Question about Whirlpool GGW9878P Gas Dryer
Door wire whirlpool gryer model lgt5624bq2. how do you change broken wire holding the front door.
Take out 2 screws near the lint filter. open the front with screwdriver from the sides -carefully. then replace the wires.
Posted on Dec 05, 2008
The door will not open after the washing cycle is complete.I think the door catch is broken now do you go about replacing or fixing this?
u have to remove the front of door boot ie rubber seal from front of mechine 2 screws where the catch goes in holds the interlock 2 mechine remove wireing 3 wires or plug depends if three wires take note of wher the go replace interlock easy.
Feb 15, 2015 | Whirlpool LHW0050PQ Front Load Washer
How to Replace a Dryer Door Switch on a whirlpool
First, make sure the peg on the door that pushes the switch is in place and the two snap pegs that hold the door shut are not broken. If any of these are broken, replace them first and see if that solves your problem. If not, here's how to replace the door switch: Unplug the dryer. Pull out lint screen. Remove two screws revealed underneath. Slide a 1" putty knife between the top and cabinet at the top front corners on each side, jamb it in while tugging the top forward to release the clips, one at a time. Lift top and lean against wall. If it's a gas dryer, remove lower front panel and loosen two 5/16" hex head screws for top front panel. If electric, loosen same screws at bottom of front panel. Remove two 5/16" hex head screws holding front panel from inside near top. Carefully tilt front toward you, holding drum in place. Lift front panel slightly to disengage bottom screws and remove. Gently lower drum until it stops. Unplug two (sometimes three) wires to door switch on right side. Now the front panel is completely free. Remove two Phillips head screws holding door switch onto front panel. Reassembly is the reverse of disassembly. Make sure wiring to door switch is secured to cabinet so they don't drag on the drum, and are not pinched. Be careful realigning the drum into the door opening so felt seal is inside the front glide ring on the drum. After the front panel is in place, gently hand turn the drum to make sure it is turning properly and the belt in still hooked to the idler and motor pulleys. If the drum falls off the rear rollers, or the belt comes loose, you will have to correct it before putting the front panel back on, as you cannot reach them otherwise. Taking pictures during disassembly will help get it back together properly. It really is not as hard as it seems, you may even be able to replace the switch without removing the front panel. Also, if you have a three wire switch, write down where they go or snap a picture. If it's a two wire switch, it doesn't matter, it will work the same either way. Good luck.
Feb 18, 2014 | Whirlpool 358409 Washer/Dryer Screw &...
Broken ceil on whirlpool duet front load leaks water from rubber part
You need to get a new seal. You can probably change this yourself. There is a wire clamp holding it in place that you will have to remove before getting the old seal off and installing the new seal. Finally, you will have to replace the clamp.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Need to change the belt, for model # LER3624JQ0
To change the belt on a whirlpool dryer first unplug the dryer
  1. Remove the lint screen and take out the two screws.
  2. Take a 1 inch paint scraper and insert it between the top and the cabnet about 2 inches from the corner to release the spring clips holding the top in place.
  3. Swing the top back and rest it against the wall.
  4. Looking down inside holding the front dryer panel on,there is a screw on both sides. Remove these screws and tilt the dryer front forward seperating the front from the dryer drum.
  5. Mark the wires going to the lid switch and remove the wires.
  6. Lift the dryer front off and out of the way.
  7. On some Whirlpool dryers there is an access door at the rear lower corner of the dryer. Remove this door and observe how the belt goes on. If the belt is broken it is easier to replace the belt if you can access it through this panel. Some newer dryers have no panel and the belt has to be replaced from the front.
  8. Remove the drum and do a complete cleaning of all lent.
  9. Check to see that the two rollers on the rear panel of the dryer turn freely. If the don't , replace them. (Clean and lubricate the shafts.
  10. Check to see if the idler pulley moves freely. If it doesn't replace.
  11. Positoin the belt over the drum where the marks are where the old belt was and put the drum into the dryer
  12. Pinch the belt and position it threw the idler pulley and over the motor shaft pulley.
  13. Reinstall the front panel with the two screws removed. Lock the top down and reinstall the two screw from under the lint screen. Reninstall the lint screen. Plug dryer in and test.
Dec 29, 2009 | Whirlpool Dryers
Machine won't turn on flashes dL F code and gives me short buzzes
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Replace failed component.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool Washing Machines
Whirlpool duet says Fdl washer wont turn on
F/dL ERROR IS FOR :-- Door Lock ErrorA Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
TO RESOLVE THE PROBLEM :---
Door Lock Mechanism broken or removed from the Door globul1a.gif Check Door Lock/Switch Assembly globul1a.gif Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
May 06, 2009 | Whirlpool GHW9400SU Front Load Stacked...
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Door open!
i had the same prob..and the cure was to change the bushes on the motor.its been fine since
Oct 28, 2008 | Whirlpool AWM6100 Front Load Washer
Whirlpool GGW9878P Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
