Question about Philips Epic 17PF9936-37 17" Flat Panel LCD Monitor
TV will not turn on!
I have a philips 17" LCD Flat TV, model # 17PF9936. Is there a bulb that I can replace, or any fuses that could be bad? Where might I find part numbers for replacement bulbs/fuses etc.?? Before tearing into this, I wanted to gain any advice possible, since I do not have any schematics or service manuals. I would appreciate any and all advice, Thanks!!
  • 1 more comment
  • Muzza996 Feb 23, 2008
    Mine has finally stopped working. When switched on the sound was present but it took up to 10 mins to show the picture. The picture displayed and then started rolling, then switches its self off. I have a red light pulsing. Any ideas as i dont want to scrap it, i cant find a repairer anywhere?
  • giomichsa Dec 30, 2008
    Since I conected the wii my Philps Flat screen Tv stopped working. The Tv does not turn on. As soon as I press the power button a green light comes on, but a second later a flashing red botton remains on. The remote control does not work at all even though the lights light up. Any advise for my problem. Thx.
    gljhgljh
The part that went out on mine was a wire harness. And fixed it and now it works.
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5645793&smodel=17PF9936/37
Posted on Jan 14, 2010
No picture on Philips LCD TV
One very common problem encountered on many Philips models, old and new, In some cases, the SSB board has to be replaced as the resistor on the PCB on the back of the CRT had to be fixed. In other cases the Y Sustain board had to be replaced. If the problem is not due to these two issues, then the capacitors will need to be replaced as they only have a fixed guaranteed life. Thus, it would be wise to take out an extended warranty on Philips due to this common repair issue which often occurs after the limited warranty has ended. Or you could just call your local repairman. There are lots of websites on how to fix it yourself on google. There could be many reasons. Hope this helps!
Apr 14, 2010 | Philips 17PF9945 17 in. LCD HDTV
Screen is blank
Hello
The issue might be that your monitor is not getting enough voltage to turn on properly.
If the monitor is plugged into a surge protector, remove it and plug it directly into the wall outlet. If the monitor works fine, the surge protector is not allowing enough power thru it for the monitor to work correctly - replace the power strip.
If there is no change, then your monitor is going out.
Dec 03, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Opened my unit, a Philips 17PF9936-37 17" Flat Panel LCD Monitor.
if the unit is not powering on at all then it is the power board (the one with the voltage coils, if it is powering on then replace the board with the two heatsinks(video board.)
Aug 29, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
How to replace lcd tv bulb
Most of those models you replaced them through the front. The lower front panel pulls off. Some models have a knob that must be loosen on the back of the set at each end. Once the front panel is taken off the Lamp door is easily accessed. The new Lamp from Sony will come with the proper Wrench to remove and reinstall lamp.
Hope this helps,
Skyassoc
Jul 03, 2009 | LG RZ-17LZ40 17 in. LCD Television
Philips model 29pt3425-79 flat screen wont switch on
May try to replace your power supply. Average cost runs $200 via Internet. Also may inspect test & replace deformed an or any bulging caps.
Jun 01, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
17" Philips LCD TV has sound, faint blue flashes and blinking pwr
GP151001, Typically these cable/wire connectors fall into a catagory called HIGH DENSITY INTERCONNECT connectors or similar type. I should think that the whole assembly should be available somewhere ****!!! It's just this kind of thing that really gets me P.O.ed louie12fix
Apr 15, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips Epic 17PF9936-37 17" Flat Panel LCD Monitor Logo
157 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
