Question about Nu Mark Numark Cdx Table Top CD Player CD Player
Won't read discs, just spits them out.
I have 2 CDX dex, one of them will not read discs at all now, it just spits them out, the other works fine. its not the cd player because i have changed them over from the deck that works and it still wont read discs, i have also changed the ribbon cable which worked for a couple of days and now is back to not reading discs. every now and again it will read a disc but will get a few tracks in and start repeating the same few seconds over and over, if you filck it to another track it goes back to not reading again!!
is there any other part i can replace that will fix this as i know its not the cd player or the ribbon cable???
  • 6 more comments
  • dj catch Dec 05, 2008
    Yes I have cleaned the lens. I will try again when I get home and let you know. Is there any other solution if the lens cleaning doesn't work?
    When you optic is bad, do you mean i need a new cd player unit? Because It's deffinatly not the cd unit as it works fine when i put it in my other cdx.
  • dj catch Dec 06, 2008
    It is NOT the cd player as it works when i put it in my other cdx.
    The cd player is fine IT IS NOT THE CD PLAYER. What else could it be?
  • dj catch Dec 16, 2008
    It now works after being on for a couple of hours, but i then have to leave it on all the time for it to work. I saw something on this website about the ribbon cable being re-seated, what does this mean?
  • dj catch Dec 17, 2008
    it seems to need to warm up for an hour or two before it will read any cd's.
    No, its still the same!!!
    IT HAS NOTHING TO DO WITH THE CD PLAYER UNIT, IT WORKS WHEN FITTED IN A DIFFERENT CDX.
    Sergeant:
    Novelist:
  • 327 Answers
Its the internal circuit issue the components r loose just needs resoldering as they should directly get heated as u turn the device ON.but its taking time to get heated because its loose inside just resolder the loose components on the main circuit board internally in the device.
Posted on Dec 17, 2008
  • 1,183 Answers
HI,
MY friend , honestly speaking there is nothing more that can be done apart from what you have already tried to make it work , by changing cables and even replacing with the good known drive. The cdx can be repaired , but finfding parts for it would be a challange .
Thanks
proton
  • Mandeep  Singh
    Mandeep Singh Dec 18, 2008
    HI,
    Check the following website.
    http://www.instrumentalparts.com/nucdxsp...
    These are all the parts that you can replace in the cdx. Suspectable points of failure on your drive can be because of the following .
    1. Centre spindle
    2.Switch track selector
    3.PCB funcational assembly
    4. PCB I/O assembly.
    Thanks
    Proton.
    NOTE: open up the cdx to repair and replace parts inside , if you are comfortable working with the electrical equipment. Best of luck
  • 275 Answers
Open the whole thing up and dust it, as it appears that it's not working bc of age.
    Scholar:
  • 113 Answers
The reasons why its spits out because the laser that reads the CD were not functioning anymore and grips that holding the CD were loosen. All you have to is open it or dismantle it and tighten a little bit and replace the CDrom lens. bring it to service center near you and ask for their help to replace it.
  • 105 Answers
Is the player detectingb the disc? try to insert discs at the same time to each of the players and check if loading time is the same, if not it is certainly hardware problem and can perhaps be solved by moving the cd player (I mean puting the player upside down) while loading the disc.
  • 492 Answers
Take this advice for free. Reinvest money into a digital system. Get rid of the cd players and do some research into digital solutions. They are much more reliable, weigh less, and have less mechanical parts to break.
  • 112 Answers
Hello sir,
i think your cd-rom liens need to clean
are
cheek you roms jumper settings
is it a rom on salve
are a on master
and other ways your ROM is now damage
cheek an other to with it
if its works then your old ROM is damage
replace it
from your near and get a branded ROM.
  • MOHSIN AMIN
    MOHSIN AMIN Dec 17, 2008
    sir believe me do it
    its must works
    as i say,
    Guru:
  • 829 Answers
You need to be more specific for me to Help you, As of now i can tell you is clean the disc head and try.
