Question about Zebra 110Xi III Plus Thermal Printer
Printer = Zebra TLP 2844-Z Problem = will not calibrate
The printer should find the space between labels and auto skip that. When I print from a roll of 3 X 1 labels, the printing "walks" downward because the printer is not skipping the gap between labels. I understand teh Zebra should find that gap automatically but mine is not.
  • mike_ralls Dec 05, 2008
    Looks like printer calibrates OK but as soon as I run in a print job, the printing again prints 1in apart tather than 1in plus the space between the labels?
  • Anonymous Mar 19, 2014
    2844 ctp. printing direct on 4x6 label with 1/8 gap. printer wants to send a blank after every label. Calibrated multiple times to no avail. I get an orange light after printing.
    Problem Solver:
  • 5 Answers
Just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
    Problem Solver:
  • 5 Answers
Mesure the label size accurately .and put the same size in print drivers.improber label size declaration may giv same problem in printouts.
1.go to the printer driver proberties by start->settings->printer and faxes ->right click the driver
2.select printing preferences
3.then costomize the label size(enter accurate size)
4.then go to document option
5.change to use printer settings (if itz in use driver settings.u must change to printer settings
then giv the test print
Posted on Dec 07, 2008
My printer Zebra TLP 2844 kep many Space how can i fix
possible calibration, press buton until flash 7 times. Turn off, turn on Try again.
Aug 02, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Tlp 2844 printer is callibrating is proper but not getting the print in stickers & checked the ribbon.
You need to set the label size in the driver or it will not layout on the calibrated label correctly. the default zebra size is 2x4 so if you have a smaller label it will print across 2 labels as the driver thinks it has a 4 in long label
May 17, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Using tlp 2844-z
hold the green feed button down intill it flashes 4 time to default the printer and calibrate it
Apr 07, 2010 | Zebra TLP 2844-Z Thermal Label Printer
I can't feed the new label roll into the printer on a Zebra 2844-Z Thermal Printer. I don't want to batch.
Label rolls for TLP-2844-Z are wound out, the roll will come over from the top and feed through the two paper guides. If you are using fanfold feed through the slot at the rear of the printer.
Mar 24, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Can t print labels they are not align zebra 2844
Press and hold the feed switch and when you see 4 flashes, release the button. The printer will calibrate and you should be able to see the labels align
Oct 26, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
Jun 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Dec 08, 2008 | Zebra LP 2844 Thermal Printer
Zebra tlp 2844 trouble
Verify that the ribbon fits into position, back and forth. You can also calibrate the label by pressing the button while powering up the printer and release the button.
Aug 02, 2008 | Zebra R2844-Z Label Printer
TLP 2844 skips over labels
The first thing I would do is to default the printer then run a width calibration. The instruction are in the user's manual that should have come with the printer. If the instruction did not come with the printer I can provide the instruction.
May 07, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 110Xi III Plus Thermal Printer Logo
3,264 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
