHF and VHF signals. If you're not getting channel 19 it may be due to a poor VHF portion of your antenna. If your using a basic old set of rabbit ears for your antenna that has a loop in the middle then I might have a trick for you. Most rabbit ears have 2 telescopic antenna elements. Extend or collapse until each length is 14.7 inches long. (Which is a quarter wavelength at 201MHZ). You are effectively tuning (Optimizing) your antenna specifically for that channel 19. You may need to rotate your antenna a bit to find the best signal.
There are other factors which can hinder you receiving channel 19 but this is a good starting point. Let me know what type of antenna you have. Hope this helps.
Dec 03, 2010 | Insignia Digital-to-Analog Converter for...
Can't program digital channels only has analog option
If your TV does not have a digital tuner, you'll need a digital converter box.
After the digital switch in June, did you have channels then? If so just do a rescan.
Jan 11, 2010 | Broksonic CCVG1935 19 in. LCD TV
How do i cahange my reception From analog to digital?
The Dynex LCD-19-09 19in LCD Tv has a digitial tuner in it already. I would recommend doing a channel scan and make sure it is on the "Antenna" setting instead of "Cable" and let it scan for channels. You will see all the analog channels like "7", "12" if they are still broadcasting, however, if you can pick up the digital channels, it will look more like "7-1" or 12-1; 12-2 etc.". To get to this, push the "Menu" button on the Dynex remote, then arrow down twice to TV, then push the right arrow and make sure it is set at Antenna and do a channel scan. Should get you whatever digital channels are available. If the digital antenna is not strong enough, you will need to get the digital one at Wal-Mart as previously suggested and hope that will convert the analog channels in your area.
Jun 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Cancelled dish & hooked up rabbit ears. no local channels
Digital channels require a really strong signal to work well compared to analog. Can you get any analog channels through the tv itself? You will probably need to get a large antenna mounted outside to get these channels to work especially if you are a distance outside the city from where the broadcast is coming from. Sorry for the bad news. It is one of the bad things about the digital transition.
Benjamin
Mar 25, 2009 | Insignia Digital-to-Analog Converter for...
NEw TV antenna fails to capture all local channels
Dear Shoostar, 6:55 EST (USA)
It may be that those stations are only broadcasting in analog for now and since your using a digital converter the signal can't be read.
Did you try using the old antenna to get those stations?
If this is the problem you could use both antennas with a switch when you want to change channels for now until they all go digital.
I once used two antennas and a 4-pole switch to get Philly & New York from Jersey instantly back in the day.
I didn't like waiting for the antenna rotor to turn into place!
Hope this is helpful.
jack
ac2c3d4.jpgPlease Rate This!
Feb 09, 2009 | Leadtek Televison & Video
Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
Dec 06, 2008 | Dell W4200 42 in. HD-Ready Plasma...
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Televison & Video Logo
209 people viewed this question
Top Televison & Video Experts