    Genius:
  • 1,199 Answers
This sounds like the laser in your unit needs to be cleaned or realined (then it will once again be able to read the CD
    Genius:
  • 1,011 Answers
Sir,
Click this link for some troubleshooting tips
thanks
good luck
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, I am assuming that you already have opened the CDX a number of times. Right at the center of the bottom cover would be the power supply board. This is where the wires from the transformer go to. Inspect the capacitors. There would be about 3 that are bigger than the others. Pls inspect the top and make sure that it is flat and shiny with no discoloration. Capacitors in general provide filter to the power supply and clean up the rectified outputs of the diodes. If any losses its capacitance, then the DC voltage would be relatively lower. While at it you may want to straighten a bit the flexible white cable that plugs into the DA converter PCB. it might also be to your advantage to clean the exposed contact tips with a hard rubber eraser.
Good luck and Thank you for using FixYa. Happy Holidays.
  • 679 Answers
Get a program called any dvd, it removes the copy and region protection making any dvd readable and able to copy. It's made by slysoft and you can get a trial, just google it
    President:
  • 2,110 Answers
Posted on Dec 14, 2008
    Genius:
  • 1,239 Answers
Hi The C601 will not spin up the disc unless one is detected. If the optics are bad and do not realize that the disc is there...
Try cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the optics are bad. The optics in this unit are KSS-240 (I think). This part costs about $30-$40 depending upon where you get it. You can try to replace it or have a shop replace it for you. Add in the local labor rate for the total repair cost. This is a relatively simple repair. I have done 100s. It usually takes about 45 minutes plus the testing time.
Posted on Dec 05, 2008
    Genius:
  • 3,422 Answers
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
    Genius:
  • 1,550 Answers
Have you cleaned the lens ?
If not clean the lens .
  • 1 more comment
  • SAM ANDERSON Dec 05, 2008
    If this doesnot work Optic is bad in your unit .
    You need to replace it . It will cost you around $70 -80 .
  • SAM ANDERSON Dec 06, 2008
    You need not buy new cd player . You can repair it . If you take to local repair shop they will repair you and they will charge around $70-80 for optic problem .
    Optical block includes the laser diode, associated
    optics, focus and tracking actuators, and photodiode array. It is defective so it is not not able to encode the data properly from the disc . Thats the reason you are having intermittent behavior . Some time reading disc and at other time it is not reading disc .
    Top Expert:
  • Nu Mark Master
  • 77,499 Answers
All this advice! the thing is after all this is said and done you are going to have to replace the darn thing, they are not worth fixing, a new one cost very little.
  • yadayada
    yadayada Dec 17, 2008
    You need to request a refund, you are not going to get it fixed here over our keyboards, not this kind of problem, replace the drive.
CDX-f500
Have you tried cleaning the unit with a "Laser Lens Cleaner?" one that uses fluid? Mp3 is a fickle format and your deck may be having issues reading it. Try running a cleaner thru it. Secondly, when you burn discs, make sure you finalize it by making it "compatable for all player types" Hope this helps
Jun 25, 2009 | Sony CDX-F7500 CD Player
CD's keep spitting back out of player which is in caravan
The drive(optical) drives door mechanism has malfunctioned. If the PC CD drive can be replaced that would be the best, but repairing is also not cost-effective...........sodeep
May 12, 2009 | Sony CDX-L400X CD Player
CDX-FM65????? DOES IT EXSIST???
CLICK HERE for the specs on the CDX-FM653
No manual is available from pioneer for download.
ERROR 11 on pioneer cd players is common.
It can be due to a failing laser or dirty lens. It means that the CD was not recognised, either because of the CD scratched, or it could possibly mean the laser is out of alignment.
If the player works fine with other discs - chances are it needs a good cleaning.
If the player wont read any discs - it's time for a service call. Typically - I charge $50USD for clean and alignment.
you can do it yourself (clean it) by disassembling the player, and using a qtip and isopropyl alcohol - however an alignment requires a special alignment tool.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 16, 2009 | Pioneer CDX-FM657 6-Disc CD Changer
Numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Oct 13, 2008 | Numark CDN95 2-Disc CD Player
Cd player
DOES IT TRY AND SPIN THE CD>?
or does it just kinda click and then spit it out?
May 30, 2008 | Sony CDX-M800 CD Player
CDX wont read any CDs
The CD transport (reader) is shot. These units are known for this! To date, they still havent fully corrected the problem. A band-aid fix is to buy a new transport thru numark or parts dealer.
Apr 13, 2008 | Numark CDX Turntable
CDX-M8800 won't read CD-R discs
hi mate did you make the cd if so make the cd on slow speed it will work then max of 16x on you cd ok mate
Oct 19, 2007 | Sony CDX-M8800 CD Player
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
59 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
